Question about Acer Aspire 5100 Notebook
I did a recorvery on my Aspire 5100 everything installed but when it gets to the acer launch install it just keeps running at process 4/5
  • ajfibew683 Jan 08, 2009
    i let run all night and did the recover cd twice and still having the problem
    Scholar:
  • 142 Answers
U hav to wait when it's running yr laptop hdd light are showing blinking means it's working it it's not then some problem wirh hardware or file curraption problem then do boot woth recover cd if it avalable
Posted on Jan 08, 2009
  • Chinmay Joshi
    Chinmay Joshi Jan 08, 2009
    then run in safe mode chek what it's show and just conform yr dvd/cd is ok or not is that any scrach if it has then may be yr cd/dvd is haveing problem also need to do when i run in safe mode chek everything is ok or not..? then use in RUN "msconfig" and select statup then unchek acer launch path after restart yr pc and chek.. it's help u..
  • Chinmay Joshi
How to get back my acer webcam aspire 5100-3825 and how to set it
if you have the webcam driver installed, you only need to install the webcam software. Try Cyberlink YouCam3, download link:
http://www.topshareware.com/cyberlink-webcam/downloads/1.htm
Apr 10, 2010 | Acer Aspire 5100-3825 Notebook
CineDashMediaConsole.volume not working.
Cinedash FIX for Windows 7
This works to fix the CineDash Media Console!
I had the same problem with my Aspire 8920G
Now it works fine.
Getting the CineDash Media Console and Launch Buttons working
If you have problems with either the CineDash Media Console or Launch buttons then you will be happy to hear that the solution for fixing these is easy!
The first thing that you will need to do is install the “Launch Manager” which can be downloaded off the Acer website. Go to http://www.acer.com and click the service support, then driver download. Go to your model. Download the Launch Manager on the acer site. The filename should be “Kilimanjaro_v2.0.00_Vistax32×64_XPx32×64.zip” the version of Launch Manager under the Windows Vista operating system .This will get the Email, Web and Empowering Technology buttons working with their default settings. If you need to change what the buttons do, you can launch the application named “Launch Manager” in the start menu.
Uninstall any previous version of Launch Manager
The solution to my problem was to get the Launch Manager to run in compatibility mode for Windows Vista Service Pack 2.
Unzip. Explore the new folder and right-click Setup.exe.
To do this go to the Launch Manager Install directory (C:\Program Files\Launch Manager ), right-click on “setup.exe”, select the “troubleshoot compatibility” tab, check the “Troubleshoot program” check box and then click “The program worked in earlier versions of Windows but won’t install or run now”. Then select “Windows Vista Service Pack 2”. Then click “Start” program. Now everything should work properly! It will install. But don’t reboot yet!
Now locate and explore the freshly installed folder in your program files directory – (probably C:\Program Files (x86)\Launch Manager or C:\Program Files\Launch Manager depending on if you are running 64-bit or 32-bit)
right-click on “LManager.exe”, select the “troubleshoot compatibility” tab, check the “Troubleshoot program” check box and then click “The program worked in earlier versions of Windows but won’t install or run now”. Then select “Windows Vista Service Pack 2”. Then click “Start” program. Now everything should work properly! It will install.
Reboot and enjoy properly synced volume, and fully functioning buttons.
Feb 16, 2010 | Acer Aspire 6920 Notebook PC
Acer Aspire 5100 back to factory settings
You may be able to hold F2 as you power up to open up the "setup" screen. There should be an option to restore to factory defaults on that screen.
Jan 12, 2010 | Acer Aspire 5100 Notebook
Acer aspire 5100 stops at agpcpq.sys and keeps rebooting. Will not boot up normally, safe mode, or any other way. Booted off of install CD and ran chkdsk /r. No luck.
Boot from the CD again and this time run chkdsk /f
This command will try to fix any errors with the file system and check for and recover bad sectors.
Hope this helps.
Aug 28, 2009 | Acer Aspire 5100 Notebook
NEED DRIVERS FOR ACER ASPIRE 5100
Hi there
You can get all the drivers for that model from acer support site>>>>
http://support.acer-euro.com/drivers/notebook/as_5100.html
Good luck and thanks for using Fixya!
Jan 15, 2009 | Acer Aspire 5100 Notebook
Acer launch manager
how big is the hardrive 2.5 inch or 3.5 inch mine is messed up and i need a new one
Feb 24, 2008 | Acer Aspire 5630 Notebook
Acer launch
Kill Startup:
1. Reboot and keep hitting F8
2. Choose SAFE MODE and hit enter
3. Win Xp - Start - Run - MSCONFIG or if Vista Click Start - then in Start Search Box type is SYS and click System Configuration
4. Click on Startup Tab
5. Click Disable All
6. Click OK
7. Click Restart
Dec 27, 2007 | Acer Aspire L100 PC Desktop
Acer Aspire 5310 Bluetooth Heeelppppp
I Also have the Aspire 5310 and when you press the bluetooth launch button it says 'No Bluetooth Device', this is becasuse it does not have the Bluetooth card installed into this computer and this is an extra for your laptop... hope this helped.
Thanks
Dec 14, 2007 | Acer Aspire 5100 Notebook
My acer aspire 5610z
Do u have installed sound dirver???Email me at ar_pllana@hotmail.com and i will fix ur problem.OK?
Nov 08, 2007 | Acer Aspire 5100 Notebook
Acer Aspire 5100 Notebook Logo
Brian Sullivan
Brian Sullivan
