Question about Toshiba Satellite R25-S3503 Tablet PC
Adding memory i got a toshiba sattelite m45-s165, iwanted to make it 1 gig of ram,so i got 2 stiks of 512..wen i opened the lid,there was only 1 slot for the ram.does that all it has or is there another mem.slot lid somewhere else? if there isnt does that mean i have to buy a 1gig stick? $$$$$$$$$$$$$$$$$$$$$$$$ for ddr
  • abbeezwax Jan 08, 2009
    dont know why i need assistance,its simple thnx
  • 66 Answers
Chek your laptop first if it can accept the 1gig memory. if so then ask the supplier of your 2 pcs 512 memory to replace with 1 pc. 1gig memory. and also ask assistance to replace it.
Posted on Jan 08, 2009
Why only 2 gigs of MEMORY available for APS ON A DIGILAND 10" ANDROID TABLET ANDROID WITH A 16GIG INTERNAL MEMORY? Can I increase it?
The 16gigs is storage. The 2 gigs it is referring to is what programs actually use to do they're thing. These are not the same memory-it is normal. You do not need to do anything.
(even if you added say a 32gig, you would still be operating programs from a 2 gig base.) it's how it works.
Jan 31, 2015 | Tablets & eReaders
How can I ad an additional stick of RAM (2 GB) on my TC4400 tablet? Where the additional slot is? I didn't find it. Thank you, Benjamin
There should be a cover behind the laptop, unscrew these tiny screws and the back cover should open. Then you want to located where the rams are at. In some case the ram slot is already being used by the original rams and you need to take these out to install the new ram. Before hand, make sure your laptop support the correct type of the ram, in your case it will support ddr2 sdram up to 4gb. So pretty much once you locate the ram slot after opening the back panel... then just install it.
Jan 14, 2011 | Compaq tc4400 Tablet PC (RL875AW#ABA)
I want to add RAM to my Toshiba Portege M405-S8003 but I can't find the memory slot. The only things I see underneath my laptop are the battery pack, a square-shaped slot (when I opened it, there's a paper...
Hi,the Ram slot you are looking for is underneath the keyboard,if you have expertise on uncoupling and re-coupling a system then proceed,if not take to a qualified technician to that for you wont take any time.
Jan 01, 2011 | Toshiba Portege M405-S8003 Tablet PC
Can't find ram slot!
There are laptops that do not have two slots for RAM. the EEE Pc's for example only have one slot.
Nov 18, 2009 | Acer TravelMate C302XMi Tablet PC
WHERE IS THE SLOT TO UPLOAD MY 512mb SIMCARD ON MY TOSHIBA LAPTOP
take a closer look left or right side of ur laptop u may find it there
Oct 25, 2009 | Toshiba Portege M400 PPM40U01000E Tablet...
Relating to ram
I am not sure what motherboard you have, but I would suspect that your computer will take at least 2 sticks of 512 MB each.
You didn't say what operating system you are using. If you are using Windows 98, 128 MB is fine. If you are using Windows XP, you should have at least 10x that, or 1GB to run correctly.
You really do need to know how much memory your computer will support, so you can go on the manufacturer's site and look it up or use the manual that came with the computer, if you still have it.
Jun 20, 2009 | Samsung Q1 Tablet PC
Memory upgrade.. toshiba portege 3500
hi..the one of memory located at the lower or under the one slot memory installed..thanks...^_^
May 13, 2009 | Toshiba Portege 3500 Tablet PC
How do I Install my memory in my Toshiba R25-S3503?
ur laptops memory slot is located under the keyboard, u have to carefully remove the thin cover from the top of ur keyboard to reveal the 2 screws, then un screw them to reveal the RAM cover. unscrew the two screws on that to reveal the RAM. be sure to take out ur battery b4 u do this.
Mar 27, 2009 | Toshiba Satellite R25-S3503 Tablet PC
Memory reading
please check RAM its 256 or 512. pick up RAM & change the memory slot.
Sep 17, 2008 | Compaq tc1000 Tablet PC
Startup takes forever.....at least a good 5 minutes
Hi Lynne
You may remove unnecessary startup items by using MSCONFIG utility. You may keep only Toshiba Touchpad utility and Essential security programs. Perform maintenance like using Disk clean up and disk error checking. Also using the performance settings definitely will create significant change. If you need further assistance you may post again I will reply asap.
Good Luck
Oct 18, 2007 | Toshiba Satellite R15-S822 Tablet PC
Toshiba Satellite R25-S3503 Tablet PC Logo
194 people viewed this question
Top Toshiba Tablets & eReaders Experts
micky dee
Alun Cox
Are you a Toshiba Tablet and eReader Expert? Answer questions, earn points and help others
