Question about Microsoft Windows Vista Ultimate Edition
NEED WIZ HELP- UNABLE TO BOOT FROM XP OR VISTA
Well what I wanted to do was reformat my computer because i have vista ultimate edition and I want xp. Im scared that if I reformat my computer that I wont be able to install xp because my computer can't boot from the dvd drive. The problem was that it wouldn't boot my xp cd or even my vista cd. I have 2 hardrives and one of them, drive c, has vista installed. So what I did was i disconnected my hardrive that has the vista installed from my motherboard. My other hardrive is blank so when i rebooted it says error loading operating system and when i try using my xp or even my vista cd to boot it doesn't boot. So i reconnect that harddrive that has vista installed and everything gos fine just that i cant boot XP or VISTA.Really weird need help. I think it might have to do with my BIOS but it is set to default. When writing a solution for me PLZ write alot of information and solutions just in case your first solution is no help. THX!
I had someone from this website give me a solution stating that- "first you must check your XP/Vista cd if it is bootable then open the bios setting change the first boot to CD ROM save and exit the bios insert CD wait for a second if the CD is BOOTABLE if so then follow the instructions of formating drive. But before you do that you must be sure that you have all the driver need to you PC for security you must use the black drive then install the XP OS." Well was is a black drive anyways? Rally need to get this to work.....
  • Curtis Tuendemann May 11, 2010
    You have set the primary boot device to CD I assume?
Yes, it's true.. you dont have to disconnect your drive c when you want to install winXP since it can be installed in drive D. just follow what the first info that says that you have to set you first boot to cd/dvdrom so that you winXP installer will boot. then choose drive D to install your winXP.. now you can have 2 OS at the same time, winVista in drive c and winXP in drive d. you just have to choose which to use during start up.
Posted on Apr 02, 2009
  • 227 Answers
Well the info about setting your boot priority is correct. Set the DVD or CD drive as 1st boot device. Usually, as the machine boots it allows the option to boot from CD/DVD by a message to the effect of "Press (<some key> usually the space bar) to boot from the CD/DVD". if NOT pressed in 5-10 seconds, it then reverts to the 2nd boot priority device. Do you know about jumper settings located on the HDD?
Posted on Apr 01, 2009
  • Arthur Hoffmann
    Arthur Hoffmann Apr 01, 2009
    Well the info about setting your boot priority is correct. Set the DVD or CD drive as 1st boot device. Usually, as the machine boots it allows the option to boot from CD/DVD by a message to the effect of "Press ( usually the space bar) to boot from the CD/DVD". if NOT pressed in 5-10 seconds, it then reverts to the 2nd boot priority device. Do you know about jumper settings located on the HDD?
  • Arthur Hoffmann
  • 26 Answers
Dont mind it...
if you want to install xp to your computer while you are using utimate vista you can install it...
but you must have a large space of memory to install xp, tnx anyway hope that i can help...
Posted on Mar 22, 2009
2 Suggested Answers
  • 27 Answers
SOURCE: NEED WIZ"S HELP- CANT BOOT XP OR VISTA CD FROM DVD DRIVE
I'll give a whack at this problem. I think the previous person meant blank drive NOT black drive (that doesn't make sense to me).
I would follow the previous persons in going to BIOS and making sure the first boot device is CDROM. My question to you is whether you've already done this or whether you need assistance with this process. If so, please tell me what computer model you have.
Dman
Posted on Jan 08, 2009
Downgrading from vista to xp ( I have disk ) on h p dv6500 dv6504au A M D turion64 x2 Can you help please.
You download GPARTED live cd, boot it usually by pressing the boot key at startup, select cd drive, delete the paritions on the hard drive, or if you want to keep you're vista, resize it, then once thats done, boot from the XP disc, and select the empty partition format it, then install to it. Done.
Sep 02, 2011 | Microsoft Windows Vista Ultimate Edition
Can i boot win vista cd? can i use vista cd to reformat my computer?
Yes you can format computer with vista disk and instal new windows.
Inser that vista disk into cd/dvd rom then when you power up the computer press F1 or F2 del or ALT+F2 key to enter in bios.
Then go to boot menu and set first boot device as cd /dvd rom then save settings and exit from bios.
Then it boot with windows disk.Then follow the procedure and choose installing new windows xp then select 1 partition and format it then it install windows vista on it.It will take 30 to 45 minutes to complete the installation.
Let me know if you need further assistance.
Thanks for using FixYa.
Jul 13, 2010 | Microsoft Windows Vista Ultimate Edition
Removing windows 7 boot restore win xp boot
please be more precise in what you would like done...do you have both os on your computer?? are you trying to dual boot? did you want to remove W& and put xp back on..or what?? i can only help if you tell me exactley what you need done...otherwise just format the hard-drive..then reinstall xp..
Nov 30, 2009 | Microsoft Windows Vista Ultimate Edition
Dman
Jan 08, 2009 | Microsoft Windows Vista Ultimate Edition
NEED WIZ HELP- UNABLE TO BOOT FROM XP OR VISTA FROM DVD DRIVE
Jan 07, 2009 | ASUS A8N-VM CSM (00610839133826)...
Getting ERROR FOR OPERATING SYSTEM
This is because you have to change the boot sequence in the BIOS or setup of the motherboard. When you first turn on the computer you can see something like press DEL to enter Setup or F12 or F10 or F2 depending onyour motherboard. once you get into setup you will see either boot sequence or boot order. Set the CDROM as the first boot device. Then when you startup the computer again you will see PRESS ANY KEY TO BOOT FROM CD. proceed with pressing anything on the keyboard.
Download
Hello I want to download Vista Theme for XP
Please
i want to download vista theme for xp ANKAJ SAMKARIA hello i am abhay. i want windows vista ultimate edition
abhay kumar
Aug 15, 2008 | Microsoft Windows Vista Ultimate Edition
Unable boot vista ultimate (installed earlier) after installing new xps2
You have to reinstall vista bootloader.
Just insert vista dvd in the drive and boot from it.
Select startup repair and it will fix everything back to normal.
Jul 05, 2008 | Microsoft Windows Vista Ultimate Edition
Unable to Access Any Operating System
i would try to reinstall xp on the first and largest hard drive and go from there, reformat, and start from the begining. there should be no problem if you do this as long as you have a legit copy of xp and reformat.
May 11, 2008 | ASUS M2N-SLI Deluxe Motherboard
Demo problem
If you have installed vista as a multiboot sytem, then you can do the below: Otherwise you have to do as tom19511 said:
Uninstall Windows Vista on a multiboot system
Applies to all editions of Windows Vista.
You cannot uninstall Windows Vista. However, you can change the code that starts the operating system (often called the master boot code), and then remove Windows Vista from your multiboot system and return to Windows XP or Windows 2000. You will need your Windows Vista installation disc for this procedure.
Before you begin, back up your programs, files, and settings. Removing Windows Vista is an advanced procedure that could result in losing information stored on your computer. For information about backing up data, search Help and Support for "back up."
1) Insert the Windows Vista installation disc.
2) Click the Start button getopencontent.aspx?assetid=4f6cbd09-148c-4dd8-b1f2-48f232a2fd33&documentset=en-us&renderkey=xml, click All Programs, click Accessories, right-click Command Prompt, and then click Run as administrator. getopencontent.aspx?assetid=18abb370-ac1e-4b6b-b663-e028a75bf05b&documentset=en-us&renderkey=xml If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
3) Type [DVD drive letter]:\boot\bootsect.exe /nt52 ALL /force and then press ENTER.
For example, if the DVD drive letter is F, type f:\boot\ bootsect.exe /nt52 ALL /force.
4) Eject the Windows Vista installation disc.
5) Restart your computer.
Your computer will start in the previous version of Windows that you have installed.
6) Delete Windows Vista files and folders, such as the Program Files, Users, and Windows folders, manually.
Note: You can also remove Windows Vista by reformatting the partition where it is installed, but do this only if that partition is not the boot partition. Reformatting the boot partition might make your computer unable to start.
Nov 14, 2007 | Microsoft Windows Vista Ultimate Edition
Microsoft Windows Vista Ultimate Edition Logo
129 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
