Question about LG 37LC2D Television
Light blue screen--No picture or sound
Menu will not display on the screen
  • franceshmoor Jan 08, 2009
    Awesome
    You nailed it
    Thanks a lot
    Can you remove both question s for me?
    New Friend:
HAVE YOU GOT LT 32A1 LCD TV PARTS NUMBER GGA10120 MAIN BOARD
Posted on Feb 11, 2016
  • 505 Answers
LGs crash a lot. Try resetting the power (unplug 1 min, replug) and wait about 30 seconds to let it boot up... THEN hit the power button. Hopefully this will fix, if not it probably needs a main board. Try checking all inputs and HD to verify all the parts of the main board. . i can help further..
Posted on Jan 08, 2009
Sony KDL46S4100 when turned on there is no picture just a blue screen
Is this blue screen on all inputs (HDMI, etc.), or just on the one?
Does the remote control work, can you get the menu to display, is there any sound?
If no sound and picture, no menu etc., might be a software problem, the main PCB, or a missing voltage on this board.
Feb 24, 2015 | Sony KDL46S4100 Bravia S Series 46" 1080p...
My Vizio has power, has sound, just no picture. The vizio light does turn blue.
Not sure what model you are talking about, but in general it would be helpful to check the setup menu on the TV. The menu will typically display regardless of the display settings. A factory reset of all the controls may help. (This is in the manual for your model #.) Also check the input cables as well as then input settings in the menu for each input you want to see on the screen.
Jan 15, 2015 | Vizio Televison & Video
LG 37LG30 wont come on. Gives blue light, but screen stays black and no sound
Sounds like the problem could be in the power supply of the TV. Have a technican check for defective capacitors if you're not equipped to do the job yourself.
Apr 22, 2013 | LG 37LG30 37 in. LCD HDTV
Toshiba 32a43 32' picture garbled mess
If you can get the tv to display the blue blackground(usually happens when there is no antenna or cable feed to tv) check to see if the whole screen is a solid blue, if it shows discolored areas around the screen then you might have to "demag" the screen. See if you can rent a demad coil from a tv shop and with tv on turn the coil in circular movements all over the front of screen till blue is solid.good luck!
Aug 03, 2009 | Toshiba 32A43 32" TV
TV lost it's picture...Only have sound
Need more info.
Is blue screen on all inputs, conponent, composit, HDMI, tuner... ect
Do you have MENU is it in color?.
Email me.
Jan 09, 2009 | Samsung Televison & Video
Mitsubushi vs4541 red,blue,green vertical lines no picture,very good sound
Try soldering the vertical output IC, sound without picture usually means vertical output is either defective or has bad solder joints. Does your on screen displays work when you press menu?
Mar 12, 2008 | Mitsubishi WS-48315 48" Rear Projection...
WD-52725
if you get a blue screen than your lamp is working fine. blue screen is considered "video mute" it display that blue if the tv thinks there is no video. try to reset the tv by pressing - menu 123 then reset to system defaults.
Feb 21, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Black screen,no picture just a sound.not even menu bar displays
I had this same issue a year ago and I have it again. I was told it is the light. The company sent me a new one I installed it easily. Worked fine I am not sure why mine died so fast
Sep 09, 2007 | Televison & Video
Blue screen
Your tuner or PLL circuit is blown out. if you have homeowners call the agent. Good Luck
Aug 10, 2006 | Hitachi 43UWX10B 43" Rear Projection...
Televison & Video Logo
411 people viewed this question
Computer Repairing
Computer Repairing
