PC Laptops
Problem for HP PC Laptops
Generic problem for all HP PC Laptops
How to get my webcam works
By robin_ou on Jan 08, 2009
my laptop is dv4-1155se, how to get my webcam works
Solution #1
posted on Jan 08, 2009
Not Rated)
tericrable
Rank: Wiz
Rating: 85%, 27 votes
  1. Press the QuickPlay button (normally located near the display) on the notebook PC to open the QuickPlay application. NOTE: If this takes you to DVDPlay instead of QuickPlay, then you are probably not using an HP Pavilion notebook and you do not have QuickPlay installed. You should skip this test and go to Test the webcam using YouCam instead. Alternately, click Start , type QuickPlay in the search field, and select QuickPlay when it becomes available to open the QuickPlay application.
  2. Click icon, and double-click HP webcam in the Source column. The input from the webcam displays on the screen.
  3. Click Record in the QuickPlay window to record a short webcam file, and then press Stop .
    • By default, the file is saved in a public folder, and the date is used as the name of the video file. For example: C:\Users\Public\Videos\HP Webcam\webcam_20070228_1540.mpg .
    • The saved file can be renamed and moved for use by QuickPlay or other media programs.
  4. Double-click the name of the file in the playlist in the QuickPlay window to view the short Webcam file.
  5. If you can view this file, this concludes this test. You should now test with YouCam.
If you have a third-part webcam, see HP Notebook PCs - Testing a Webcam in Vista with QuickPlay for additional information. Test the webcam using YouCam To verify that the webcam on an HP or Compaq computer that shipped with Microsoft Vista with Service Pack 1 installed is operating properly, perform the following YouCam test. This test verifies that the Webcam is working and can record or play video files.
  1. Click Start , type you in the search field, and select Cyberlink YouCam from the resulting list. After a few seconds the program starts and the webcam image should be visible in the main viewing window.
  2. Click in the main control bar to record a short webcam file, and then press Stop .
    • By default, the file is saved in the Documents folder, in a subfolder named YouCam, with a generic name based on the date. For example: Capture_20080327.wmv
    • To navigate to this folder, click Start , Computer , and then select Documents under Favorites, and then open the YouCam folder.
    • The saved file can be renamed and moved for use by YouCam or other media programs.
  3. Double-click the name of the file in the playlist in the YouCam window to view the short webcam file.
  4. This test verifies that the webcam is working and can record or play video files.
I hope this helps you, I don't have the same operating system. You can find all the information you are looking for at http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01560721&lc=en&dlc=en&cc=us&product=3795310&lang=en#N565
Was this helpful?
Yes
No
Popular Solutions for PC Laptops
Questions and Unsolved Problems for PC Laptops
Answer
How to apply this layout on my account?
Answer
i want to bye the best performance laptop on the market, with the state of the art hardware, 15in... (More)
Answer
I have one notebbok Toshiba Pavillon Pro A210 model with the motherboard broken. Do you have one of... (More)
Answer
my laptop gets extremely hot on the bottom, and also the battery lights are flashing orange??
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Laptop Experts
Top Computer & Laptop Repairmen
in , CA
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
