Question about Toshiba 56HM66 56" Projection HDTV
Rainbow line on the top of the screan
I noticed a lite rainbow line at the top of my tv screan. It dont interfer with the picture,but someone said because i had a speaker on the top of the tv set that caused the line to apear. the speaker is from my surround sound and is sealed acording to the speaker. is this true? will it clear or is it now dammaged? Can this be fixed or adjusted?
  • 108 Answers
You most likely have a defective optical engine. these usually become defective around the time the lamp needs to be replaced but not in every case.
Posted on Jan 08, 2009
I have a Dynex 32 LCD that I can only see the top half of the picture, the bottom half/40% looks like rainbow lines. What are the possible problems and how do I fix it.
Unfortunately what you have is a fried screen. Toss it at the city dump and get a new TV. Wallmart has 36 and 45 inch TV's for under 300 dollars
Good luck
Nov 29, 2014 | Dynex DX-LCD32-09 LCD TV
Strange rainbow.reenish type effect
Did you notice any better picture when you play a movie on a DVD player or using a flashdrive on this TV? Is the picture quality better? Or is it the same? Try to check another cable connection or try to play TV channel thru internet. The last option in this case is to show a TV mechanic for he would better understand which part to order.
Jan 20, 2014 | LG 60PZ550 3D Plasma TV
Rainbow colors from bottom of screen to top corners
Check its degaussin posistor. Replace it. This component can be located at the main power regulator section.
Picture of the suspected component attached.
May 23, 2012 | RCA TruFlat 27F520T 27" TV
My son was bouncing a small ball against the screen and then it went to looking like a rainbow. Would this be the picture tube?
He may have caused some type of damage to the picture tube, but usually rainbow effects happen when magnets are present. Perhaps the ball became charged with a large amount of static, which then discharged across the tube, damaging the controlling circuits.
Jun 03, 2010 | Toshiba 36A43 36" TV
Dvd play back has a line from top of screan along
try reinstall converter drivers and software. if persists try to send to repair, maybe a converter board defective.
Jan 16, 2010 | ION Audio VCR 2 PC USB VHS Video to...
Has rainbow lines on tv screen
shadow mask is warped. tv might have been dropped. crt is bad(picture tube). try deguassing it. if you dont know what that is take it to your local service center. the rainbow effect is a magnetic field of some sort. try unplugging and move to a different location. could be a speaker too close to tv.
Nov 12, 2009 | RCA F36650 36" TV
Video distortion
You need to take your tv in and have the picture deflector re-aligned.  This doesn't cost much, My dad had to do that to his a few months ago and it cost 30 bucks.
Mar 21, 2009 | Mitsubishi VS-60705 60" Rear Projection...
Colour lines on samsung tv top side concave
  • Unplug your TV.
  • Leave it unplugged for a minute or two.
  • Plug the TV back in and turn it on.
  • Dec 06, 2008 | Samsung HC-P4363W 43 in. TV/DVD Combo
    Lines on Touch screen
    I know if you use a DS stylus on a DS lite it will mess up the touch screan i dont know what DS you have though and your not suppose to touch the top screan with the stylus. Try reading the DS manual I don't know what to do...
    Nov 16, 2008 | Nintendo DS Console
    Sony FD Trinitron WEGA KV-36HS500 36" TV - Bowed Picture
    it sounds like a convergence adjustment problem. If you hava book on the tv still read it, and it will tell you what to do, other wise, look for a convergence button on the front of your tv, and take the remote and push menu to bring up setup, and go convergence adjustment click it and hit the conv. button on the front of the screen. there should be to lines going vertical and horizontal, these are the limes you adjust with your remote, you have to adjust the red and blue, the tv should blink to let you know which color you are on. when you have them lined up right the line will be perfectly white. hope this helps
    Jan 31, 2007 | Sony FD Trinitron WEGA KV-36HS500 36" TV
    Toshiba 56HM66 56" Projection HDTV Logo
    65 people viewed this question
    Top Toshiba Televison & Video Experts
    Jaime Hernandez
    Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
