Question about MSI K8MM-ILSR Motherboard
Try to install 2gb ddr memory on MS-6741 motherboard
I try to install 2 X 1GB PC3200 184 PIN 400 MHZ DDR RAM on a K8MM-ILSR (MS-6741) motherboard http://www.msicomputer.com/product/p_spec.asp?model=K8MM-ILSR . When I start the computer nothing happens. I have flash the AMI BIOS to version 3.7.
Thank you.
Luc
  • lucbourdages Jan 11, 2009
    Thank you,
    I will try with 2 X 1GB PC3200 333 MHZ
Hi, never install 2 pieces of DIMM, not even CORSAIR XMS 3200XL 2x512MB 2-2-2-5 does boot up at DDR400 (!?)
reason: K8MM-ILSR and K8T800-ILSR M-ATX boards will clock RAM down to DDR 333 (even with a latest VENICE revision S754 CPU) which seems unlucky RAM clock to CPU ratio. Board freezes and hangs. I suggest to install only 1x 1GB PC3200. I can recommend KIT (but use only 1 !):
OCZ 2GB DDR400 2x1024MB PC3200 2-3-2-5 Platinum
G.SKILL DDR400 2x 1GB F1-3200PHU2-2GBZX 2-3-2-5 (blue green colored heatsink) Hope this helps, rainer N.
Posted on Mar 19, 2009
  • 66 Answers
Pls check you motherboard manual if it accept that kind of memory because some board cannot accept.
Posted on Jan 08, 2009
Dont know the ram that it use. wat is the number on the battery
  • K8M800-M7A
  • Support DDR 333/400 MHz
  • 2 x DDR DIMM Memory Slot
  • Max. Supports up to 2GB Memory
  • the battery i dont no
  • hope it helps
  • Biostar K8M800-M7A - motherboard - micro ATX - Socket 754 - K8M800 specifications
    • General
    • Product Type Motherboard - Micro ATX
    • Cache Memory None
    • Chipset Type VIA K8M800 / VIA VT8237R
    • Max Bus Speed 800.0 MHz
    • Processor Socket Socket 754
    • Max Processors Qty 1.0
    • Compatible Processors Athlon 64 , Sempron
    • Memory
    • Max Supported Memory 2.0 GB
    • Supported RAM Technology DDR SDRAM
    • Supported RAM Speed 400 MHz , 333 MHz , 266 MHz
    • Graphics
    • Graphics Controller VIA UniChrome Pro
    • Memory Allocation Technology Shared video memory (UMA)
  • Jul 20, 2011 | Biostar K8M800-M7A Motherboard
    I want tobuy 1gb memory card for my ms 6787 ver2.. what is the specific type of memory card is the best for my board (1gb or 512mb only)
    For this particular motherboard, you need a 184-pin DDR SDRAM DDR 266 (PC 2100) memory module. These can be found in sizes ranging from 256MB to 1GB. There are several places that these could be found on the internet. Pricing for a 1GB module seems to be around $44 or $45 USD currently.
    The MS-6787 supports a maximum of 2GB of RAM (1GB in each DIMM slot).
    Hope this is helpful!
    May 09, 2011 | MSI P4MAM-L (MS-6787) 400/533 MHZ FSB...
    What kind of memfory do I need for a P4M80-M4 Motherboard? I want to install another card.
    Here is the specs of the memory that you can use for this motherboard.
    2 x 184-pin DDR SDRAM
    PC3200 (DDR400) DDR SDRAM
    Maximum 2GB
    Jan 03, 2011 | Biostar P4M80-M4 Motherboard
    I upgraded my RAM to 1 Gig but it's still showing only 256 meg. Why?
    Hi this model sopport 2Gig Memory Ram.
    RAM Technology DDR SDRAM Installed RAM 512 MB Max Supported RAM 2 GB Number of Memory Slots 2 x DIMMs Supported RAM Speeds 400 MHz • 333 MHz Installed Cache Memory 256 KB
    Please check in to your Bios system maybe share memory Video or capacity is setting
    Nov 03, 2010 | Dell Dimension B110 PC Desktop
    Mercury PVCLE 266M L is support DDR 400MHz RAM?
    Memory Support
    ♦ Two DIMM sockets for DDR memory modules
    ♦ Supports 200/266MHz DDR memory bus
    ♦ Maximum installed memory is 2GB
    There you have it. I'm sorry but that motherboard does not support 400 MHz.
    Hope that helps, give me thumbs!
    Aug 23, 2010 | Mercury PVCLE266 Motherboard
    I have 2 slots, currently only one is in use, it has 512 DDR 400 MHz PC 3200U. Can I use both slots and how much RAM will my SiS 963Lua support? Thanks. Richard
    Hey Richard, your board has 2 x 184 DIMM slots, that are both usable, with a maximum capacity of 2GB, supported RAM types are 333MHz, and 266MHz..
    Hope this is what you are looking for,
    Cheers,
    Memory Type DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 333 MHz • 266 MHz Max Supported RAM 2 GB Memory Type DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 333 MHz • 266 MHz Max Supported RAM 2 GB DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 333 MHz • 266 MHz Max Supported RAM 2 GB
    Apr 09, 2010 | Foxconn K7S741MG-6L Motherboard
    Please identify RAM upgrade options for Asus PSCH-L motherboard. Thank you.
    From the Asus spec site: Memory Memory Type dtrquestion.gif DDR SDRAM Number of Memory Slots 4 x 184 Pin DIMMs Supported RAM speeds 400 MHz • 333 MHz • 266 MHz Max Supported RAM dtrquestion.gif 4 GB
    Memory Memory Type dtrquestion.gif DDR SDRAM Number of Memory Slots 4 x 184 Pin DIMMs Supported RAM speeds 400 MHz • 333 MHz • 266 MHz Max Supported RAM dtrquestion.gif 4 GB DDR SDRAM 400; 333; 266mhz
    4 GB max 4x1024 184pin
    Hope this helps.
    Aug 26, 2009 | ASUS PSCH-L Motherboard
    Replacing existing DDR RAM
    Well this that you can use PC3200 DDR 1GB then those you mentioned above ... and let me tell you there is only bus speed difference between ..
    Jun 23, 2009 | MSI 865P Neo (MS-6742-020) Motherboard
    Abt ram
    101GGC:
    boxbullet_gray.gif Two DDR SDRAM Dual Inline Memory Module (DIMM) sockets boxbullet_gray.gif Support for DDR 400 MHz and DDR 333 MHz DIMMs boxbullet_gray.gif Support for up to 2 GB of system memory
    102GGC:
    Support for DDR2 533MHz and DDR2 400MHz DIMMs
    Support for up to 2GB of system memory
    Mar 10, 2009 | Intel D101GGC Motherboard
    Try to install 2gb PC2700/DDR333 memory on MS-6741 motherboard
    Hiya Luc
    the problem is with your memory, i have read your post and b4 you was using pc3200 and now using pc2700 have you made sure that the memory is set to auto in the bios as it sounds like it is still set to ddr 400 and not ddr 333
    regards Rik
    Feb 26, 2009 | MSI K8MM-ILSR Motherboard
    MSI K8MM-ILSR Motherboard Logo
    566 people viewed this question
    Top MSI Computers & Internet Experts
    vsri9
    Alun Cox
    David
    David
    Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
