I had an empty black ink cartridge and putt a new one in and it does says it is full and the red led light in on solid. No ink comes out when I copy in black and white or when I print in gray scale from the computer. Please help thank you!
-   HELLO I JUST INSTALLED A CANON MX700 - IT PRINTS COLOUR BUT BLACK INK IS NOT PRINTED - DOES NOT PRINT IN BLACK AND WHITE EITHER. PLEASE HELP!!!
-   ranimudaly
Try going into Control Panel and click on printers.
Normal
0
when the next window comes up, Click on MAINTENANCE, the
Properties page will come up and this is where you can do the NOZZLE check/clean and
other functions. The NOXXLE is more than likely clogged from lack of use and needs to be cleaned. It might take several times to clean it. Hope this helps. Bud
Was this helpful?
Yes
No
Popular Solutions for Canon PIXMA MX700 All-In-One
What does 6A80 mean? I JUST got the printer, set it up, loaded the ink cartridges and now that...
(More)
What does 6A80 mean? I JUST got the printer, set it up, loaded the ink cartridges and now that message.
The paper feed source defaults to "Paper Feed Switch" under "Quality and Media"...
(More)
The paper feed source defaults to "Paper Feed Switch" under "Quality and Media" Tab but it always wants to feed from rear tray even when empty and closed. It did not work this way originally! Is there a way to make it default to front tray without having to set manually on every print?
states "Error" Paper output slot - paper is jammed, clear paper and press OK" no...
(More)
states "Error" Paper output slot - paper is jammed, clear paper and press OK" no paper jam in sight. no paper in machine - any ideas?
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
