I got a replacement from dell last week and it doesn't accept a charge. Perhaps my computer isn't charging the battery. What can I do? Is there an adjustment that I can make?
  • gowthamk
    gowthamk May 11, 2010
    can you be more specific on the problem?
  • Randall  Trahan
    Randall Trahan May 11, 2010
    Did Dell send you a new power adapter
  • 46 Answers
Look there is issue with the dell laptop motherboard or get the adapter and battery replaced
Posted on Nov 02, 2009
Laptop will not accept a charge
replace the battery, perhaps you are using the wrong charger, or even charging for too long.
Apr 02, 2014 | Gateway MD2614u Notebook
ASUS K54C won't power from battery
Take it back to shop if it's only 2 weeks old
May 06, 2017 | ASUS Computers & Internet
Laptop dell 1015 not charging showing wattage problems
sounds as if battery needs replaced or perhaps the charger...its one or the other
Jun 07, 2012 | Dell Vostro 1015 Laptop Computer (Intel...
My camera has been plugged into the computer for 24 hours now and the battery still isn't charged. How long does it take to charge and how will i know when it is done charging? i have a Vivicam X029
The manual merely says "a few hours." The LED on the back of the camera lights up while charging and goes off when finished. Not all computer USB ports put out enough current to charge batteries. If you're using a hub, bypass it and connect the camera directly to the port. If that doesn't do it, try another port if available. If that doesn't do it, use the supplied AC adapter and plug it into a wall outlet.
Aug 05, 2011 | Vivitar Cameras
I have had my iphone less than a week- i did not expect it to have problems so soon. .... i have iphone 2g my battery ran out now it wont recharge or turn back on? .... but it doesn't turn on, it...
If your iPhone's battery runs very far down, the iPhone won't turn on. That's because it's using its remaining battery life to preserve your data and settings.So, your iPhone could be refusing to turn on because its battery doesn't have enough juice. In that case, plug your iPhone into a wall charger or into your computer (plug it directly into the computer; some USB ports on keyboards don't have enough power to charge iPhones). Let it sit for 10-20 minutes. If it was low on battery and needed a charge, when it's got enough juice to power the screen, it will turn on and show you its charging status, starting with the red battery icon.During this process, you may also want to make sure there's no lint packed into your cable or the iPhone's dock connector. This isn't a hugely common problem, but a lot of pocket lint could interfere with the iPhone getting a charge.
Jun 28, 2011 | BoxWave Corporation Apple iPhone 2G...
Dell Inspiron 5160 flashing orange / green power LED
If your Dell notebook battery flashes four orange one green, there might be a problem with your battery.The battery life is also shorten and doesn’t last longer than an hour.gets hot sometimes.
pls see this if it helps
http://www.wareprise.com/2007/07/05/dell-notebook-battery-flashes-four-orange-one-green/
This is directly from the User Manual:
If the computer is connected to an electrical outlet, the Battery light operates as follows:
• Solid green: The battery is charging.
• Flashing green: The battery is almost fully charged.
If the computer is running on a battery, the light operates as follows:
• Off: The battery is adequately charged (or the computer is turned off).
• Flashing orange: The battery charge is low.
• Solid orange: The battery charge is critically low.
pls do rate me FIXYA if i helped u
Nov 29, 2008 | Dell Inspiron 5160 Notebook
E280 not charging
You might have to get a new charger--But be careful. If the charger isn't made especially for the Sansa e280 there's the possibility of it messing up the mp3 player itself.
It could also be your computer's USB port. Try using a friend's computer or a different USB port perhaps and see if it works then.
Apr 07, 2008 | SanDisk Sansa E280 MP3 Player
Battery
As you have probably already figured out it sounds like the battery is damaged. Due to the potential fire hazard I would immediately remove the battery even if the laptop is off and discontinue its use until you are certain it is working correctly. Laptop batteries are not safely repairable by users and most technicians. Other than inspecting for bent pins there isn?t much you can do. If the battery is less than a year old you can call Dell, tell them it doesn?t work and see if you can convince them to warranty replace it. Batteries should not become unusable by a normal 3-4 foot drop. If it?s out of warranty I strongly suggest you try to borrow an identical battery to see if it behaves normally, or if that isn?t an option purchase another. Let us know if you have any other questions and please don?t forget to rate this post.
Mar 30, 2007 | Dell Latitude CPX Notebook
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
