Question about Microsoft Windows XP Home Edition
XP pc very slow to boot and run
I was performing a back up and the system crashed. System=iwll
P4R533-n P2.4ghz 1066 1gig rdram. Necessary to format C and using an image copied to the 80 gig WD 7400, The macine takes forever. Task manger=systen idle at 00- CPU at 100% There are no apps running and the best I can get is 65-70% system idle process. What ever I open msconfg/control panel ect takes forever. When I run the mouse over to the start button the flash light symbol appears as it looks for the start menu. I tried two HD with the same result removed the pci cards and the same. I am thinking motherboard but it does run. Maby upgrade the board but don't what card to buy????????? LOST
  • 1 more comment
  • rddesilets Jan 10, 2009
    Hi Ken
    Thank you for you time and advise. I am not the type to just let the problem set. This problem was still occurring even after a format of C: re-installation of windows xp pro. The system never was connected to internet after the install. So I decided that the problem was in the Bios and went through every step and what I did not understand googled. After a ton of research and trying many different settings top to bottom. Finally hit it the aperture setting which is how much memory the video card can use was set at 64 with 16 the lowest and 256 the highest. Set this to 256 and like a switch the CPU usage at idle went to 0% and the system Idle process went 99% just the way we like it. The machine is as fast as ever.
    Thanks
    Rick
    http://www.tweak3d.net/joomla/features/h...
  • berniesmith Jan 19, 2009
    XP Pro Running Very Slowly after Acronis Restore
    Hi, ....I saw the "do you have the same problem" link and would like to contribute the following - along with any new feedback from anything I try to resolve it.
    I have just installed a new HDD to replace a flakey one. I used Acronis True Image to clone the old drive content, (MBR, Boot Sector and all) and after some problems getting the new drive recognised by my BIOS, I restored the Image to it and successfully booted into XP. The problem is that after the first couple of background programs load and show in the system tray, everything slows down to snails pace. Although not all such background programs seem to be loading at all, it does reach a point where I can access the Start Menu - however, it takes about 10-20secs to respond to any mouse click. I haven't successfuly opened a program.
    I've cloned a drive that had no apparent problems beforehand so I'm a bit mystified. I note that Norton 360 isn't getting started, but since it's not using resources I can't see that that's the cause.
    I can open Task Manager, and it shows 30-odd processes going on, but the only one using any CPU resource is "SYSTEM", which is using 99. "System Idle Processes" is using 00. Clearly something is chuntering away leaving no resources for anything else - does anyone have any ideas what it might be? Nothing seems to be occupying excessive RAM.
    Thank in advance for any suggestions.
    Scholar:
  • 34 Answers
Hello
I will try to help you out with this.  First, don't be too rash and run out and get a new motherboard, since I think you have a software problem not a hardware one.  I will try to get you to diagnose your system a little, and we can get through this together.
With your system booted up, do a CTRL-Alt-Del.  I know you did this already, but you were looking at something different.  When the task manager comes up, it says no apps are running, but did you look at the processes running?  Click on the "Processes" tab, and then click on the CPU column twice. (First click will sort and put the heaviest running processes on the bottom, second click will put them at the top!).  Now you have a good indication of what your system is working hardest at.  Some viruses/malware etc., will do exactly what you are talking about, including eating all of your CPU time.  If you have a process that is 95% or higher on that list, that is your problem.  If it has a name like "sdfioiuyw" or such garbage, it is probably a virus/worm.  First, highlight the process eating all of the CPU time and then click "End Process".  Once that process ends, your computer should be running normally.
Assuming that the above paragraph went well, the next thing is to try to figure out what caused it.  First I would run one of the available virus scanners, then a malware scanner, and finally an adware scanner.  Following the instructions for each of the above programs, you should be back in business, and happy with a system running pretty fast.
I hope this helps you out!
Ken
Posted on Jan 08, 2009
Is this computer able to dual boot win 7 and xp
Which version of xp are you trying to install 32 or 64 bit ?
Your ability to install a second operating system on your Windows 7 system hinges on one thing: partitions. If your computer has only one partition, you can't dual-boot your system without erasing all information on your computer. Two hard drives, or two partitions, enables you to dual boot. Check this information first, before proceeding.
Click "Start" and type "disk management" into the search bar. Click on "Create and format hard disk partitions" in the list of programs to open "Disk Management." Look at the list of partitions and available drives. The information here will be different on every computer. "C" is your primary hard drive and active operating system partition, and this drive contains your Windows 7 installation. You can't install Windows XP here without formatting the system. Check for secondary drives and partitions in Disk Management. Your system may have a "D" or "E" drive. Some computer manufacturers create a hidden partition with recovery software: don't remove this partition. If you have a secondary partition called "D" with more than 2GB of free space, you can install Windows XP here. b> Installing XP b> Insert the Windows XP Setup disc into your CD or DVD drive and close any windows that appear. Shut down your computer with the disc in the drive. Turn the computer on and look for a message saying "press any key to book from CD." Press any key on your keyboard when this message appears. Most computers are configured to look to the CD or DVD drive first, before booting to the operating system. If your system doesn't recognize the disc, you will have to enter your BIOS and change the boot order. Look to your manual for information on changing the boot order. Press "Enter" on the "Welcome to Setup" screen to load the Windows XP setup program. Read the license agreement and press "F8" to accept. Windows will detect that an operating system is already installed on your primary partition and present a list of other partitions to install XP. Use the arrow keys to select your secondary partition ("D") and press "Enter" to confirm that you want to install XP here. Then choose what to do with the partition: leave the file system intact or format the partition using FAT32 or NTFS. Windows XP supports both file systems, but requires NTFS on partitions larger than 32GB. You don't need to format the drive to install XP. Follow the prompts on screen to enter your personal information, serial number, and date and time. The setup program copies files to your PC and reboots -- don't press a key to boot to the CD. When you have to operating systems installed, a DOS screen appears asking you to choose an OS; press the down arrow key to highlight Windows XP and press enter to complete the setup. You will have to choose this every time to boot into XP, otherwise your computer will boot to Windows 7 by default. Hope this helps.
b>
Jan 06, 2013 | HEWLETT-PACKARD Pavilion Desktop with AMD...
My pc is running really slow... can u please help me????!!!!?????
There are a number of reasons but mainly 2 kinds causing a PC running slow. Outdated hardware or poor system maintenance. If possible, try upgrade hardware configuration such as add more RAM etc. Otherwise try this program Speed up PC to diagnose & fix the slow pc for issues. Best regards!
Jul 17, 2011 | Computers & Internet
PC on boot up shows busy disk light for an hour or so. Runs programs very slowly. Runs AVG anti-virus and Malwarebytes' anti-malware with no problems. Runs Spybot-search & destroy, but locks up on fix...
start your PC in safe mode By pressing F8 as it boots into windows Just safe mode not with CMD prompt or Networking. then ren the AVG &spybot-search & destroy, program again this should sort out your problems
Apr 26, 2010 | ASUS P4R800-VM Motherboard
Pc to slow
for this you need a system recovery discs or boot discs just insert them and follow the instructions
Apr 19, 2010 | E-Machines eMachines Desktop PC
Hard drive full running xp ,drive is paritionedc,d
To delete a partiition is quite easy in windows. but you will need a third party application like "partition magic" to merge two partitions together, this could be costly
The best advice I could give you is to back up all your information and reinstall your windows straight onto one partition. This will improve your overall speed and also probly also free more space by deleting unwanted programs, spam etc.
Regards
Dec 05, 2009 | Dell Dimension E310 PC Desktop
Administrator password Dell Inspiron 1720
If the system is asking for an administrator password in Windows and you are wanting to format and reinstall the system, then the password shouldn't be an issue. Most inspiron systems are equipped with a PC Restore partition CTRL+F11 just after the Dell Splash Screen should enable the restore process. If PC Restore doesn't work, then boot to the XP CD and format the NTFS partition and install Windows XP clean. If you have Windows Vista, the PC Restore is run from the F8 Boot menu. If no restore partition is accessible in Vista, then again Boot to the Vista DVD and format the NTFS partition and install VIsta.
Sep 30, 2009 | Computers & Internet
I have Windows Vista Home edition installed in My Compaq Presario 700. I have been experiencing a slow down in the performance from last 3 days. So tried to install Windows XP. But It immediately shows...
You need to format the drive so back up all docs etc that you want to keep and then boot from the install disc (make sure it's an install disc NOT an upgrade) then you will see an option to format and partition the drive. The problem is that Vista is an upgrade from xp, and it won't allow you to downgrade.
Jun 30, 2009 | Compaq Presario 700 470024-192 Notebook
Windows running very slow
Have you scanned the PC (all drives) for spyware and viruses?
Spybot search & destroy is a good, free application.
For anti-virus, Trend Micro PC-Cillan or CA Internet Security
(Nortons will drastically slow down your computer)
Have you loaded any other software on the C drive?
Often programs designed to load up & run in the background at startup cause a PC to run slow.
RAM can be another culprit. 1GB minimum is best.
Hope this helps
Jan 01, 2008 | Microsoft Windows XP Home Edition
Inspiron 1150 Slow startup, slow printing, unable to run 2 programs at once
What Operating System do you run? If it is Windows XP SP2 (Home Edition or professional), here are some things you can do to speed up your system. 1st you should remove all programs that are not required from the start menu. Start > Run > Msconfig > startup tab. Unselect all that are not necessary. Also Right click on my computer > properties > Advanced > Performance settings > Adjust for best performance. This should speed things up a little. I would recommend atleast 512 MB of memory to run Windows XP and its applications decently. You should consider an upgrade.
Dec 20, 2007 | Dell Inspiron 1150 Notebook
Microsoft Windows XP Home Edition Logo
410 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
