Question about Ruud UBHC Air Conditioner
Ruud achiever 90 plus gas furnace not turning on
Some time during the day/nite the system will not start heating. No fan no clicks just nothing. The only work around we've found is to cycle the power and it will work for maybe a day or two. I've checked and clean four heat detectors. We've had three or four companies in. The last and most expensive solution to date is to replace the control board. Any one with any back ground on this would be appreciated.
  • Keith Miller
    Keith Miller May 11, 2010
    do you have a volt meter to check 24v at the unit when your tstat is calling for heat between white and ground when unit is not working
  • 61 Answers
Remove and clean the drain trap and make sure the drain tubes are clear.
It sounds like the water may be building up in your drain lines.
Hope this helps.
Posted on Jan 09, 2009
I have a Ruud Achiever 90 Plus Gas Furnace with Air Conditioner. I have a new Nest Thermostat. What is the correct wiring connections on the Furnace?
A Ruud Achiever gas furnace I believe came in a two stage model for heating. What this means is that you will have a high and a low setting. Your furnace should have two wires that control the heating cycle a W1 and W2. This should correspond with the terminals on the nest thermostat. You may run into issues if you do not have enough thermostat wires to control the furnace. If you are ever in the need for Ruud And Rheem Gas Furnaces we offer a great selection online. Shop Natural Gas Furnace. We also have a chat line which can provide technical support.
Dec 26, 2017 | Ruud Heating & Cooling
Achiever 90 plus igniting
be sure the heat anticipater setting on thermosta matches gas valve.
Jan 09, 2014 | Ruud UBHC Air Conditioner
Ruud achiever 90 plus won`t start at times
sounds like you have a heat pump heat pumps dont work below 30* temps you should have some type of backup heat
Feb 05, 2009 | Ruud UBHC Air Conditioner
RUUD Furnace not coming on
the fuse that your refering to is on the control board indie of the furnace. shjould be a 3 amp. good luck.
Jan 30, 2009 | Ruud UBHC Air Conditioner
Ruud achiever 90 plus blower not working
does the furnace ignite?? your system may not have been lighting and has gone into ignition lockout count the codes of the led lights then remove panel led diagnostic codes are listed there.
if led codes indicate no problem verify capacitor is good and that mtr is getting 115 volts.
Sep 15, 2008 | Ruud UBHC Air Conditioner
The door, you mean the metal cover on the front? if you have the door off and push the safety switch in with your hand everything works fine? I need more info here, but if what I said is right, then the "door" isn't making good contact with the switch.
Mar 05, 2008 | Ruud UBHC Air Conditioner
Ruud UBHC Air Conditioner Logo
203 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
