Question about Fisher and Paykel IWL12 Top Load Washer
F&P smart drive
My F&P smart drive takes water and clean. it just started making noise when it drains out. It cleans and finishes the cycles correctly
I called the mechanic he says -pump problem.
Thanks,
Jagdish
  • j_jaiswal Jan 10, 2009
    the problem remains. seems to change the pump. anyways thanks for the information.
    Scholar:
  • 58 Answers
Yes you have issue with the pump most likely you have something stuck inside it you can try to remove the item yourself or see if it clears itself i recommend you try to remove the object. Good luck
Posted on Jan 08, 2009
WHIRLPOOL ADG 6340 ix - At start and during the cycle water drains in pulses and for long time and water intake is in pulses and for long time. The cycle finishes OK but it takes long time, 30 min cycle...
since the water drain is on a float be sure there is no blockage of the screen drain area in the bottem of the dishwasher under the lower rack.the make some cleaner rinses to clean out the screen.
Feb 21, 2014 | Bosch SHX5AL02UC Dishwasher
I have a stackable Kenmore washer and dryer When I start the washer it will fill up and try to start then it will make a beeping noise and drain then it will beep again then stop I tried to switch cycles...
You have a clogged drain line their should be a plastic filter inside the washer located on the main drain line remove the plug clean filter and snake hose if ness. Make sure you have a container to catch water if not drained all the way
Jan 15, 2014 | Washing Machines
Steam coming out of dishwasher
Sounds like the drain hose is partially plugged restricting the water to completely pump out.
Mar 28, 2017 | Dishwashers
Tricity Bendix AW1053W Stuck on cycle 2 (Whites @ 90)
Possible that the drain pump is struck or clogged and does not finish the cycle.
Remove the drain and clean, click this link: drain pump.
Jul 05, 2012 | Washing Machines
Machine gets stuck between rinse ans spin and sits for a while then spins but wont stop, then **** from the in the machine or hose is on the clothes???? Any suggestions? Machine is a top loader smart drive...
You could try a hot load with epsom salts....this will clean out the machine....Make sure it is with hot water. It goes slow in between rinse and spin possibly because it is slow draining...clean out the pump. Also as it FILLS make sure the water runs in properly and not just trickle in making a hissing noise. Good luck. Tony the technician.
Apr 02, 2011 | Fisher and Paykel Washing Machines
1. Too much vibration on spin cycle even on
loud rumbling noise when running, unplug it, take the rear cover off and remove the drive belt. Then turn the inner drum by hand. If there is a grating noise, the bearings will almost certainly need replacing.
drain port take out and give a very good clean with warm water and makes sure all the holes are cleaned right through
Mar 09, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Cycle finishes but water is not draining
Sounds like too much water leftover.
Give me a make and model number of the dishwasher.
Check that the drain hose isn't kinked, and that where the drain connects at the garbage disposal at the sink isn't partially clogged. And, is the garbage disposal clean/clear of food stuff's.
I had a similar thing happen to me a few weeks ago, and it turned out the kitchen sink drain line was clogged.
Dec 16, 2009 | Cars & Trucks
Washer will not spin and finish cycle.
on the lower rhs is a clean out door, use ascrew driver to spin the door loose and clean out the pump behind the door.
Jan 28, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
Dishwasher won't clean properly anymore.
sounds like the hose is clogged... i used to fix these.
first check to make sure the drain inside of the dishwasher (located on the bottom usually towards the back) does not have food clogging the drain. if there is nothing there than its more than likely a hose underneath the dishwasher. make sure you turn the water off before trying to fix this.
Sep 28, 2008 | Dishwashers
Dishwasher not draining
if its new call your dealer its a warranty call
Dec 22, 2007 | Dishwashers
Fisher and Paykel IWL12 Top Load Washer Logo
205 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
