Question about Makita 10" Miter Saw LS1030N
Hi, need to use drop saw. Have used many times, however husband usually around. He has now passed away, and I know this may sound ridiculous, but have plugged in and can't find power switch or catch to release saw from locked position. Can you help?
  • 2,176 Answers
If this is a Makita Mitre saw the switch requires 2 operations to engage. First you should see a round button on handle, you need to depress the button and then pull the trigger. I would recommend doing this with the tool unplugged first so you get the feel for it. Second the release button is on the right hand side of the saw, what you need to do is push down on the saw head some and PULL out on the round pin to release. I would recommend also that you go to Makitatools.com and type in your model number and download a owners manual so you can see exactly how to use the tool. Let me know if you need any more help please.
Posted on Jan 09, 2009
I don't know if I'm still elgible for my safelink ph.
If you are making over a certain amount you will not be eligible. Usually if you are eligible for Medicaid you are eligible for safe link.
Aug 10, 2016 | Cell Phones
I need to know what the best gas chainsaw to purchase is.
hi... my choice would be either a husquvarna or a stihl.. most professionals use one of the two. i happen to on a stihl with a 20" bar and i have never had any trouble out of it even though i got it second hand
Sep 25, 2012 | Husqvarna Garden
My sweeper pump started making a loud noise yesterday , it is still running but the noise is so loud that I can not keep it running long I dont know anything about pools my husband always took care of it...
Thank you for posting your question here on Fixya.com.
I am sorry to hear of your husbands recent passing.
A pump can cause loud noise for several reasons. Some noise is normal with a pump but when it is very noisy it is indicating a potential problem. If the seal is damaged it may whine and then it usually starts to leak(sometimes a seal leak allows water to get into the bearing at the pump end and reduce its lifespan). If the bearings are damages they will make excessive noise before doing other bad things. These are the most common noises indicating a problem.
If I hear one of these whines I usually make a mental note and let the customer know there is a potential issue. I give them the option of letting it go until it either starts to leak or worse or fixing it right away. Sometimes it operates normally for quite a while while other times it fails very soon.
The motor can be replaced in this pump and therefore cost less. If you have a Leslies pool supply store in your area you can take it to them and if they are not busy they usually fix it while you wait if they have all the parts. They usually only charge you for the parts to repair it.
The only problem you may have is removing the pump and reinstalling it. You might want to find a friend, relative or neighbor to help you do these two tasks. If this happens you can see what tools they use and how it is done so you can do similar things later.
If this answer does not resolve your issue, please comment with additional information before rating the answer. Positive feedback is especially appreciated once your problem is solved! Thank you.
Aug 27, 2011 | Pentair Pool & Spa
When sawing against a guide the back of saw moves away from guide can not hold it against it. Also center of blade around arbor gets hot and builds up gum. no looseness in bearing and saw turns free???
hi there
this happens alot with circular saws it usually means that the saw is out of alignment back to front this makes it ******* the tool because your going strait and the tool isnt its fighting it self ******* the motor and whole tool this happens easily setting it down hard throwing it in truck with other tools etc.. the olnly thing you can do to fix this is use solid work bench with tool unplugged lift safety set blade up against the bench then measure front and back from the bench this will tell you if its out of line if so you will need to take it to a tool repair shop to get it fixed
hope i have helped you with your problem thank you have a great day
Aug 20, 2011 | Makita 7 1/4" Circular Saw 5007NB
My husband inherited a Ryobi 9" band saw BS900 when his father passed away. We have no manual and are trying to tighten the blade. Can you help us--he's helping his grand son with a cub scout car.
Tensioning a blade on a band saw usually means moving the upper driven wheel upwards. Remove/open the upper wheel cover and look for the lock bolts and the bolt that will jack the wheel upwards to tighten the blade. Loosen off the lock bolts, tension the blade - it needs to be pretty tight with virtually no sideways movement - and tighten the lock bolts. Replace the covers and lock the covers. Make sure that the wall plug is removed from the socket before you proceed with this operation - band saws know no mercy.
Mar 06, 2011 | Ryobi 9 in. Benchtop Band Saw
Where do i purchase chain saw oil for electric chain saw
Hi
It would be helpful to know where durban is. In most parts of America "Bar Oil" is available at many hardware stores, and certainly at any chain saw dealership.
Oddly enough, many "Green" aware saw operators are now using vegetable oil as a lubricant. So Canola oil, Corn oil, or any other fairly thick, heavy vegetable oil will work fine.
The oil is pumped onto the bar at the top of where it exits the motor housing, and then circulates around the bar. Much of it is lost on the first pass the chain makes through the wood. This is carried away in the chip stream coming out of the cut. On many gas saws, you can see oil being slung off the chain when you rev the motor up.
The green feeling is, all this oil is left where we cut. Are we leaving a biodegradable oil behind? Or a contaminant that will take years to degrade.
See also:
http://www.fs.fed.us/eng/pubs/html/98511316/98511316.html
Stay safe, keep the blade sharp - use the protective gear as directed.
HF
Feb 13, 2010 | Ryobi 18-inch Electric Chainsaw Chain Saws
Can not unlock saw
there is a safety button[usually by thumb area when u grab handle ] on most saws that has to be pressed as well as the switch when using circular saws
Jan 18, 2010 | Saws
Tv started to turn on, but shut itself off,and won't turn back on
Hi t taylor,
I am very sorry to hear of your husbands passing. In the unlikley chance you have the original reciept the service plan number will be printed there.
If no reciept call 1-877-968-6391 and a customer service rep will be able to assist you
If  they are unable to help come back to FixYa and I will help with repair advice.
Please rate this solution.
Lone99star
Mar 03, 2009 | Polaroid TLA-04011C 40 in. LCD TV
I need directions on how to replace my ink cartridge on a HP officejet v40. My husband purchased this printer, but I don't know when, and he has since passed away. The support on the phone wouldn't help...
Hi, normally when you open the printer the ink cartridges will go to the centre and you can unclick the cartridges to replace them. On some printers you need to press a button which brings the cartridges to the centre so you can replace the cartridges.
May 13, 2008 | Office Equipment & Supplies
Playing mp3 files
if that is only a simple/usual reciever then you simply hook your laptop speaker out to any available line in of your receiver like aux, CD, DVD, video aux. but not the phono in please. you are just using the receiver as a simple amplifier for your laptop. is that what you need to know mam?
just post your comment if you have a different query. Regards/Reden
Apr 11, 2008 | Denon AVR 3808Ci Receiver
Makita 10" Miter Saw LS1030N Logo
257 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
