Question about Acer PD525 Multimedia Projector
Changes colors works good for 15 mins. then starts changing colors and shuts down in another 15 mins. put new bulb in and still the same
    Problem Solver:
  • 5 Answers
This is a DLP projection. may be that you have a defective color wheel motor or supply voltage to color wheel motor is out of range.
daniel.acosta@codetel.net.do
Posted on Jan 21, 2009
My Mitsubishi 73 in SDLP works fine for about an hr then turns green and starts jumping. I can turn it off and back on and it's good for about 15 mins. If its off for a while it starts within a hr
Hello. When the picture changes color after warming up, chances are that the color wheel is defective. If you get close enough, you might be able to hear a whining sound. If you do hear a whining sound, you definitely have a bad color wheel. Some color wheels are still available from Mitsubishi. Good luck!
Jul 31, 2016 | Mitsubishi Televison & Video
Just installed new lamp. works for 5 minutes than color starts to fade and shuts down
Did you put Right Bulb in, if so did you touch your fingers on the glass section of bulb because that could knacker them.
For shutting down i would think that is a fan problem.
Apr 06, 2016 | Televison & Video
I am snow bird; printer turned off for 6 months. I shut down properly. Now when doing print nozzel check the top PGBK pattern whole center portion is missing. I have cleande, deep cleaned twice and wiped...
It's manually unclogging.Open the cover and first remove the ink cartridges.Then open the holder and remove the print head.Run hot tap
water and put the print head with the nozzles up to stream water.Hold that 5 mins then turn the print head around with the nozzles down.Hold that for every color of 5 mins.Then put the print head in hot water with the nozzles down.Left it water about 15 mins and then you must very nice to dry.When the print head dry put it in printer and start cleaning.If this not help you need to replace the print head.It's part number is QY6-0062.
Nov 17, 2009 | Canon PIXMA MP960 Printer
Television shuts itself off
i had the same problem with my set shutting off and was told it may be the ballast so i changed that but it still would start up and shut down after a few mins, then i was asked if the bulb had been changed and i had not, so i did change the bulb and have not had it shut down yet. :) (so try a new bulb)
Jun 01, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
52 inch Vivitek rear projection dlp-hdtv
hi ferrari,
changing the bulb isnt going to help. the t.v. is just one big disaster so you might as well rip someone else off just like vivitek has done to all of us. if the new owners tell you theres a problem with the t.v. tell them they must have messed it up during transportation. Thats what vivtek told us. =D
Apr 06, 2009 | Vivitek V37655 56" DLP TV
66 mustang engine running out of fuel
Do you have any of you fuel lines close to the exhaust? (vapor lock)
Mar 24, 2009 | 1966 Ford Mustang
TV shut off after 10 min.
it souds like the cooling fans arent working correctly. if the tv is staying on long enough to warm up and then shutting down i would look at the cooling fans
Jan 29, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Picture loses all normal color & changes to snowy blues & greens
Not sure what causes it but it can be fixxed by your local repair guy, I just had mine fixxed for under a hundred bucks, he takes the back off and with a tiny screw driver adjust a few screws to near brand new perfect picture.. and it has been good ever since
Dec 01, 2008 | LG RU-52SZ30 52" Rear Projection...
Acer PD525 Multimedia Projector Logo
365 people viewed this question
Top Acer Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
