Question about Brother IntelliFAX 4100 Laser Fax
Paper Jam every time I try to print
Every single time I print a page, it gets a paper jam. Every single time, without fail. What can I do to fix this?
  • 3 more comments
  • von dutch Jun 01, 2007
    the paper stops just behind the toner cartridge. And when I pull out the paper, the toner smears off.
    There aren't any distinct noises that I notice.
  • von dutch Jun 03, 2007
    any ideas???
  • von dutch Jun 05, 2007
    Any idea where I could get this fixed and how much it might cost?
    Should I just throw it away?
    any idea where I could get this fixed, and how much it could cost?
    Should I just throw it away and get a new one?
  • von dutch Jun 14, 2007
    Well sort of, it is all rippled up when i pull it out.
    Scholar:
  • 77 Answers
Where does the paper stop? Are there any sounds? Are there any marks on the paper? I need a little more information before I can help. Ed
Posted on Jun 01, 2007
  • Edward Paulinski Jun 03, 2007
    Unfortunately is sounds like the rollers are not turning in the fuser unit (the part that gets hot). If that is the case, it is a major disassembly to get to it.
    Sorry I don't have better news for you.
    Ed
  • Edward Paulinski Jun 05, 2007
    If, in fact, the fuser unit is bad, you're looking at about $150 to $200 parts and labor. There is a possibility that that one of two small plastic gears are broken (about $5), however you're still looking at a fair bit of labor.
    I don't know what area you live in, but look around for a shop that is familiar with them.
    One last question. When the paper jams, does it look like an accordion fold? If not, there may be a sensor problem
    Ed
Pick up roller rotates twice even if when gives single page print command and creates paper jam.
I do not know for sure on the Samsung but on HP's this problem is often caused by the pickup solenoid sticking. There is usually a foam bumper on the pickup solenoid which breaks down over time and then the adhesive stops the solenoid from releasing properly. You can clean it off all the old foam and adhesive and run without it, just make printer a little noisier. The solenoid will usually be on the right side.
Aug 30, 2016 | Samsung Ml-1675 Laser Printer 17ppm...
Paper Jam in Duplex mode when printing more than 1 sheet
check between the rollers there will be small bits of paper jammed in that is the reason.
Sep 09, 2008 | Minolta magicolor 2350 Laser Printer
We have a Ricoh Aficio CL3500N and every time we print the paper jams and we get the "Remove Misfeed A: Internal Path". I remove the jam and when it tries to print again we get the same thing,...
There may be an obstruction inside the printer. Try this....remove the paper from the paper tray and put paper in the handfeed tray (front of the machine) If it feeds from that tray it means that the feed rollers in the bottom cassette are worn.
Dec 17, 2010 | Ricoh Aficio CL3500N Laser Printer
Paper stucked inside
Open the top cover.
Pull out the toner / developer units and look for paper under neath.
In the rear, pull open the access door.
remove the paper tray and look for misfed paper.
Dec 12, 2009 | Kyocera Mita FS-820 Laser Printer
It is sying i have a paper jam but there is no paper in it
There are two types of paper jams:
1) A jammed piece of paper at or near a sensor. Or a shred of paper is stuck under a sensor.
2) A paper feed operation that does not send paper into the printer will get reported as a jam it the paper does not reach a sensor in the time that is allotted to reach the sensor. The printer knows that the page is late and suspects a jam occurred prior to the sensor.
To determine if there is a “Pick” problem in the tray, place a mark (line or scribble) on the top sheet in the paper tray. Send a print operation to the printer. If a jam is reported, check the tray. If the marked page is still in the tray then you know the paper pick failed.
There are dozens of reasons for paper to fail to pick. The simplest fix to try is to remove the paper and fan it to remove any possible static charge causing the paper to stick together.
Don
Dec 12, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Paper Jam message on every print job.
I have the same printer without the doc feeder. Check the paper trail thru the printer for the paper sensor lever hanging up. It gets pushed up by the paper and can stick, making the printer think it still has paper in it. Pulling the cart unsticks it till you print again.
Jul 03, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Paper Jam
try a test page..and see if that flows..
Aug 20, 2008 | HP LaserJet 2100 Printer
Paper jam
remove papers fixed in printer than,
service your printer at service center of branded showroom
use quility papers for printing some time low quility paers make your printer donkey,
try to use best for long life span of printer.
THNX
May 16, 2008 | HP PSC 1315 All-In-One InkJet Printer
Brother IntelliFAX 4100 Laser Fax Logo
185 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
