Question about Maytag 24 in. MDB8751A Jetclean II Built-in Dishwasher
Dishwasher keeps setting itself to rinse cycle.
My dishwasher's front panel has recently started flashing the nine minute rinse cycle for no obvious reason. No one has touched it, we've turned to leaving the door ajar. Tonight it had hijacked my dishes... we set it for normal wash and moments later it switches to rinse cycle only. I've tried unplugging in an attempt to reset, but to no avail.
5 Suggested Answers
  • 18 Answers
SOURCE: I can't get my dishwasher to start
try pressing normal wash, then heat dry normal wash then heat dry normal wash then heat dry. do it 3 times
Posted on Feb 04, 2007
  • 338 Answers
SOURCE: Maytag Dishwasher Doesn't Start
on a dishwasher an ohmmeter is almost useless. the best way to check is to look for voltage. at the door switch check for voltage to ground on both sides. if you have 120 on both sides of the switch then follow the wire over to the control board. if you have 120 going into the control board and nothing coming out of the control then you nood to start looking for a broken neutral. however the likelyhood that its the control panel may be a better idea especially if you are hitting buttons and nothing happens. try reseating any ribbon cables
Posted on Nov 25, 2008
  • 1632 Answers
SOURCE: dishwasher doesnt drain on wash cycle,ok on rinse cycle
Change the circuit board, timer/progrsmer.
Take it out and clean contacts,
Look for burnt circuit line and solder a fine bead carefully on the circuit board, difficult. Use the pot and pan program.
Vitally
Posted on May 14, 2009
  • 1149 Answers
SOURCE: dish washer \does not rinse good leaves white flim
Hi:
Some things you can do to try to improve your dishwasher's performance:
1) Make sure your dishwasher rinse agent dispenser has rinse agent in it. The filler is usually close to where you put soap in the dishwasher.,
2) Consider switching brands of dishwasher detergent, if you are experiencing problems. Depending on the water condition in your area, certain brands work better than others. Ask your neighbors what works well for them.
3) try different wash cycle's with your dishwasher. Sometimes the economy cycle doesn't work as well as it should.
Posted on Dec 17, 2009
Bosch dishwasher gets stuck at 1 minute
New and highly targeted viral marketing campaigns can instantly place your product, service or brand in front of potential customers. See the best examples of viral marketing videos and social media strategies. Viral Marketing Company Plan Strategies and Resources Viral Shot
Mar 11, 2014 | Bosch 24 in. SGS43C12 Classixx...
Dishwasher motor starts and stops
Hey Bill,
Not professing to be any kind of a dishwasher repairman but I have had a similar issue with the start and stop thing and it turned out to be the timer motor had started to go, and in going it 'burned' a couple of sets of the contacts as well. Check with a local appliance repair centre and see first if they agree with me, and if they have anyone who can rebuild the timer - Typically not too hard to get access to and remove - In my case in Canada, it had to go to Toronto pre-paid but $70 was cheaper then a new dishwasher and it's worked great for years
Feb 09, 2014 | KitchenAid Dishwashers
It is stuck on nine minutes rinse only cycle i will start it at normal wash (2 hrs) and it reverts back to the 9 minute rinse only.. When it is running I cannot cancel the cycle
Hi mlbierman, I have the exact same problem (The 9 minute rinse). Have you been able to resolve it? Will appreciate help. My email is sanjeevnutsATyahooDOTcom
Jan 04, 2011 | Maytag 24 in. MDB7601AWS Stainless Steel...
I used the "rinse only" cycle on the dishwasher a little while ago. I've never used this cycle before. After dinner I tried to start the dishwasher, but no other buttons on the panel respond except the...
Try un-plugging the dishwasher (check for cord under the sink) or turn off the breaker to it to re-set the control board. If this does not resolve your issue you may have a defective key panel.
Jun 18, 2010 | Dishwashers
My dishwasher will start any cycle then half way
The touch pad has gone bad. Common problem with the GE made dishwashers.
May 12, 2010 | Dishwashers
Dishwasher doesnt drain on wash cycle,ok on rinse cycle
Vitally
May 03, 2009 | Maytag MDB7100AWB Dishwasher
Kitchen Aid Dishwasher--model #KUDS01DJ
On mine the "normal" light was the one that was flashing; after a cycling of the breaker switch in the electrical main panel and closing the washer door, it went to a 2 minute rinse before shutdown.
May 17, 2008 | KitchenAid 24 in. KUDP01IL - Multiple...
Jenn-Air dishwasher jdb1100aws problem
I hate to sound like a broken record. But look for my vinegar and CLR fix. In my experience in most cases that works.
Thanks
Kashif. A
Mar 07, 2008 | Jenn-Air 24 in. JDB1100AWS Built-in...
Zanussi ZDT6252 stops 1min into cycle
You need to reset the computer on the bottom. Had the same problem with mine. The Blinking led means the heating element is bad and will not operate.
Dec 30, 2007 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Maytag 24 in. MDB8751A Jetclean II Built-in Dishwasher Logo
44 people viewed this question
Top Maytag Dishwashers Experts
Carmen Mikulic
Mike
Marvin
Marvin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
