Question about Kodak EASYSHARE 5100 All-In-One Printer
Kodak 5100 AIO won't print after cartridge change
I have two Kodak 5100 aio printers. They worked great until I changed cartridges. Now I have a flashing lights saying there is no ink cartridge and neither will print.
  • Anonymous Jan 11, 2009
    I am having the same problem. I t won't print tells me the color is empty and I just replaced it !! I have had enough of the printer
  • hondagirl23 Jan 12, 2009
    me 3 lol i changed ink 2x its a no go then i thought mabey i should replace the print head but i cant find anyone who sells thee darn thing
    Problem Solver:
  • 15 Answers
The red blinking light indicates that your printer wont recognize your ink carthridge. you can try to reseat the carthridge and the printhead. to remove the printhead just press on the release tab which is located on the upper left corner of the printhead wall. If this will not correct the issue, you need to call their technical support hotline. maybe the carthridge is faulty or there is a problem on the printhead. their hotline no is 1 800 421 6699
Posted on Aug 28, 2009
Koadak easy share all in one, won't print in bacl
Check the version of AiO software you are using. We had to re-install the Aio Kodak software yesterday because the print que did not register when I changed the ink cartridges. The AiO would scan, but the computer side still thought it was out of ink.
Perhaps the latest software will fix your problem too.
Juliasew
Jan 30, 2010 | Kodak EASYSHARE 5100 All-In-One Printer
Won't print the black have bought new cartridge but it still won't print colour ok but no black
If you have done all the steps to clean the printheas, as listed in the printer's maintenance program, contact Kodak and let their customer support know your problem. You will need your model number (5100 AIO) and serial number (lift the platform where you change the ink. There is a number there. They will send you a new printhead. It takes 30 seconds to replace and there are no tools required.
Nov 05, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
I changed the ink cartridges printed properly once now no black. printer says ink is full but fuzzy and no black?
Here are the steps.
1.Please verify that the ink cartridges are intact and securely inserted into the printhead.
a.Lift the printer access door, then remove the ink cartridges from the printhead
b.Verify that the label on the ink cartridges is intact, and the cartridges are not damaged.
c.Insert the ink cartridges into the printhead, then press down firmly until you hear them click into position.
2.Clean the printhead.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} a. On your computer, open your Kodak AiO Home Center software.
b. Click on the Help (?) button.
c. Click on the Maintenance option.
Click on the Clean Printhead option
3.Print Demo Page.
Press Photo and Copy buttons at the same time for 2-3 seconds or until the printer starts printing then release the buttons.
If issue persists,the printhead on your printer require replacement. Call 1.800.421.6699
Thanks.
Regards,
Neerak21
Sep 27, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
The ink level indicator is more than 1/2 full yet the print quality is pale. I cleaned printer heads several times, alligned etc., but still pale print quality. I changed ink cartridges, printed about 40...
try to change the properties of the printer. Usually it has a configuration to increase the printing quality.
And also, look for the configuration for ink drying wait time. Change it to long.
If you dont have any problems with your cartridge. then i think you should need some adjustments from your configuration.
well, i hope this works.. :)
Thank you.
Aug 08, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak 5100 aio; banding/streaking problem
You will need a new printhead. If its not under waranty good luck trying to find one.
Jul 11, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Ink level will not reset when cartridge is replaced
If you take the cartridge to walgreens, etc... they can clear the chip. There is none for home use
give them a call !
May 10, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Printer Problem on Multiple Printers: As if low ink on both
The printhead has dried out and you need to contact kodak to get a replacement, they may do this under warranty. The same thing has happened twice now with my AIO 5500, I guess the problem is if you don't print very often, the ink dries out in the printhead itself, not the cartridges.
Feb 05, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Help
Sorry to hear about your problems. Here are the steps Kodak AiO Support will ask you to perform.
Remove the black and color ink cartridges.
Right above where the black ink cartridge was, in the top left hand corner of the printhead, push up towards the ceiling and you should be able to push a button that releases the printhead.
Place the printhead right back into the printer and push straight back on the back wall.
You should hear a loud snap.
Replace the ink cartridges which should snap as well.
Close the printer.
After about a minute or so the printer will ask you to do a calibration.
Insert a paper and press start.
Scan the calibration sheet.
After that, in the menu, do a printhead clean.
Do one basic and one deep.
Print a demo sheet to see if anything has changed.
If the picture looks better, continue to do cleans.
In the event that it does not, the printhead will need to be replaced and since the printer is still under warranty, Kodak specialists will try to overnight you a printhead.
The whole process is short and free.
The number for Kodak AiO Support is 1 800 421 6699.
Jul 23, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak EASYSHARE 5100 All-In-One Printer Logo
342 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
