Question about E-Machines T6520 PC Desktop
Trying to upgrade RAM - won't boot after new RAM installed
I have the right memory. Trying to go from 1gb to 2gb of RAM. Will not boot after I install memory.
    Scholar:
  • 191 Answers
Install the RAM on memory slot and Switch on your system and go to BIOS settings. There you can check whether your RAM is working properly or not. If it shows no memory installed then the RAM Chip may be damaged.
Posted on Jan 11, 2009
HI I have a Gigabyte motherboard 945GCMX-S2, I have a 1GB ddr2 (667 Hz) hynix ram already installed ..to upgrade it i installed another 1GB dynet ram (666 Hz)..but my cpu beeps now...i remember runni
You should be able to as it can take 4 gig total according to the manual.
Memory:
2 DDRII DIMM memory slots (supports up to 4 GB memory) (Note 2)
Supports dual channel DDRII 667/533 unbuffered DIMMs (Note 3)
Supports 1.8V DDRII DIMMs
Note 2. Only for GA-945GCMX-S2.
Note 3. Only for GA-945GCM-S2.
Feb 06, 2012 | Gigabyte Computers & Internet
Fujitsu v700 4 gb memory will not boot
You don't say if the Notebook is 32 or 64 bit.
If its 32 you may have a problem uprating the RAM more than be handled.
Aug 03, 2017 | Fujitsu LifeBook V700 Notebook 15.4...
Why does memory upgrade for biostar k8m800-mam2 motherboard cause memory error beeps?
I would verify that the memory you're using is actually working properly.
Try to boot to the new stick and see if it works.
If not, it doesn't work.
If it does, you may need to replace the original stick with the same stick that you are trying to use now.
Use this site as a guide.
http://www.crucial.com/store/listparts.aspx?model=K8M800%20Micro%20AM2&Cat=RAM
Dec 22, 2011 | Biostar K8M800 Micro AM2 Motherboard
I have an IBM Netvista A30p that I am trying to upgrade the memory in. It currently has 640mb and I am trying to go to 2GB. I have 2 1GB dimms to install but it will not boot with them. It will not boot...
are the modules of the same brand and type
make sure the sockets and ram modules are dust and corrosion free and are securely seated
you might swap each module over then reboot one might be faulty
RAM
  • Installed Size 256.0 MB / 2.0 GB (max)
  • Technology DDR SDRAM
    hope this helps
  • Nov 17, 2011 | IBM NetVista A30p PC Desktop
    I m trying to upgrade my HP compaq nc6320 RAM MEMORY from 1GB to 4GB, Do i need BIOS upgrade if yes from were i can find the drivers and how can i do it? thanx i am gone wait for respond......
    As far as I know, the machine supports 4GB of ram, so you purchase the ram modules from a pc parts dealer and install them inside the machine, removing the existing ram, there are 2 slots, so you need 2, 2GB cards.
    You do not require any drivers or bios update.
    Windows will need to be upgraded to 64Bit version if you wish to use the full capacity. as normal windows is limited to 3-3.75GB
    Further questions? let me know.
    Sep 01, 2011 | HP Compaq nc6320 Notebook
    I recently purchased Two PNY 1Gb ram to upgrade from original 512mb. When I put both 1Gb ram in the slots, the computer will not boot up. When I take one out and put the original 512 back in with the other...
    I don't know your specific model, but some of the Emachines had some memory directly on the motherboard. With the 1Gb and 512Mb sticks installed, boot the machine and report how much memory the system sees. Perhaps the onboard memory is causing you to exceed the 2Gb limit.
    Please post the memory size you get here with the above sticks.
    Thanks,
    Dan
    May 12, 2011 | E-Machines W6409 (7234) PC Desktop
    Just installed 2 2GB cards (Corsair VS2GB800D2) to replace the 1 1GB card in my emachines EL1200 series. Computer will not boot. replaced the old card and it booted right up.
    Will it boot with only ONE of the 2GB memory-sticks installed?
    Will it boot with ONE of the 2GB memory-sticks AND one of the 1GB memory-sticks?
    Look closely at the 1GB memory-sticks.
    Does the label show 'DDR266' or 'DDR333' or 'DDR400' or 'PC2100' or 'PC2700' or 'PC3200' ?
    Do the 2GB memory-sticks have _identical_ information?
    It's definitely _not_ acceptable to have "slower" RAM (smaller numbers) in the new RAM,
    but it _might_ be acceptable to have "faster" RAM (larger numbers).
    Nov 12, 2010 | E-Machines eMachines Desktop PC
    Having upgraded to 2gb ram on advent 5421 laptop, machine will not boot up with 2gb or re-installed 1gb.
    Just make sure it is an original ram and it must also be the right one. Of course it should boot with 2GB. Also insert the ram properply.
    Mar 09, 2010 | Computers & Internet
    Trying to upgrade memory in a toshiba satellite a105 s1013
    Pls Check this link, in reference to your memory upgrade...it seems that your laptop could only accomodate max 1Gb of RAM
    http://support.gateway.com/s/Mobile/Q106/Magic/5948sp2.shtml
    Feb 14, 2010 | Gateway MX3215 Notebook
    P4m800-m7 Rev:3.1 RAM PROBLEM!
    the problem is with the new ram.
    its phsically damged.
    may be little bit that you cant see it.
    try checking the other 1GB ram.
    Nov 08, 2008 | EliteGroup P4M800-M7 Motherboard
    E-Machines T6520 PC Desktop Logo
    252 people viewed this question
    Top E-Machines Computers & Internet Experts
    Alun Cox
    Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
