Question about Sony IT M11 Corded Phone
Sony corded phone IT-B4 wont work!
This beautiful phone worked perfectly for years and then i put it away and used another for a few years. i want to use it now and though its had no knocks or water etc it simply will not give a dial tone or work. i have taken the base panel off and the wiring and board inside looks in perfect order.
i note however that there is a lithium cell in it type CR 2032 which is hard wired into it. i am wondering if this could be "dead" or otherwise be the problem. any ideas gratefullly received. and thanks in advance.
malcolm
5 Suggested Answers
  • 3 Answers
SOURCE: handset
I guess its time to get new batteries
Posted on Jan 01, 2009
Z1G ZA9
  • 122 Answers
SOURCE: Replaced battery in handset. Got a dial tone and all was well. Picked up handset later in the day and it was dead. Unplugged and reattached everything - no luck.
Try taking batteries out, but also unplug base station. The aim is to disperse all power in the phone so that it resets itself. I would leave everything unplugged for 24 hours and then reassemble and see if the problem has gone. Its worked for me loads of times with different electrical appliances. Hope that helps.
Posted on Apr 23, 2009
  • 43 Answers
SOURCE: problem with my handset identifying base phone
I can help you register the handset if it is functional. I am a former Sony Tech.
Hand lotion gets on the keypad and into the back of the rubber keypad. There is a conductive carbon on the back of the keypad to short the circuit board when you press the key. Oil makes it stop working.
Parts are no longer avaliable but you can glue a small piece of alumimum foil on the rubber.
For Register Handset Error email me I will walk you through the steps.
digitalwoodshop@aol.com
AL
Posted on Jul 31, 2009
  • 9 Answers
SOURCE: cannot use with another phone on the line
This sounds like a polarity issue in the new home.
I think you hace red and greed reversed somewhere in the telephone wiring. All greens should go together as all reds. If it is newer wiring the colors will be different, but the same rules apply. example: blue/white and white/blue striped wires will be one pair, it is easy to get then reversed if you are not careful.
Another possibility is there could be two incoming phone lines that are crossed with the red (or blue white) paired with the green (or white blue) from another incoming line.
The 2nd line should be on the black/green (orange/white pair)
Posted on Aug 25, 2011
I need help with my ps2, its about 4 years old, The bulky model. up until a few days ago, it worked perfectly. yesterday it was a bit glitchy, but a few resets fixed it. Today i wanted to play it, so i...
clean the laser using a lazer disc cleaner not only does the disck get dirty but the lazer too when its too dirty it wont read the disc -- disc error
heres a piture of one you get them from electronics shops
Dec 31, 2010 | Sony PlayStation 2 (PS2) Console
Sony Ericsson K800i cant make of recieve calls, and inactive sim!
mikey....not to worry after reading your problem i found it a software problem ......give that phone to your retailer for software formatting and every thing will be ok.
Feb 18, 2010 | Sony Ericsson K800i Cellular Phone
I have a philips 60pp9363 60in that worked beautiful for four years now it just wont power up period. No sound,no picture, no power light, no nothing. and it worked perfect yesterday.
The place to begin is with the fuse----with the set unplugged follow the power cord into the set---there is a fuse on the narrow right board--it can be checked--there are two on that board--one near the cord and another foward--you cannot just look at them--check them like any other fuse.
Sometimes a power surge or outage will take the AC fuse--it is the one right where the power cord comes in.
LET ME KNOW IF YOU NEED HELP OR HAVE ANY QUESTIONS.
sd tech
Oct 31, 2009 | Philips 60PP9363 60" Rear Projection...
Mokick monkey bike 50cc requires piston rings,gudgeon pin,rear light lens where to purchase parts please. This has a v501 engine is anyone out there with advice on restoration parts etc. PLEASE NOTE that I...
www.ebay.com will most likely have everything...try to stay away from china knock offs, get used o.e.m and make sure you find out if the are in perfect working order or not b4 u buy, a few email usually clarifies this... or you could try your local motorcycle junk and salvage yard, they should be listed in your local phone book if there are any in your area
Aug 17, 2009 | 1986 Honda VT 250 F Special Edition
Screen doesn't work. only after sereval attempts
This is a known problem for Razr V3. I had a phone like it with the same problem four years ago... I bought another brand and put the V3 away..three years later the phone works perfectly but I have not used it since three years..only turned it on to see if the screen will come on. Get the phone repaired or buy a new one. this is common on a RAZR
May 28, 2009 | Motorola Mobility RAZR V3
W810i Battery draining quickly .
if motherboard is changed, that is like the engine in a car. your phone should work perfectly, (provided it is a brand new motherboard) and you should have warranty.
Feb 12, 2009 | Sony Ericsson Walkman W810i Cellular Phone
Freezing screen
remove the battery for few minute if it still dont work look in the manuel how to reset normally they put it in the back small push it with a pen hope it work cheers
Jan 18, 2008 | Samsung SGH-d807 Cellular Phone
123 BUTTONS DON'T WORK ON MY SONY ERIKSON K750I
Try putting the phone in a very warm dry place, ay in the "Hot water cupboard" for a day or so and this may drive out any moisture that may be causing the problems, also shake the phone vigorously B4 you do so to try and dislodge any moisture. Or you could try disassembly and wiping the keypad contacts, perhaps there is still moisture there, or maybe it has shorted something else which is why ya gotta dry it out completely.
Jul 14, 2007 | Sony Ericsson K750
Sony IT M11 Corded Phone Logo
342 people viewed this question
Top Sony Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Lands Phone Expert? Answer questions, earn points and help others
