I have a MItsubishi Projection TV (Model 52327), and the lamp light was red. We replaced the lamp and cleaned the filter, but the lamp light flashed yellow and then turned back to red. We've put in the cartridge as tightly as possible. What else can we try?
  • 133 Answers
You have to make sure the door is all the way closed , there is a safety switch on it, and if the door isnt pushing that switch in, it will do that, also, smeetimes when you push the lamp in , it will push the plug inside the tv to the side, take the lamp back out and make sure it is str8
Posted on Jan 08, 2009
What is the cause tv turns on about half hour turns off red flash
most likely the lamp. pt# 915P020010
Recommend Phillips, OSRAM, or Mitsubishi original, as others may not work at all or have a very short life.
Mar 17, 2015 | Mitsubishi WD-52327 52" Rear Projection...
Status indicator flashes 3 short times, then one long red flash
Once the status light blinks 3 times, this is an indication that there's a problem with the lamp. The lamp may need a replacement.
If you replace the lamp, but get the same problem, check the inverter board.
If you're not sure where the inverter board is, then you may need to contact a pro for your safety.
Good luck and have a good evening!
Feb 14, 2010 | Mitsubishi WD-52327 52" Rear Projection...
Recently my wd-52327 said it needed new bulb(steady orange light). i had replaced the bulb 7 months earlier and didn't want to see the light so i reset the lamp timer. well the bulb blew the next time i...
If you have a voltage meter you can pull the bulb out and check for continuity by placing the probes on the power plugs of the bulb. If you have continuity the bulb should be good, and it may be the lamp ballast.
Nov 21, 2009 | Mitsubishi WD-52327 52" Rear Projection...
I have had my TV for about 4 years a red light kept flashing saying replace lamp ligh then one day the light blew if I get a lamp light will it fix the problem or is the TV worthless
Lamp, call Mats 1-800-628-1118 Or if you know the part number go to E-bay .For a list of parts and prices Encompass Electronics 1-800-638-3328
Oct 04, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Getting a loud buzzing noise in the rear of my Mitsubishi wd-52327. The sound is coming from the fan area. Originally i thought the fan was bad but after review the fan seems to be working fine. When...
is there a large amount of heat coming from the back? I had a similar issue w/ my tv, and it ended up being the lamp - but a trick that i was able to use to extend the life a little longer was to power the tv off, grab a can of compressed air (can get it anywhere, usually just a buck or two) and blast it right into the vents in the back, cleaning out the dust that accumulates from normal usage. If it is, in fact, the lamp, it's not a tough fix - email me if you have any other questions! Good luck!
Sep 12, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Have problems with mitsu wd-52327
check the current maybe high voltage occur or due to loose connection high amper occur.
Jun 04, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi lamp
Sometimes the same symptom can be caused by the lamp driver (ballast) failing. Also make sure the lamp door and filter door are fully closed. Unplug for 1 min to reboot. When it turns on, you will hear the fans (airflow sound) and then colorwheel spin up (high pitched) and finally the lamp will fire. If the lamp is bad, you will hear the spark gap make a buzz sound for 1 second.. it will retry a few times before shutting down
Jan 08, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Televison & Video Logo
99 people viewed this question
Top Televison & Video Experts
