Question about KitchenAid KSM150PS Artisan Series Stand Mixer
Peeled beater and hook
The flat beater and dought hook for our kitchenaid mixer have lost some of the coating? is it safe to keep using them, or should we get new attachments?
  • stanthemanal Jan 10, 2009
    Ricardo,
    Thanks for the reply. It makes sense to invest in new attachments rathen than risk any health problem. I appreciate the input. Thanks a lot!
    Stan
  • 135 Answers
Stan. If you were to keep these attachments soaking in alcohol (rubbing) between uses, I'd say yes, however this would probably make more coating flake off. This coating goes into the food you're mixing. Bacteria will remain between the metal part of the attachment and the plastic coating,where you can't scrub it off.
Replace them. Try to find all metal ones. While you're at it, throw out all cracked plates and coffee mugs too, as these cracks harbour bacteria that will survive normal dishwashing. If you are ever in a restaurant and are served food on a cracked plate refuse it and tell them not to just scrape the food onto another plate.
I spent 13 years in the restaurant business, anytime we came across a cracked plate cup or mug, into the trash it went. food and all. Dont take chances with your health. If you found this solution helpfull, please rate it Good luck. ricardok45
Posted on Jan 09, 2009
Kitchen Aid flat beater leaves carbon on my hands and food
Are you using the white coated beaters or the burnished beaters. If they are the white coated beaters then the finish has come off and the zinc/underneath is rubbing off. Are you using the aluminum looking beaters in heavy acidic applications? if the mixer is new go to kitchaid customer support they will re-place. if your mixer is out of warranty then you need to replace it. about 15.00 t0 24.00 USD. if the problem persists then you may be leaking metal shavings from the planetary head, (I don't think it is happening but it is a possibility) if it is ground metal shavings you have a serious problem. I can't say anymore without knowing more. What application are you getting this result. is it all the time. is it after the mixer sits along time. need more info.
Aug 27, 2012 | KitchenAid Food Mixers
One of my blades is stuck and I can't engage the release
Make sure your Beater can slip in and out of the Beater Shaft
easily. Do not force the beater onto the Shaft if the shaft is bent.
If it cannot be removed easily by hand, use a soft rubber mallet
(not a steel hammer) to slightly tap the beater so it can be moved
up and down the shaft or from side to side. Then you can easily
turn the beater left and remove it from the shaft.
From Kitchenaid Manual:
To Attach Flat Beater, Wire Whip, or Dough Hook
1. Turn speed control to OFF.
2. Unplug stand mixer or disconnect power.
3. Tilt motor head back.
4. Slip beater onto beater shaft and press upward
as far as possible.
5. Turn beater to right, hooking beater over pin on shaft.
6. Plug into a grounded 3 prong outlet.
To Remove Flat Beater, Wire Whip or Dough Hook
4. Press beater upward as far as possible and turn left.
5. Pull beater from beater shaft
Jul 19, 2011 | KitchenAid KSM150PS Artisan Series Stand...
First time using bread dough beater It was hard to put on and am unable to remove
as far as possible.
5. Pull beater from beater shaft.
Jul 17, 2011 | KitchenAid KSM90 Ultra Power Series Stand...
Bread dough beater will not come off
as far as possible.
I have a Kitchenaid 550 watt 6 qt. stand mixer model #KB26GIXER. I tried to use it this morning and couldn't get the beater blade to lock in place. Isn't there supposed to be a spring and washer...
There is only one pin on the beater shaft to hold the beater in place.
There is no spring or washer on the shaft.
To Attach Flat Beater,Wire Whip, or Spiral Dough Hook, simply
1. Slip flat beater on beater shaft.
2. Turn beater to right, hooking beater over the pin on shaft.
Jun 25, 2011 | KitchenAid KP2671 Professional 6 Series...
Mixer blade keeps loosing the coating
See pg. 13 of the owners manual for bowl height adjustment procedure:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%209707917.pdf
clockwise to lower the head and counterclockwise to raise the head for more clearance for the beaters.
Apr 11, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
Having trouble removing beater from shaft... HELP
These are held on with a bayonet attachement. You need to rotate the beater to disengage from the shaft.
I would recommmend using a brass pin punch against the tang on the beater and tapping it with a SMALL hammer to rotate the beater.
Once the bayonet is disengaged, it should walk off the pin. If it doesn't you might have to use some penetrating oil like PB Blaster.
IN THE FUTURE put a light coat of mineral oil or food-safe grease on these mating parts to avoid the probllem in the future.
Dec 22, 2009 | KitchenAid KITCHEN AID 5 Quart Artisan...
I have a kitchenaid stand mixer & the top is wobbly & hangs lower than it should & the plastic coating on the beater is starting to come off. How can I fix this?
Hi TH1754, you don?t mention your KA mixer model, but you can easily download a PDF version of your Owners Manual from the KA website: (http://www.kitchenaid.com/flash.cmd?/#/page/home). Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number (for this example, I?ve used a KSM90P mixer) and select the last file listed that appears under Owners Manuals: KSM90PSWW0.pdf (2930.74 KB) and save that file to your PC. You?ll need to have Adobe Reader to be able to open it. Turn to Page 11 and you will find the instructions for adjusting the mixer head height. I have extracted the instructions below: Beater to Bowl Clearance Your mixer is adjusted at the factory so that the flat beater just clears the bottom of the bowl. If for any reason, the flat beater hits the bottom of the bowl or is too far away from the bowl, clearance Tilt-Head models ? Unplug mixer. ? Lift motor head. ? Turn screw (A) SLIGHTLY counter clockwise (left) to raise flat beater or clockwise (right) to lower flat beater. ? Make adjustment with flat beater, so it just clears surface of bowl. If you over adjust the screw, the bowl lock lever may not lock into place. I hope this helps! ?Howard, Burke, VA If this solution has helped you, please rate it, thanks! - hslincoln
Nov 30, 2009 | KitchenAid Food Mixers
Help with replacement parts
Your beater to bowl adjustment may have come out of alignment, which can happen over time with normal use of the machine. This simply means that the flat beater may be contacting the bottom of the bowl.
In your mixer's Use and Care Guide, the beater to bowl adjustment is covered and will provide easy instructions to follow about how to adjust your beater back into proper position.
There are burnished aluminum beaters available. That is to say, they do not have the food-safe nylon coating on the outside of them. Burnished aluminum beaters may not be used in the dishwasher, require hand-washing, no soaking, and immediate towel drying. Failure to follow exact washing instruction with burnished aluminum beaters may result in tarnishing of the beaters.
May 27, 2009 | KitchenAid K5SS Heavy Duty Commercial...
Kitchenaid beater rubs bottom of the bowl
Your beater to bowl clearance has come out of alignment. This can happen naturally over time and with normal use of the appliance. This is something you may correct from home using a flathead screwdriver.
Unplug the mixer, with the bowl and flat beater removed. Tilt the mixing head back as far as the machine will allow. In the exposed hinge, behind where the bowl would normally sit, you will see a 3/8 screw exposed. Turn this screw half a turn counterclockwise (to your left) in order to raise the flat beater from the bottom of the bowl.
This may take a few attempts until the beater is clearing the bottom of the bowl again. If the adjustment screw will no longer turn, do not force it. It is only designed to move so far to make the appropriate adjustment.
Be cautious. Raising the flat beater too high may leave dry ingredients at the bottom of the bowl.
If further information is needed, I would advise you to contact Kitchenaid Customer Service. They may walk through this adjustment through you over the phone and can look into ordering replacement beaters for you also.
Their toll-free telephone number is 1-800-541-6390.
Mar 20, 2009 | KitchenAid Artisan Series Tilt-Head Stand...
KitchenAid KSM150PS Artisan Series Stand Mixer Logo
141 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
