Question about Mitsubishi VS-50607 50" Rear Projection Television
Vs-50607 turns off by itself it might come on after about 8hrs
It went a long time between shut offs but now it turns on then right off about 1 second
  • 6 more comments
  • the_green26 Jan 08, 2009
    nothing happens on the screen but the timer light blinks
  • chevy1978420 Jan 22, 2009
    i have the same tv i did what u suggested my code was it blinks twice then a pause and then it blinks 3 times i i thank your thelling me it a “23” ... Horizontal Deflection failure. what is that and what can i do about it
  • vbargerhuff Feb 05, 2009
    I have the same problem
  • jtmcfadden Mar 25, 2009
    I turn the tv on and I hear a couple of clicks inside tv then it turns off in about 1 second. I held the input and menu down to get a code and I got a 12 which means no error but the tv fails to come on.
  • jpdurkin Apr 09, 2009
    I have the same problem mine coded at "24" what dose that mean im not an electronic savy person please help in english lol thankyou
  • Haterestev87 Apr 15, 2009
    we seem to have the “24” ... Vertical Deflection failure problem. please help.
  • henrrp02 Apr 24, 2009
    I also have the same problem and mine codes out at 24, do you have a solution for this?
  • 505 Answers
If you hold menu and input on the front panel it will blink a code to tell you
where the error likely is. hold the buttons for 5 seconds and you'll get a 2
digit error, like 1 2 = no error..
“12” ... indicates no error has occured.
“21” ... X-Ray Protect circuit.
“22” ... Short Protect circuit.
“24” ... Vertical Deflection failure.
let me know what you find.. it will determine area of failure
Posted on Jan 08, 2009
  • thielectronick
    thielectronick Jan 08, 2009
    If it blinks non stop you have a DM board failure.. likely the bad 1000uf capacitors going bad. Depending on design, there are 4 or 8 of them, Mits recommends replacing with 680uf 16v caps. If you have soldering irons and confidence to disassemble and repair, I can assist, otherwise contact you local Mits repair center for about a $200-300 repair..
AFTER TURNING ON TV ,THE GREEN LIGHT COMES ,SOUND STARTS AND THEN TV TURNS OFF ASAP
after tv shuts off press and hold menu and input buttons on tv at same time for about 8 second. power led will start to blink error code 12 ok 22 dead short 23 deflection failore 24 vertical failore. after you know error code have electronic technition repair for you. J.D.W.
Jun 24, 2010 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi Projection TV Model #VS-50603 will not turn on.
The TV is going into a "protect mode", the micro-processor has sensed a circuitry problem and has shut the set down so that no furhter damage can happen, you will need to have the TV serviced by a Mitsubishi tech. Good luck !
Jan 07, 2010 | Mitsubishi VS-50607 50" Rear Projection...
I think Its ********... My cod5 got stuck
faulty power suppl or motherboard. try leaving unplugged for 8hrs. to see if system resets itself
Aug 30, 2009 | Sony PlayStation 3 40GB System
I have a Mitsubishi VS-50607 and it will turn on then off.
This solution fromtroylove solved my problem. troylove11
Rank:wizard_s.gif Wiz
Rating: 85%, 1164 votes
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source.
Jan 03, 2009 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubshi vs50607 picture flickers and after some time shuts off and won't turn on for about 1 half hr.
Bad connections on deflection yolks will cause this prob
kinda tricky to resolder but anyone handy with an iron could do it
Dec 11, 2008 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi rear projection tv model ws-65907
Your problem is in the power supply section,,all the solder there holding the parts is crack or loose already need to resolder so performance will back again.
Jun 19, 2008 | Mitsubishi VS-50607 50" Rear Projection...
The VS 50607 won't turn on.
I'm not sure of the fix, but my manual says the 2-3 error code is due to Horizontal Deflection Failure. Hope this helps. I just uploaded my service manual, it should be available in 24 hours pending fixya's approval.
Oct 30, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Will not turn on
Oct 06, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi VS-50607 Won't Turn On
Sep 25, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi VS-50607 50" Rear Projection Television Logo
309 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
