Question about RCA HD61LPW42 61" Rear Projection HDTV
New problem... replaced color wheel and lamp still won't work
I wrote prior asking about my RCA 61" rear projection DLP tv model # HD61LPW164. The color wheel was replaced and then we had sound but still no picture. We ordered a new bulb and replaced that and now we are getting no picture still and no sound. When the tv is turned on the light power indicator goes on (blue) and it sounds like the color wheel is winding and then it stops and the light blinks 5x and then it starts up again and the light goes solid and the process repeats. We had the tv apart and 3 or 4 times the lamp came on and then shut off 2 seconds or so after the color wheel stopped spinning. Does anyone know what this means? and if so what part and where to get it for the best price? and we don't have the tv manual anymore but is there a way to find out what the blinking sequence means?
Already put $300 into it and just want to know when to cut our losses.
Thanks so much in advance!
Is it possible to have only the red tint projector lamp replaced on 61" projector Samsung tv
No. This is a DLP TV. It gets it's color by a color wheel. If color seems to drift across screen or there is a loud-ish whining noise from back of TV that you can here clear across a room, then this color wheel may be bad. They wear out.
Jan 07, 2015 | Samsung HLN617W 61" Rear Projection HDTV
Have sound but no video, also makes a high to low pitch noise,light blinks on start and stop switch. Sometimes it will come on if I wait an hour or so.I have changed the lamp. Could this be the color wheel...
Yes sir the problem is the color wheel try to replace it. Remove the lower access panel from the back of the set. To the left of the lamp housing, you see the color wheel. Unplug the two leads and, using the Torx screwdriver, carefully remove the three screws that hold the wheel to the lamp housing. Good day and best regards.
Sep 03, 2011 | RCA HD61LPW164 61" Rear Projection HDTV
I need help with my rca tv
probably bad color wheel. not an easy repair. some of the rca dlp required the light engine be
pulled out to replace color wheel.
Feb 24, 2009 | RCA HD61LPW175 61" Rear Projection HDTV
RCA DLP TV needs color wheel replaced
I used the internet and found others who had the same problem. Two individuals had a brief description on how to replace the color wheel in a DLP TV. Three small torque screws and a ribbon connector was all that was need for removal; once the access panel on the back was opened. I would guess that this process is the same for all DLP TV's, with some small variations!
Nov 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Samsung 61" DLP 3 Blinking lights.
all 3 lights blinking means lamp has a fault the service manual says replace the lamp. If you need the service training manual for that model let me know and I will post the link as the training manual has excellent trouble shooting breakdowns for that model DLP
Mar 26, 2008 | Samsung HLN617W 61" Rear Projection HDTV
61" samsung DLP
The original lamp code number and color wheel part number must match...give me all the # ' s for research = Model # , lamp
numbers,color wheel numbers,etc.
Also, does it "melody" on and " melody" off ?? That is a function
of DMD module = might be defective...............T,
Dec 20, 2007 | Samsung HC-P4752W 47" Rear Projection...
Samsung 61 inch DLP
Needs color wheel. What's the model #?
Oct 27, 2007 | Samsung HLN617W 61" Rear Projection HDTV
No vidio audio ok
Normally the symptom, audio/no video is the DMD. The light needs to be changed. Contact RCA at 866-465-7157 for a servicer in your area.
Jun 02, 2007 | RCA HD61LPW164 61" Rear Projection HDTV
RCA HD61LPW42 61" Rear Projection HDTV Logo
354 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
