Question about Samsung AS18A6RB Air Conditioner
Circuit diagram i have one problem when turn on the power after 1 minuts sestem shut down
  • 2 more comments
  • mostafa rajbala Jun 03, 2007
    I NEED SHEMATIC DIAGRAM SPLIT AIR CONDITION
  • jinu thomas May 27, 2008
    i need circuit diagram
  • kanoterm Jun 20, 2008
    Me also need electronic circuit about split air conditioner. there was
    some elctrtic shock and the bouth electronic components to the bouth
    units (in door and out door) are broken. I am in Macedonia. I need shematic for it to fix them. please answer somebady.
  • mickeythebes Jul 13, 2008
    when turn on the power after 1 minuts sestem shut down, it cool during that 1 minute!
I need electronic circuit about split air conditioner
Posted on Apr 27, 2008
  • 883 Answers
Maybe detecting lack of freon...does it cool during that 1 minute?
Posted on May 31, 2007
How can I trouble & fix my scooter
hi sounds like youre circuit has shut down if your have had it in free wheel it will shut down all the lights will work take the key out put it in drive and put the key back if it has a similar circuit as a pride XL it should work...........one more thing if u leave the key turned on for 20 minutes the circuit will shut down all the lights will work take key out wait for a few minutes & put the key back in ..if this does nothing get youre batteries checked with a ..battery load tester .....good luck
Sep 05, 2015 | Pride Hurricane 4 Wheel Personal Mobility...
Overheating
It probably has a fault.But try this.Disconnect all speakers and inputs and try again.If that works reconnect the speakers A PAIR AT a Time.That should lead to the fault.If that still shuts down.
the set is going into protection mode. This is caused when ever one of the many sections of the tv has a shorted circuit. The increase in current is detected by the protection circuit and it flies into action by turning OFF the ON relay.
Most often, but not always, it is either the high voltage section or one of the deflection amplifiers. But can be the power supply, the audio amplifier or voltage regulators, etc.
Goodluck..
Feb 19, 2008 | Samsung HLN5065W 50" Rear Projection...
What is the clicking noise come from the relay fuse box with e the motor off and the key out
It could be a couple of things. Try finding out which relay is clicking by touching the top of each relay. You'll be able to feel the click. The lid to the fuse box should have a diagram of what each relay controls. If the fuse box doesn't have the information, your car's manual will have it. In the back, look for "Fuse."
Mar 24, 2015 | 2005 Kia Sorento
IN104 automatic shutdown
Hello, my infocus in104 will power up for a while (1- 5 minutes) when connected to the power supply and turned on, after that it automatically shuts down. Power button does not light red when it automatically shuts down and need to be unplugged for a minute or more before red power button will light up again.
Mar 21, 2013 | InFocus IN104 Projector
Underhood fusebox fuse #13 50 amp what is it for
The large MAXI fuses in the engine compartment fuse block are the MAIN fuses. They supply voltage to several other fuses or circuits.
MAXI Fuse #13 in your 1996 Ford Ranger is supposed to be a 30 Amp fuse (not a 50 Amp) according to the power distribution diagrams as well as the fuse block detail diagram. This fuse supplies voltage to the Powertrain Control Module (PCM) power relay and to the oxygen sensor heater circuits.
Please note that it is NORMAL for this fuse to cause a draw on the battery during vehicle operation and also after engine shut down. The OBD-2 oxygen sensor heater circuit monitors run after engine shut down and key off. This can take up to 45 minutes to complete. After the O2 heater monitor has run, the PCM will go into sleep mode.
When the PCM goes into sleep mode, the battery draw from this fuse will be reduced greatly. If you are performing "ignition-off-draw" tests trying to figure out why the battery keeps going dead, it is best to use an ammeter that has a 1 or 2 amp scale. You should set-up for the test using a shunt bar. Wait for 45 minutes to an hour for all of the computer systems in the vehicle to go into sleep mode, then open the shunt. Your computer memory, radio pre-sets, clock, etc. will continue to draw without ever shutting completely off. Any draw under 300 Milliamps is considered "acceptable". It is my experience that most vehicles have an ignition-off-draw of somewhere near 150 Milliamps.
The underhood fuse box diagram can be found on page 314 in the 1996 Ford Ranger Owner's Manual.
If you do not have an Owner's Manual, you can get a PDF version HERE (direct link)
May 15, 2012 | 1996 Ford Ranger SuperCab
When we try to turn on the tv, it chirps and shuts off
Power supply (switched mode) is shutting down due to either a fault within the power supply itself, or a problem in the line stage (EHT) and the current protection circuit is shutting down to prevent further damage. Flyback diode often fails shutting the power supply down.
A circuit diagram is required in order to repair this.
Sep 12, 2009 | RCA HD52W59 HDTV Projection Television
Power Problems
You may have jarred a component loose inside. Open the side panel and carefully inspect the cable connections and circuit boards.
Check the memory sticks as well. Good luck!
Mar 13, 2009 | Gateway 310 Series (158920) PC Desktop
Tv won't turn on..
need to replace the power supply
Sep 03, 2008 | Hitachi 53UDX10B 53" Rear Projection...
RCA D52W20 52" TV SHUTS DOWN AFTER A FEW MINUTES
this is the filment circuit having a problem. i think you will find it is a loose connection on a solder joint. Goodluck
Jan 16, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Set will not stay on
Better get this checked out by a technican. One possible reason could be coolant from the picture tubes leaking down onto the printed circuit board causing this symptom which could end up destroying the circuit traces on that board. Other possibilities include problems in the power supply or deflection circuits. If the set is over 8 years old, I would just replace it with a HDTV.
Jan 30, 2007 | Mitsubishi VS-55707 TV
Samsung AS18A6RB Air Conditioner Logo
334 people viewed this question
Top Samsung Heating & Cooling Experts
Nyte_Ryder
gbob59
billconfused
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
