Question about Bosch Nexxt 300 Series WFMC2201UC
END OF CYCLE ALARM
How do i silence the end of wash cycle alarm?
thank you
  • Anonymous Jan 25, 2009
    This noise wakes us up at night an no one anywhere seems to know how to switch the end of wash cycle off. Please can anyone help so I can sleep through the night when using off-peak electricity tariff.
    Problem Solver:
  • 5 Answers
The manual on my Bosch 500 plus 4.2 says to select a cycle and then push and hold two option buttons until you hear the beep to turn off the audible end of cycle alarm. Hope this works for you! P.S. It says not to try this with a load of laundry in the machine.
Posted on Mar 02, 2009
My electrolux washing machine ewf1090 after few mins stopped,, any solution plz??
There is too little information to be able to conclude with certainty what is wrong with the appliance.
I suggest that you first check if is there any alarm?
It is possible to read alarm during normal operation (if exist).
The family of alarms is displayed to the user by a repeating sequence during which the END OF CYCLE LED flashes.
You just count how many times the LED diode "END OF CYCLE" light up. That means family alarm code and than we will be able to give precise diagnosis.
Dado
Sep 25, 2015 | Electrolux Washing Machines
How to silence Whirlpool WED72HED electronic beeps
page 7 of the owners manual tells you to hold cycle signal button down for 3 seconds
Oct 20, 2014 | Washing Machines
Why Does Fault Alarm Beep at End of Cycle?
Check any user friendly ports, filters, screens. It appears that the washer is trying to tell you something. See your manual for troubleshooting. BLEEP BLOOP
Mar 10, 2014 | Haier HDP18PA Stainless Steel...
The noisy alarm on my washer/dryer combo is driving me crazy, is there any way to disable it?
Hello Heather Holley - The signal will sound when the cycle ends and briefly every five minutes as it is a reminder to remove the load. For this purpose, unfortunately the buzzer signal cannot be disable. Most of this brands laundry centers and microwaves are preset to do this.
Dec 29, 2012 | Frigidaire FEX831CS Top Load Stacked...
How do I stop my washing machine door alarm beeping?
do this and fix it. God bless you
However read the instr. manual section troubleshooting /
if doesnot have download from www.fitness.manualsonline.com
The processes below will get most controls unlocked.
Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 15 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 15 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 15 seconds.
Some Models- Press and hold the control lock button for 15 seconds.
If none of these work try unplugging for 5 minutes
Sep 28, 2012 | Hotpoint WMA74 Front Load Washer
End of batt service live
There are 4 possible ways to try and clear the battery timer alarm.
1. Press and hold the fault reset button for 3-5 seconds.
2. Press and hold the fault reset and security key simultaneously for 3-5 seconds.
3. Press and hold the fault and alarm silence buttons simultaneously for 3-5 seconds.
4. Cycle logic power
If this does not work you have to have the factory clear it. This is their way of making extra money.
Oct 04, 2011 | MGE Galaxy 3000 UPS System
Doesnt spin or drain
Sounds like its a pump problem if pump dosent work the rest of the cycle wont either maybe pump belt has come off or has broken hope this helps
Sep 06, 2009 | Kenmore Washing Machines
How to disable the alarm on a Zanussi ZWD16270W1 washing machine i.e. the annoying bleeping at the end of every programme cycle.
To deactivate the audio alarm that denotes the end of the cycle signal carry out the following procedure:
press the left two buttons in the row of three buttons on the front panel for six seconds, carry out the procedure again to reactivate the audio alarm.
(The two buttons are labelled as SPIN and OPTIONS respectively)
Apr 04, 2009 | Washing Machines
Control locked
is any thing on or working check to make sure door is latched
Dec 28, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Error codes
Hello ALARM CODES Alarm code Description of fault User code Effect E11 Problems with water fill in wash phase E10 Cycle PAUSED 8.2 E12 Problems with water fill in drying E10 Cycle PAUSED 8.3 E21 Problems with water drain in wash phase E20 Cycle PAUSED 8.4 E22 Problems with water drain during drying or drying condenser blocked E20 Heating phase skipped 8.5 E31 Analogic (electronic) pressure switch circuit faulty --- Cycle blocked with door closed 8.6 E32 Incorrect calibration of analogic (electronic) pressure switch --- Cycle PAUSED 8.7 E33 Incongruency between level of analogic (electronic) pressure switch and level of anti-boiling pressure switch 1 --- Cycle blocked with door closed 8.8 E34 Incongruency between level of electronic pressure switch and level of anti-boiling pressure switch 2 --- Cycle blocked with door closed 8.9 E35 Water level too high --- Cycle blocked with door closed and water drain 8.10 E36 "Sensing" circuit of anti-boiling pressure switch 1 faulty --- Cycle blocked with door closed 8.11 E37 "Sensing" circuit of anti-boiling pressure switch 2 faulty --- Cycle blocked with door closed 8.11 E38 Pressure chamber blocked --- Heating phase skipped 8.12 E41 Door open E40 Cycle PAUSED 8.13-14 E42 Problems with door closure E40 Cycle PAUSED 8.15-16 E43 TRIAC which powers the door interlock faulty E40 Cycle PAUSED 8.17-18 E44 "Sensing" circuit of door delay interlock faulty --- Cycle blocked 8.19 E45 "Sensing" circuit of door delay interlock triac faulty --- Cycle blocked with door closed 8.19 E51 TRIAC which powers the motor short-circuited --- Cycle blocked with door closed (after 5 attempts) 8.20 E52 No signal from tachometric generator --- Cycle blocked with door closed (after 5 attempts) 8.21-22 E53 "Sensing" circuit of motor TRIAC faulty --- Cycle blocked with door closed 8.23 E54 Relays (motor) contacts faulty --- Cycle blocked with door closed (after 5 attempts) 8.23 E61 Insufficient heating during washing --- Heating phase skipped 8.24 E62 Overheating during washing --- Drain, end of cycle 8.25 E63 Insufficient heating during drying Heating phase skipped 8.26 E64 Overheating during drying --- Heating phase skipped 8.27 E66 Power relay to heating element faulty --- Drain, end of cycle 8.28 E71 NTC wash sensor faulty --- Heating phase skipped 8.29 E72 NTC sensor on drying condenser faulty --- Heating phase skipped 8.30 E73 NTC sensor on drying duct faulty --- Heating phase skipped 8.31 E84 "Sensing" circuit on circulation pump triac faulty --- Drain, end of cycle (door open) 8.32 E85 Circulation pump faulty --- Drain, end of cycle (door open) 8.33 E91 Communications error between main PCB and user interface --- --- 8.34 E93 Configuration error E90 Cycle blocked 8.34 E94 Incorrect configuration of washing cycle E90 Cycle blocked 8.34 EF1 Drain filter blocked LED-EF0 --- 8.35 EF2 Excessive detergent LED-EF0 --- 8.35 Regards David Marsh
May 06, 2007 | Zanussi ZWD1470W Front Load Washer / Dryer
Bosch Nexxt 300 Series WFMC2201UC Logo
3,233 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
