Question about Mitsubishi WD-52327 52" Rear Projection HDTV-Ready Television
Mitsubishi lamp We have a Mitsubishi project tv, and the lamp light was red. We replaced the lamp and cleaned the filter according to the instructions. But the tv still won't turn on, and the lamp light flashes yellow, then goes back to red. What else should we do?
  • MRWELBILT Jan 08, 2009
    where is the lamp driver ballas located on the
    mitsubishi ws52327
    I changed the lamp on my projection tv,
    turn it on, it played for 10 seconds then went off
    showing a yellow light. Don't know what may be
    wrong.
  • 505 Answers
Sometimes the same symptom can be caused by the lamp driver (ballast) failing. Also make sure the lamp door and filter door are fully closed. Unplug for 1 min to reboot. When it turns on, you will hear the fans (airflow sound) and then colorwheel spin up (high pitched) and finally the lamp will fire. If the lamp is bad, you will hear the spark gap make a buzz sound for 1 second.. it will retry a few times before shutting down
Posted on Jan 08, 2009
I have been trouble shooting this with the dealer for two days and here it is:
The TV sensors are very touchy – and it HATES DIRT so if you replaced the LAMP – go back and RE CLEAN THE FILTER and CLEAN OUT THE LAMP COMPARTMENT with a Blower or a Brush, but first turn off the TV for about 15 minutes. I did not clean out the lamp compartment, and the dealer said that the Fans sense the dirt and will not work because of that.
THEN make sure that your screws are replaced back in the holes in the cover plate that have the little errors over them. The cover plate AGAIN is very sensitive to the functioning of the TV. If you don’t believe me – check it out, when the light is blinking yellow on the status button, PRESS ON the filter cover OR the lamp light cover and see if it the light turns off, because that is what the status light is telling you the problem is about per the owners manual.
Well a clean machine is a happy machine – hope this resolves all your problems and saves everyone a lot of heartache!
Just thought I would share –
Posted on May 01, 2009
I have a mitsubishi 1080p wd-65731 just replaced lamp , tv comes on works fine for about 30 minutes and then shuts off , cleaned vents good , has good air flow light that says lamp turns red in the fr
Could be the fan. It will cool tv but could also be to much for tv to handle.
You can also try reseating the lamp. It may say ok but be wrong.
I have a Mitsubishi 5500 projection tv . have had the type of issue you have had and I have replaced a lamp as well.had to reseat the lamp three times before it worked without shutting down.
Hope this helps.
Jan 14, 2015 | Mitsubishi Televison & Video
What's your problem?The tv comes on for 1 second and turns off and the red lamp light is on
Replace the lamp. The red lamp light is indicating an issue with the lamp. You can get the replacement lamp with installation instructions from www.tvrepairworld.com
Oct 19, 2012 | Mitsubishi Televison & Video
Replaced bulb in are mitsubishi (WD-60735) now has yellow light and wont turn on it was not the filter cleaned it need help!!!!!!!
Recheck the the tv safety switch it is not on or a little warp before u put it back and closed the door to the tv projection lamp compartment?Yes,than this tv also have a dead boad that is call the Ballast board,must be replace too.This Ballast board only job are to help to ignite the tv projection lamp only.
Jul 14, 2011 | Mitsubishi WD-60735 Projection Television
I have Mitsubishi WD62525 for the past 5 years. Last week the lamp light came on RED and I replaced it with a newer lamp and the TV still doesn't work. The RED light continues to stay on. Any ideas on what...
check to make sure the lamp cover is pressing the lamp switch in it is at bottom right corner of lamp panel, also make sure lamp is set in properly,another thing to check is the lamp cooling fan panel on right back side,remove and clean filter and replace
Nov 28, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Lamp light is still on after replacing bulb lamp
Try removing the filter cover on left side of chassis and cleaning the filter. I had the dreaded yellow/green blinking light , so I removed and put back the lamp (it was ok) and cleaned the filter screen and the light was out, tv came on...all ok!
Sep 22, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Picture went out completely flashing red status light 4 flashes pause constant
Most likely the lamp is burnt out (indicator goes to constant red status). Replace lamp (get lamp P/N from User Manual for replacement), clean any dirt around lamp, fan, and rear filter. Do NOT get any fingerprints on new lamp.
Aug 11, 2009 | Mitsubishi WD-62825 62" Rear Projection...
I have a MItsubishi Projection TV (Model 52327), and the lamp light was red. We replaced the lamp and cleaned the filter, but the lamp light flashed yellow and then turned back to red. We've put in the...
you have to make sure the door is all the way closed , there is a safety switch on it, and if the door isnt pushing that switch in, it will do that, also, smeetimes when you push the lamp in , it will push the plug inside the tv to the side, take the lamp back out and make sure it is str8
Jan 08, 2009 | Televison & Video
Mitsubishi Wd-52525 HDTV Stutis light constant red
Good Day, barryspiegle.
You and a million others are having this problem. Are you handy? Did you say; yes/kind of?
HERE IS THE SOLUTION FOR THAT PROBLEM AND THE ONES YOU WILL HAVE IN FUTURE:
Replace C81A2,C81A3, C81B3 AND C81B4 (1000uFD, 16 V) On DM PCB.
Replace C8F19, C8F21, C8F22 and C8F27 (1000uFD, 16 V) On FMT PCB.
Replace C9A51, C9A52, C9A61, C9A62 On power PCB.
REPLACE ALL WITH (680uFD, 16V, 105c), part number 181P734030.
Replace C9A37 and C9A38 ON POWER PCB. (3300uFD, 50 V).
Good Luck, big IRISH.
ps; Three boards on left side of TV and about 2.5 to 3 hours of repair time.
Aug 28, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi DLP - model #WD62725
you have mention that after 10-15 seconds T.V starts up, will you give total description of the T.V within that 10-15 seconds?
Aug 11, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52327 52" Rear Projection HDTV-Ready Television Logo
257 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
