Question about SanDisk 2GB microSD Memory Card
I don't know how to open the sandisk card to insert the smaller one:(
  • 416 Answers
Slide the small card from the rear of the adaptor
Posted on Jan 08, 2009
I just bought a new sandisk 4GB card for my p880 kodak. Wnen inserted the new card camera screen says card is unusable, insert new card. I have followed instructions for formatting on my PC, but still get...
The P880 works with MMC and SD cards. Your new 4GB card is an SDHC card. While it fits into the slot, it is electronically incompatible and will not work. The camera is limited to working with cards 2GB and smaller.
Sep 01, 2011 | Kodak EasyShare Z710 Digital Camera
I have 2gb sandisk memory card i dnt giving password.but appear password plz giving common password.
Hello Ayca,
To Unlock the SanDisk 2GB microSD Memory Card password you will require the Nokia 2690 or Nokia 2700 Classic phone.
Download FE Explorer from the link
Insert card into your phone but don't access it through phone.
Run FExplorer and Open the path C:\system.
You will find a file called mmcstore ,rename the file mmcstore.txt
Copy that file(mmcstore.txt) to your pc and open that file in notepad.
You will find your password in that file to unlock the memory card password.
Also visit :
Jun 06, 2011 | SanDisk 2GB microSD Memory Card
How do i get the data off of a sandisk adapter and on to my computer?
A sandisk adapter does not contain any information at all as it is just an adapter. You need to have a smaller memory card plugged into it because as stated above what your talking about is just an adapter. If you do have the smaller memory card plugged in you just simply open my computer ,after it is plugged in, and open the removable disk drive/folder and then select your data by dragging and highlighting it and right click, copy, and paste the information to wherever you want it.
Apr 30, 2011 | SanDisk 2GB microSD Memory Card
Is Sandisk Ultra 8 GB SDHC card compatible with a Panasonic Lumix DMC-FZ30GN camera? When inserted in Camera error message check card flashes
No. The DMC-FZ30 was designed to work with SD cards. While SDHC cards will fit into the slot, they do not work. You'll have to use SD cards, 2GB and smaller.
Jul 06, 2010 | SanDisk Cameras
Memory card Sandisk 4GB gives error memory card
The S50 uses SD cards. Your 4GB card is actually an SDHC card, and will not work in the S50. You will have to confine your choices to cards 2GB and smaller.
May 15, 2010 | Pentax Optio S50 Digital Camera
After inserting the sandisk into my computer, I get an error message. It says I/O device error. What does this mean?
It usually means that your Input/Output device (e.g. Card Reader either internal or External) is not compatible with your Flash card which is a 'newer' high speed and high capacity medium (OR your Flash card is a new one and has not been formatted). You can check that your card reader is working by inserting a 'standard' (not ULTRA) working lower capacity card (1GB or smaller). Hope it helps: let me know hoe you go.
Apr 03, 2010 | SanDisk ULTRA II 4GB Compact Flash Card...
How to insert MicroSD Multi SD Kit into mobile
our micro sd multi kit will have the smaller micro sd card mounted on the bigger adapter.what you need to do is unlock the micro sd on the side by moving it forward or backward.once you have done that you can take the smaller micro sd card out and this card will fit exactly into the card slot of your mobile phone.
Jan 14, 2010 | Cell Phones
How do you put your sandisk microSDHC card with adapter in your camera
That depends on the camera. If the camera supports Sandisk Micro, then the SD card will fit into a slot. The slot is often located near to the battery.
You will just have to push card in and camera will automatically read card.
If camera does not read the card, ensure that the camera model can support SanDisk Micro, and that it will also support card size. Older cameras do not support big memory card (eg.4Gb)
Sep 05, 2009 | SanDisk 4GB microSDHC Memory Card
Is there a way to clear my sandisk micro card pass code? My son put a pass code on it and now he doesn't remember it. We go into the phone (Nokia 6085) and it gives us an option to change the pass code but...
  1. Insert card into your phone but don’t access it through phone.
  2. Run FExplorer and Open the path C:\system.
  3. You will find a file called mmcstore ,rename the file mmcstore.txt
  4. Copy that file(mmcstore.txt) to your pc and open that file in notepad.
  5. You will find your password in that file.
Aug 12, 2009 | SanDisk 2GB microSD Memory Card
Write protection
There is a small switch on the card. The Sandisk site has a photo of a larger card, smaller cards like the microSD must be inserted into the standard SD adapter.
Jul 16, 2009 | SanDisk 2GB microSD Memory Card
SanDisk 2GB microSD Memory Card Logo
Top SanDisk Electronics - Others Experts
Piyal Perera
Piyal Perera
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
