Question about Smeg SE399X/5 Stainless Steel Electric Single Oven
HI I HAVE A SMEG OVEN MODEL NUMBER SA995XR I NEED THE INSTRUCTRION MANUAL JUST TO SEE HOW TO WORK THE SELF CLEANING OPTION THANKS
  • Anonymous Mar 17, 2014
    Timer buzzerhasnovolume
Hi I have just installed this oven SA995XR-5 yesterday and have the manual. It doesn't say anywhere it is self-cleaning, just good old elbow grease. Below is what is in the manual.
*I have a question for you. Does the cooling fan in your oven go all the time or does it stop some time after the oven has been turned off (which is what the manual indicates it is supposed to do)?
7.Cleaning and Maintenance
Before performing any operations requiring access to powere parts, switch off the power supply to the machine.
7.1 Cleaning stainless steel
To keep Stainless stell in good condition it should be cleaned regularly after use. Let it cool first.
7.1.1 Ordinary Daily Cleaning
To clean and preserve the stainless steel surfaces always use only specific products that do not contain abrasives or chlorine-based acids.
How to use: pour the product on a damp cloth and wipe the surface, rinse thoroughly and dry with a soft cloth or deerskin.
7.1.2 Food stains or residues
Do not use metallic sponges or shapr scrapers: they will damage the surface.
Use normal non-abrasive products for steel and a wooden or plastic tool if necessary.
Do not allow residues of suraty foods (suc as jam) to set inside the oven. If left ot set for too long, they might damage the enamel lining of the oven.
7.2 Cleaning of the oven
To best oven upkeep clean regularly after having allowed to cool, Take out all removable parts
  • Clean the oven grill and side guides with hot water and non-abrasiev detergent, Rinse and dry.
  • The oven should be operated at the maximum temperature for about 15/20 minuytes after using specific products, to eliminate the residue deposited inside the oven.
  • For easier cleaning, the door can be removed.(8.2)
7.3 Door Glass
The door glass should always be kept clean. Use absorbent kitchen paper to clean. In case of tough spots, clean with a damp sponge using regular detergent.
8.2 Removing
Hold the door on both sides with both hands near hinges (A - there is a diagram showing this is the top hinge) and raise levers (B - this lever is a little arm attached to bottom hinge. Flick it up until it catches into groove on upper hinge. Its quite uncomplicated). Lift up the door forming an angle of about 45 degrees and remove. To refit, slide the hinges A in the grooves, drop door and release levers B.
8.3 Oven door seal
To permit thorough cleaning of the oven, the seal may be removed. Before the seal, take off the door as described above. Once the door has been taken off, left the tabs at the corners as shown in the figure.
After cleaning, refit the seal with the longer side horizontal and insert the tabs into the appropriate holes starting from the top ones.
Posted on Apr 11, 2009
How do I clean Kenmore electric range model; 36393091300 .No manual for this self cleaning range.
Hi,Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Aug 24, 2011 | Kenmore 40494 / 40495 / 40499 Electric...
I need to clean my Tappan oven (it's a range) for the first time, but I can't find the manual for it. I don't want to do anything wrong, cause harm to my oven, or do something harmful that could cause a...
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Feb 09, 2011 | Tappan Ovens
Need cleaning instructions for tappan self-cleaning oven model number TEF351EWE
heatman101
Jan 24, 2011 | Tappan 30IN ELEC IGNa Oven
I have lost my manual and need instructions on how to start the self cleaning for the oven
heatman101
Jan 18, 2011 | Whirlpool GBS307PR Electric Single Oven
I have a Smeg SA130P single oven. I have run a self-cleaning cycle. The cycle completed but, some hours later the lock indicator is still on and the door is locked. How do I get it unlocked?
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Dec 13, 2010 | Smeg F170 Pyrolytic Stainless Steel...
I have a UMP 404 de dietrich oven user manual
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Jul 17, 2010 | De Dietrich UMP404 Powerclean Stainless...
Moved into this house. Has no manual on Kenmore glass top stove, on how to use self cleaning oven. Looking for manual or directions on how to use it. Only have model # 790.96011400 and serial # VF50635079
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Apr 13, 2010 | Ovens
Manual for Smeg SpA42016
SpA 42016 is Smeg's postcode in Italy! Model number will be on same lable. Mod:
Jun 14, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Smeg SA995XR Oven
Hello, I know this was a while ago when it was posted. But do you still need a manual? I can email you one if so!
Sep 08, 2007 | Smeg S1100MFX5 Electric Single Oven
Smeg SE399X/5 Stainless Steel Electric Single Oven Logo
548 people viewed this question
Top Smeg Ovens Experts
ashburton
Hjalmer Lamminen
Hjalmer Lamminen
Jason Harris
Jason Harris
Are you a Smeg Oven Expert? Answer questions, earn points and help others
