Question about Car Audio & Video
Hello, I just have a few questions about wiring my new subwoofer.
    Problem Solver:
  • 7 Answers
What is your question on your wirings?
Posted on Jan 08, 2009
Klh powered subwoofer model ASW10-120B... when you plug in to power... it makes a loud buzzing/humming noise
I would check the caps on the power supply. They are rather large electrolytic capacitors that will look like they burst and/or leaking. When these die, the caps ground and the sub will make a loud buzzing sound. If you are handy with a soldering iron you can replace them yourself. Replace them with the same voltage or a little bigger and same with the size.
If the cap. says 16v 4700pF on it, for example, a 20v 5300pF or a 16v 6200mF cap. will work for this application.
Jan 05, 2016 | Audio Players & Recorders
I need to connect wire to my speaker and power but i dont know wire connects to which can u help me find ?
A few variables you left out of your question. What are you hooking up? I can understand speaker wire questions for speakers and subs, but you also asked about a power wire. This indicates an amplifer or radio. If you clarify your question, maybe I can help.
Aug 12, 2011 | Clarion Car Audio & Video
I just installed a new deck but no sounds or feedback from speakers what am I missing
You need to answer a few questions first. Do you have a factory or aftermarket amp? Did you use tape or crimps to attach the harnesses together? Did you use the proper harness? Is the head unit new or used? Check the fuse(s) in the back of the head unit. Then check your wire connections. Check that they are hooked up to the right colors and they are solid.
May 02, 2011 | Kenwood Car Audio & Video
Can i wire one speaker to the other speaker inside the box so that i only have one positive and one negative cable wire coming out out of the box and to the amp
Hello... I can help you with this question. Yes it is possible to do this, but you will have to use a 2 ohm stable mono block amplifier in order to do this. By connecting both positives together and both negatives together, you will be running a 2 ohm load. So if your amp is a monoblock amp, connections will be simple as tieing all the positives together and the negatives together and just hook to the amp. If you are using a 2 channel amplifier that is bridgeable, then you will need to series the subwoofers to an 8 ohm load and then bridge the amplifier to 1 channel. The way you series the subwoofers is take the positive wire in the box and hook to the positive on subwoofer #1. Take the negative wire in the box and hook to the negative on subwoofer #2. Then take a piece of wire and hook the negative from subwoofer #1 to the positive connector on subwoofer #2. Then hook the wires to the amplifier. To bridge the amplifier (if it is a 2 channel bridgeable) would be to use the left positive and the right negative, but check the amplifier for markings to confirm this. If you have any other questions, feel free to let me know and I will help you out! Hope this helps!!
20 year car audio/video installer
Bay manager
Mar 22, 2011 | Kicker 05C104 Car Subwoofer
Subwoofer pre-out wires
Sorry for the stupid question but is your subwoofer a powered sub? The subwoofer out is just a preamped signal that drives a powered subwoofer. Let me know then we can go from there.
Jan 28, 2010 | Audio Players & Recorders
Wiwing question
its for the led light red and green red means in standby position and green means its on
Nov 12, 2009 | JBL S120PII Subwoofer
I am trying to install some L5 kickers 4om and am trying to find out how to do it..
hello, there are many options when wiring in new subwoofers. you need to make sure that your amp is stable on the impeadance you are looking for. just cause the subs are 4 ohms doesnt mean the amp is built to push 4 ohms stable. check the users manual if all matches up take these few things into consideration. typically the lower ohm signal pushed out of the amp is usually the strongest. example if your amp is 1 ohm stable it will deliver more power at 1 ohm than at 4 ohms. a resourcful tool is a website called 12volt.com hope this helps
Jan 04, 2009 | Kicker CVR12 Car Subwoofer
Kenwood vr 615 speaker sound cuts out
it means there is some shorting in the speakers.. check for the shorting
Dec 14, 2008 | Audio Players & Recorders
Connect powered subwoofer
  • If your receiver has a dedicated subwoofer line level output, we recommend connecting your subwoofer to this jack. Most receivers will have just one (mono) subwoofer output, while quite a few subs require two inputs. You can use an RCA "Y" adapter cord , which is a cable with one female RCA jack at one end, and two male RCA plugs at the other. Some receivers require menu settings (such as "sub-on" or "front speakers-small") that must be made before the sub output will be active.
  • Nov 22, 2008 | Audio Players & Recorders
    Have changed car have tuned radio /cd into new car but when radio or cd is playing it cuts out and call comes onto the screen every few minutes
    hello i rang halfords where i bought my cd/radio and they suggested i have a look at the back of my radio in case any loose wires that were not connected to anything were touching the metal of the car and when my husband checked there were 2 so he isolated them and problem solved thanks. margo26
    Jul 28, 2008 | Kenwood Car Audio & Video
    Car Audio & Video Logo
    50 people viewed this question
    Top Car Audio & Video Experts
    xxxxxx xxx
    Are you a Car Audio and Video Expert? Answer questions, earn points and help others
