Question about Kenmore 24032\24036 Top Load Washer
I need a free download for a Kenmore 20632990 washer model 111 ser ck 1001761 troubleshooting book.need to replace motor coupling
  • vernon_r_nor Jan 10, 2009
    you help out a great deal.if was not can this site I think I would have to buy another washer.Thank you for your help
  • Kenmore Master
  • 8,220 Answers
Http://appliancejunk.com/forums/index.php?action=downloads;sa=view;id=4
Posted on Jan 08, 2009
  • Dan Webster
    Dan Webster Jan 08, 2009
    A little bit mo:
    http://repair2000.com/coupling.html
    http://appliancejunk.com/motorcoupler.pd...
    http://sites.google.com/site/sublimeappl...
    Bonus stuff:
    Get parts:
    http://www.repairclinic.com/
    http://www.pcappliancerepair.com/
  • Dan Webster
    Wow I was hoping to give you an easier way to access those excellent sites. They are making it hard on me tonight. I have a friend that made a movie. Get the popcorn ready.
Model # 110 20702 991 Serial # CK 5008937 Type 111 Can hear motor running and makes a slight noise also drains but won't engage in washer spin
Hello, Thank You for using FixYa. I will be helping you today.Sounds like a failed motor coupler part number 285753. It connects the motor to the trans. You can lean the unit back to change this part. Remove the pump remove the motor and you will see it.
Thank You and please rate my answer if it was helpful..
Jun 10, 2011 | Kenmore 24932 Top Load Washer
Some times the washer machine will spin and then
sounds like your clutch is slipping,,,,you can put a #10 washer in one of the clutch spring caps and that stops the slipping! thats a low on cash fix or just replace the clutch ,cost about 40 bucks!
Mar 30, 2010 | Kenmore 22422 Top Load Washer
Does this machine have a trap kenmore model# 20632990
See the Sears Parts site for your washer and you should be able to see all of the components.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.20632990+
Also see the Sears site where you can download manuals.
http://www.managemyhome.com/mmh/owner_manuals/search?query=110.20632990
Dec 23, 2009 | Kenmore 24032\24036 Top Load Washer
Model 238322100 ser cm4768086 type 111
Check the following.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
Jun 22, 2009 | Kenmore Washing Machines
Kenmore washer wontt spin or empty. i laid machine on its side
Adjust the motor mount so the pulleys are aligned.
Brute force may be necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 10, 2009 | Kenmore 24032\24036 Top Load Washer
Washer kenmore24032 ser 1001761 m111
sounds like the transmission. take the moter and pump off and manually turn the transmission and see if the tub turns
Apr 07, 2009 | Kenmore 24032\24036 Top Load Washer
All funcions of the washer work except the drain at the end
is your drain hose kinked near the back of the washer. try to look behind the washer without moving it. if the hose is not kinked its probably the pump..
Feb 03, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 ser. washing machine
HI thanks for your question. it sounds like a faulty motor coupling, which is located on the motor and transmission. replace the coupling.
Oct 14, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
555 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
