Question about Vizio P50HDTV10A 50 in. Plasma HDTV
Vizio P50HDTV10A 50 in. HDTV Plasma HDTV Tuner out
The HDTV tuner is out. Analog tuner, and video inputs work fine. Sometimes HDTV tuner comes back on after several hours.
  • mrosalik Jan 20, 2009
    I have a 46 inch doing the same thing. When it first powers up, no DTV. Analog fine. All other inputs fine. Play a DVD and then the DTV tuner warms up and works.
  • jdubb1999 Jan 21, 2009
    Have a Vizio VP50HDTV10A. DTV will not come one. Every once in a while I can get it to come on. However, it is rare.
    Problem Solver:
TV Model P50HDTV10A
Screen Size 50 in.
TV Manufactured Date Jan 1, 2007
Part Type MAIN UNIT
Alternate Part Type SIGNAL BOARD
Part Number 3850-0042-0150(3A)
Alternate Part Number 0171-2272-2163
Posted on Dec 27, 2009
I also have the same problem. Turning on yields no picture on HDTV tuner input, all other inputs work fine. Also, when I have no picture on HDTV tuner input, I am unable to switch to other inputs with the remote, I have to use the button on the side of the set. After a period of time, which varies from minutes to several hours, the HDTV tuner works fine.
Posted on Feb 20, 2010
    Problem Solver:
  • 5 Answers
I've had a Vizio L37 LCD HDTV for about 10 years. After about 5 years the HD tuner crapped out completely, but everything else worked fine. Found a tuner on ebay and installed it after watching a Youtube video. Wasn't too hard at all. Now the tuner is going again. (maybe they only last five years?). So for about $25 bucks you can find one on ebay.
Posted on Jan 05, 2014
I've got the same problem, the digital tuner died. Any solution so far? did you guys try changing the tuner board (ATSC board)?
Let me know please?
Thank you.
Posted on Nov 08, 2011
VP50HDTV10A. THE HDTV TUNER WILL NOT COM ON. ANALOG TUNER,AND VIDIO INPUTS WRK FINE.
Posted on Jan 13, 2010
I turn my tv on and no picture, just snow on screen
your tuner board is not receiveing a signal or not sending it. either way its you siganl board.
You can get get parts for this tv at www.interliquidparts.com
Nov 26, 2011 | Vizio P50HDTV10A 50 in. Plasma HDTV
Vizio VP50 HDTV: I connected an HD antenna for first time on the TV and when I switch to DTV the screen goes blank, remote inoperable. Only controls on side of TV work, but there is no way to do a scan...
I have the exact same problem. It may be the tuner board is bad. I did some research and it seems like this tv is junk. I saw a link that said call Vizio and they are aware of all it's problems and are willing to give a new tv free of charge. I called and they knew nothing about it, but did offer to fix it out of warranty for $285 all problems fixed out the door. Also, TV locks up on RGB input and can't switch inputs until I hooked a computer to the RGB input, then I was able to select a different input.
Please post if you found a solution to the DTV issue..
Jan 26, 2011 | Vizio P50HDTV10A 50 in. Plasma HDTV
My vizio 50 inch plasma tv will not turn on. what
Tries unplug,replug about an hour,see if it reset itself.Not than must replaced the signal tuner board.Plasma have this problems alot.
Jan 08, 2010 | Vizio P50HDTV10A 50 in. Plasma HDTV
My Vizio VW 26L loses all the digital channels when it is turned off. It works fine after a channel scan, but when it is off then back on there are only analog channel available. Bad tuner?
Tries different antena like a roof antena,or digital antena get better amplication input for receptions,still have signal not ur DTV tuner.
Sep 26, 2009 | Vizio VW32L 32 in. LCD HDTV
I have a Vizio 50 Plasma TV. Sound works but display is "noise".
It'll be the X or Y boards or maybe the power board, without checking the VA and VS voltages I can't tell.
Aug 29, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
I can find where to conect my antena cable on a Vizio p50hdm
Your TV is a monitor only. That means it does not have a tuner inside for an antenna. You may try a VCR for a tuner and hook up the antenna to that. Good Luck
Jan 24, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Trys to power up makes Buzz, then nothing but light stays green.
those vizio plasma have a lot of problems, its still most likely the Ysus board, but it will have to be tested to know for sure. If you bought it at coctco you are in luck, if bought a couple of years ago they will give you a full refund. you can try replacing it yourself by checking shopjimmy.com or ebay
Jan 18, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Vizio vp50HDTV10A Plasma Vidio and Audio on and off
Odd problem for this model.
If:
* you are certain the popping is coming from the speakers and
* the video and audio come back on after going out (without reset) then
the issue will be with the main board and will need to be replaced.
Call Vizio customer service, they extend warranties sometimes.
Dec 21, 2008 | Vizio P50HDTV10A 50 in. Plasma HDTV
TV ranking
Hi. You could look up reviews. I personally usually never offer advice on choices, because what I like, may not be what you like..its a matter of personal preference. But in this particular case, I'd go for Panasonic. Why? Better features, better service, easier availability of parts, and better resolution.Plus some nice features. If this answers your question, PLEASE don't forget to rate as fixed. I'd really appreciate it. Enjoy your new tube!!!
Jeff
May 12, 2008 | Vizio P50HDTV10A 50 in. Plasma HDTV
Vizio P50HDTV10A 50 in. Plasma HDTV Logo
1,120 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
