Question about liftmaster Chamberlain Garage Door Opener Transmitter 300MC
Door wont sense when shuts.
Will not reverse open only cloes.
  • eric_hughes Jan 12, 2009
    yes
  • Joel Wiedeman May 11, 2010
    Does the motor try to keep running when the door is closed?
  • 16 Answers
Sounds like a limit switch internally is out of adjustment. Check the owners manual. What make and model is it? There may be a manual online.
Posted on Jan 13, 2009
Garage door closes almost all the way and then returns to open. Repeated tries will close door. Replaced both sensors, does same thing.
most garage door openers sense if the door hits something while closing. A sticky track can make the door opener reverse if door doesn't ride on the track smoothly. you may need to grease the track or move door by hand feeling for hard movement.
Dec 20, 2017 | Building Materials
Interior light delay not working
That is normal operation, as long as the door is open the door ajar switch senses that and keeps the interior light(s) on.
Sep 06, 2017 | 2010 Chrysler Town and Country
When I press the button to make the automatic rear door open it comes up halfway and then reverses. What is causing this?
internal problem with the motor causing high resistance or binding hinges or something binding making the motor have to push harder than normal.
May 30, 2011 | 2008 Chevrolet Tahoe
Door keeps opening on our Go video dvd player. we put the dvd in hit close it cloes says loading then opens
try to pull the dvd tray little bit before you close it. Hope this info resolve your Go-Video problem.
Mar 13, 2011 | GoVideo DV2150 DVD VCR
Motor starts runs 4/5 seconds then reverses. & stops where it started. jery l
Check to see if something is stuck on the chain or on the wheels on the door.
I had a similar issue and had to replace the gear drive that stripped itself inside the unit.
Hop up on a ladder and inspect it a little more closly.
Mar 04, 2011 | liftmaster Garage Door 1/2 Hp
Where is the waste toner box on the Kyocera FS-3830N printer?
facing prnter look on left side. midway of side panal theres a door. push tab on door to the rear of printer a bit and door should open. depress plastic tab on neck of toner coleection bottle and pull out full bottle. replace or empty an dreinstall and cloe door. should reset and restart to ready condition.
Feb 07, 2011 | Kyocera Mita FS-3830N Laser Printer
99 camery stereo works but no sound was making crackling sounds in front door speaker when you would open or cloe the door the sound would go off and on now nothing the stereo has no amplafire
Sounds like they took on water in the voice coils and are shot. Pull the speaker out of the door (not to bad) and give the cone a little push if it makes noise it's shot.
Oct 24, 2009 | 2009 Toyota Camry
Door open light stays on when door shut.
sounds like a faulty door switch not sensing that the door is shut. test the switches for continuity to determine the faulty switch
Jan 27, 2009 | KitchenAid KUDS24SE Built-in Dishwasher
Right side french door does not stay closed
I had the same problem - had my local appliance repair shop come by - simple releveling of the unit such that it is tilted slightly back re-establishes things so that the doors will cloe and pull themselves closed. The gaskets are actually magnetized. If the leveling is correct - even upon closing the left door - forcing enough pressure to push open slightly the right side - it will draw itself back in.
Nov 21, 2008 | Jenn-Air JFC2089HE French Door...
Wont start
The lights flash when the door is not shut all the way, or the sensor that detects that the door is shut is not sensing the door is shut. Try pushing in on the door while hitting the start button.
Feb 13, 2007 | Frigidaire 24 in. FDB1051RE Built-in...
liftmaster Chamberlain Garage Door Opener Transmitter 300MC Logo
100 people viewed this question
Top liftmaster Electrical Supplies Experts
Vince Heuser
tamska1102
Level 1 Expert
ray gallant
Are you a liftmaster Electrical Supply Expert? Answer questions, earn points and help others
