Question about LG 24 in. LDS 5811 Built-in Dishwasher
I have a 1E error code. Water supply is good to the machine. Not sure how to get to the filters. Don't want to break anything.
Ok found the filter in the front of machine, lower left hand corner. It was clean. Proceeded to remove front panel. But first turn of the power and I also turned of the water. Now I found that the wires from the wiring harness had imbedded themselves in the sound profing material. Its like a black thick tar. I guess during the drying cycle the tar heats up and the wires settle into the goo. As the door is opened and closed the wires are put under stress because they are now one with the door. I found a blue wire had broken. I soldered the wire and taped it. I also put waxed paper behind the wires to keep them from hooking up to the tar again. I will check that fix after a couple of months to see how the paper is faring. The machine works perfectly once again.
Posted on Jan 09, 2009
What does lf code mean?
There is only a IE or 1E error code which indicates that the washer is not filling with water. Check to be sure the water supply valves are open. Also, check to be sure the water supply hoses aren't kinked or clogged. Next, remove the hoses from the washing machine and run water into a bucket to test the pressure and flow of the water. If all of these check out and you have good water pressure and flow to the machine, you should replace the water inlet valve.
Mar 25, 2016 | LG Washing Machines
What is the error of 1E
An IE error code signifies that the washing machine is filling with water slowly or not at all. This can occur when water supply taps are not fully open or the water pressure to the tap or house is too low. Other possible causes are kinked, pinched or bent water line hoses, or clogged water inlet filters.
TIP Make sure the water taps are fully open.
Make sure the hoses are not kinked or pinched. (Use caution when moving the washer.)
Clean the inlet filters.
Check another faucet in the house to make sure your household water pressure is adequate
Sep 19, 2015 | Washing Machines
Washer from flashing 1E & leaking
LG Washing Machine Displaying Fault Code IE or 1E WM2016CW WATER INLET ERROR // Water not entering washing machine correctly
The manufacturer has assigned this error or fault code to indicate that the washer is not filling with water. Check to be sure the water supply valves are open. Also, check to be sure the water supply hoses aren't kinked or clogged. Next, remove the hoses from the washing machine and run water into a bucket to test the pressure and flow of the water. If all of these check out and you have good water pressure and flow to the machine, you should replace the water inlet valve.
Aug 02, 2015 | LG WM2016CW Front Load Washer
I have a LG dishwasher that exhibits occasional groaning, 1E error and poor cleaning. Sometime it works fine but lately it's getting more common.
Since you have replaced the water inlet valve and still have the 1E error code, this leads me to believe that your water pressure could be too low.
1E error code means that your machine is not filling with enough water to operate correctly, so check the supply system completely and also the filters where the supply hose enters the machine.
The poor cleaning could be food clogging the lower filter screen, the groaning is the circulation pump cavitating.
Apr 28, 2015 | LG LDS4821ST Stainless Steel 24 in....
I have a LG WD-1018C washer that wont spin out .. it just keep starting and stopping in about 30 second intervals ... an error code has just come up ... 1E ...can you help please ? Steve
The IE or 1E error or fault code indicates that the washer is not filling with water. Check to be sure the water supply valves are open. Also, check to be sure the water supply hoses aren't kinked or clogged. Next, remove the hoses from the washing machine and run water into a bucket to test the pressure and flow of the water. If all of these check out and you have good water pressure and flow to the machine, you should replace the water inlet valve.
Feb 20, 2015 | LG Washing Machines
LD-2040WH
Aug 27, 2014 | LG Dishwashers
HOW to fix E1 code for LG direct drive washing machine
Aug 25, 2014 | LG Washing Machines
It's showing an error message, 1E?
The manufacturer has assigned the 1E error or fault code to indicate that the washer is not filling with water. Check to be sure the water supply valves are open. Also, check to be sure the water supply hoses aren't kinked or clogged. Next, remove the hoses from the washing machine and run water into a bucket to test the pressure and flow of the water. If all of these check out and you have good water pressure and flow to the machine, you should replace the water inlet valve. This is the electrically operated valve that allows water into the machine when required.
Jul 11, 2014 | LG LDF6810ST Stainless Steel Built-in...
LG LDF7811ST 1E code
Are you sure it's 1E and not LE error code??  The symptoms you mentioned indicates that it is an LE error code and the motor has an issue.  You will need to call a qualified LG technician to diagnose and resolve the problem.
Jun 28, 2008 | LG 24 in. LDF 7811 Stainless Steel...
LG 24 in. LDS 5811 Built-in Dishwasher Logo
109 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
