Question about Arris SURFboard SB4200 Modem
Need program for sb4200 modem how to put new program in to modem
I have comcoast cable i cannot get my modem work reset modem an still will not work
  • Anonymous Jan 21, 2009
    what is the ip address for a 4200 surfboard modem?
    Scholar:
  • 34 Answers
Hello
I can sympathize with the problems you are having with Comcast.  I have had similar ones to yours at my house not too long ago.  Have you called Comcast and had them enable the MAC address of the modem?  If not, give them a call, and they can have you up and running in about 5 minutes.  Depending on the modem, the MAC address will be on a label on the bottom or back of the modem.  Make sure that you have it correctly written, have your Comcast account number, and call them.  If they tell you that you need an appointment, tell them you want it escalated to a tech.  With that address and your account, once you are enabled by Comcast, you should be in business.
Hope this helps you out!
Ken
Posted on Jan 08, 2009
2 Suggested Answers
  • 31 Answers
SOURCE: sb4200 modem not working
The only time you need software for a Motorola SB4200 is if you are using USB. If you use ethernet then it is simply plug and play, no drivers required.
The USB Drivers are here.
http://broadband.motorola.com/consumers/products/SB4200/downloads/v2.4.5_WHQL_Drivers.exe
Good Luck.
Hope this helps.
Please Rate
Posted on Apr 10, 2009
Motorola sb4200 no internet Acess Issue
i click the status and is say Transfer Operational Parameters through TFTPIn Progress
Aug 19, 2012 | Arris SURFboard SB4200 Modem
I have a a motorola SB4200 cable modem. The internet goes pretty fast however the download speed is really slow. Are there any things a could do about it?
That modem is too old to use. Most cable systems have upgraded to DOCSIS 2.0. Yours is not. Call your data support line and ask. It will still work, but very poorly and can be intermittent.
Dec 29, 2010 | Arris SURFboard SB4200 Modem
Sb4200 modem motorola
open the internet explorer2_bing.gif on the addresss bar put 192.168.100.1 then go to hack add on file adress file d11_m_speedtierextreme2_c01.cm
then on ip server file put 68.87.68.35 the press change id then unplug the modem then plug it back the speed should be back
Mar 12, 2010 | Arris SURFboard SB4200 Modem
Modem drops connection. Must disconnect and reconnect to restore
There are plenty of aftermarket Cable Modems for sale at most major retailers (Best Buy, Target, Walmart, etc..)
I would go and buy a decent one of these and try it out to really test to see if the modem is indeed the issue here. If the new one works and doesn't drop the connection anymore then problem solved. If however the new one does do the same thing I would check for proper venting area (make sure you don't have anything on top of or burying your modem) first. If that's fine then it could possibly be issues with your actual line and in that case you'll need to harass the cable company until they actually send someone to test your lines.
May 17, 2009 | Arris SURFboard SB4200 Modem
Slow download speed on motorola SB4200
Jan 17, 2009 | Arris SURFboard SB4200 Modem
Motorola SB4200 Modem IP not working
You can always do the 30-30-30 reset as follows:
  1. When router is powered on, press the reset button and hold for 30 seconds. (Use a paper clip or something sharp)
  2. While holding the reset button pressed, unplug the power of the router and hold the reset button for 30 seconds
  3. While still holding the reset button down, turn on the power to the unit again and hold for another 30 seconds.
This should allow for a full reset of the modem. Once that's done, connect your computer to it with an Ethernet cable to access it's WebUI using the Default Gateway (192.168.100.1), or connect to the WIFI using the default SSID and Password that are usually written on the modem itself.
I hope this works!
Sep 07, 2017 | Arris SURFboard SB4200 Modem
Sb4200 modem not working
Good Luck.
Hope this helps.
Please Rate
Jan 08, 2009 | Arris SURFboard SB4200 Modem
I have a motorola modem sb4200, I have only the power light on
It could be your modem HFC MAC ID is not register with your local cable tv company. You may need to call your cable provider to register your cable modem on their networks.
Sep 24, 2008 | Arris SURFboard SB4200 Modem
Cant get to connect
need to add a dns server address 4.2.2.1 and 4.2.2.2 located in local area conection
Sep 08, 2008 | Arris SURFboard SB4200 Modem
Arris SURFboard SB4200 Modem Logo
597 people viewed this question
Top Arris Computers & Internet Experts
Jerry
Jerry
bobkoure
Level 1 Expert
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
