Question about Apple Power Mac G4 Desktop
Will not power up
G4 model m8493 had power interupted. Now will not power up.
The power on button/indicator light on the front lights while being pressed but darkens as soon as one stops pressing it.
    Genius:
  • 2,920 Answers
It sounds like one of the boards has shorted out on it. i would take it in and have a diagnostic run on it to see where the problem is but it does sound to me that when the power got interupted you got a surge and shorted something out on one of the boards
Posted on Jan 08, 2009
  • Apple Master
  • 6,487 Answers
This is a power supply problem, if you have a spare power supply that you can connect to this unit try that one so we can check if it will be working fine, lets just hope its not the Motherboard that is bad...
  • Apple Master
  • 19,396 Answers
Unplug it from power for ten minutes, if it does not restart , you need to have power supply replaced.
  • 716 Answers
Unplug Then Press And Hold Off And On For 30 Seconds Then Plug Back In And Retry.
Ibook g4 will not turn on when pushing start button
Check the power source. If there are lights or beeps, they indicate issues. If not, it might be dead.
Jan 30, 2014 | Apple PowerBook G4 Mac Notebook
Power interuption to house temp. power came back but tv won't
The real question if model number indicated here is correct is does the green power light on the set come on at all ?
Aug 29, 2012 | Mitsubishi WS-65513 65" Rear Projection...
Apple mini G4. Trys to power on. The whilte lights blinks every second. Then Shutsdown. Can you help
See if the blinking lights match anything think listed here. http://support.apple.com/kb/HT1547
Usually there will be some sort of sequence to the lights that will give you some indication as to what the error is.
May 10, 2011 | Apple Mac mini G4 Desktop
My Powermac G4 Dual 1.25 machine will not boot any longer. I've removed both hard drives and it still does not turn on. When I push the power button on the front of the machine it lights ups as I push it...
Week or bad power supply, or something shorted
Open the cabinet up and unplug everything off the motherboard except the power button. Leave only one drive connected and disconnect all other drives.
If this works, then plug and power the drives one by one.
Jan 18, 2010 | Apple Power Mac G4 Desktop
I have a quicksilver power mac G4 desktop that has a blinking green light when I turn it on. What should I do?
I assume the light you refer to is the power LED.
No Apple tech repair guide says anything about this LED being able to blink.
It's possible that this is an indication that it is trying to upgrade firmware, especially if it is accompanied by a loud audio tone of about three seconds. I can't say this for sure, because it has never been necessary to activate the firmware upgrade mode on a Quicksilver, since Apple never released any firmware upgrades to it. Firmware upgrade activation is achieved by holding in the power button at startup until the tone is heard. If you are hearing the tone and the power LED is blinking, it may simply indicate that your power button is sticking in.
Dec 27, 2009 | Apple eMac G4 Desktop
Seems like the washer is not getting power. The cord has a big plug with two buttons with little lights. Lights do not go on. I think they did at on point. Is the plug toast or is there some trick or could...
the lights are gcfi circuit interupter indicators you should be able to push them in to reset them if they dont check where you are plugging them in to see if that is causing the problem.
Oct 09, 2009 | McCulloch FH160G Pressure Washer
Lap top can not start even button lights
do static discharge
disconnect battery and all peripherals. disconnect from mains. press power button and hold for 30 sec.
Connect to mains and try to turn on again
If it will not start - mainboard needs replacement
thanx
Sep 14, 2009 | Toshiba Satellite M40-S417TD Notebook
Indicator light says ''pf''
"PF" CODE USUALLY INDICATES A POWER FAILURE CLEAR CONTROL PANEL---RESET, CLOCK, OR TIMERS AND SET TO BAKE 350' IF EVERYTHING RESPONDS O.K. YOUR LIGHTS MAY HAVE BLINKED OR SOME OTHER POWER INTERUPTION
Jun 24, 2009 | Ovens
Powermac g4 will not turn
this is a common problem with G4 Quicksilver. Your power-supply is defect and has to be replaced. I have 4 G4s in my lab with the same symptom: a short flash of the power-button light, sometimes it turns on, but mostly the machine is dead.
Richard
May 07, 2008 | Apple Power Supply 344 Watt PowerMac G4...
Apple Power Mac G4 Desktop Logo
55 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
