Question about HP OfficeJet 6110 All-In-One InkJet Printer
Fax and Phone on 1 line
How can I set my all in 1 up so that on one phone line I can both use regularly as a phone line and also automatically receive faxes.? Can the all in 1 do this automatically or is there some add on device I need to buy?
    Scholar:
  • 105 Answers
You have to contact the telephone service provider and subscribe for the distinctive ring pattern service (which may be free of cost also)
Posted on Jan 11, 2009
Receiving faxes whilst connected to a phone line automaticly
Check video for 'fax receive set up' in similar model:
Manual receive: In coming call receives like telephone
Fax/tele: Incoming call rings like telephone if its not fax, if incoming is fax it will entered in fax mode automatically
Automatic: Incoming call converts in fax mode after ring count ends( ring to answer option also avail in fax set up mode rage 1-6 rings)
Fax: Incoming calls straight away converts in to fax mode.( this option only for dedicated fax lines)
Set up your best option as per your requirement.
Nov 29, 2012 | HP LaserJet 3050 All-In-One Printer
Hp officejet 6500 instructions for receiving a fax? Thanks
You can receive faxes automatically or manually. If you turn off the Auto Answer option, you must receive faxes manually. If you turn on the Auto Answer option (the default setting), the device automatically answers incoming calls and receives faxes after the number of rings that are specified by the Rings to Answer setting. (The default Rings to Answer setting is five rings.)
If you receive a legal-size fax and the device is not currently set to use legal-size paper, the device reduces the fax so that it fits on the paper that is loaded. If you have disabled the Automatic Reduction feature, the device prints the fax on two pages.
NOTE: If you are copying a document when a fax arrives, the fax is stored in the
device memory until the copying finishes. This can reduce the number of fax pages stored in memory.
This section contains the following topics:
• Receive a fax manually
• Set up backup fax reception
• Reprint received faxes from memory
• Poll to receive a fax
• Forward faxes to another number
• Set the paper size for received faxes
• Set automatic reduction for incoming faxes
• Block junk fax numbers
• Receive faxes to your computer (Fax to PC and Fax to Mac)
When you are on the phone, the person you are speaking with can send you a fax while you are still connected. This is referred to as manual faxing. Use the instructions in this section to receive a manual fax.
NOTE: You can pick up the handset to talk or listen for fax tones.
You can receive faxes manually from a phone that is:
• Directly connected to the device (on the 2-EXT port)
• On the same phone line, but not directly connected to the device
NOTE: The automatic document feeder must be empty to receive a fax. If there are documents in the ADF, then the device will not be able to receive incoming faxes.
To receive a fax manually
1. Make sure the device is turned on and you have paper loaded in the input tray.
2. Remove any originals from the document feeder tray.
are documents in the document feeder, then receiving the fax will be
unsuccessful.
3. Do one of the following to answer a fax manually:
• Set the Rings to Answer setting to a high number to allow you to answer the
incoming call before the device answers.
• Turn off the Auto Answer setting so that the device does not automatically
answer incoming calls.
4. If you are currently on the phone with the sender, instruct the sender to press Start on their fax machine.
5. When you hear fax tones from a sending fax machine, do the following:
a. Press START FAX Black or START FAX Color on the device control panel.
b. When prompted, select Fax Receive.
NOTE: Depending on your country/region, the device might receive the fax
automatically when you hear fax tones from the sending fax machine.
6. After the device begins to receive the fax, you can hang up the phone or remain on the line. The phone line is silent during fax transmission.
Jan 30, 2011 | HP 1250 Plain Paper Thermal Inkjet Fax
When i receive fax my fax says line error
You configure you fax program.Such as line type,fax number,or you follow user manual,how can use it?
It is problem setup or configure not problem machine.
Dec 03, 2009 | Samsung SCX 4521F All-In-One Laser Printer
How do i set up fax to automaticely receive faxes after several rings
For a phone line dedicated only to the fax machine, the process is as follows:
  1. Press Menu/Set, 0, 1.
  2. You will see the Fax Receive window
  3. Use UP and DOWN arrows to change the setting to FAX ONLY
  4. Press Menu/Set.
  5. Press STOP/EXIT
Your fax machine will now answer every incoming call.
If the fax machine is sharing the phone line with a telephone, repeat the above steps and change from FAX ONLY to FAX/TEL This option will allow you to share the line with a phone only, not an answering machine. Once in FAX/TEL mode, the fax machine will still grab every incoming FAX call, and give a special ring (slightly different than a regular telephone ring) when it's a regular incoming phone call signaling you to answer the phone. I hope this helps with your problem. Best of luck!
Greg
Nov 11, 2009 | Brother IntelliFax-2820 Laser Fax
How do I set fax and phone on one incoming line?
You can't do that automatically on one line unless you ask for distinctive ring from yyour phone provider. Dist. ring gives one pattern for fax and a different ring for regular calls. Otherwise the fax needs to be set to manual and you answer each call and press fax start when you hear fax tones.
Oct 16, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
I have a hp 2200 all-in-one printer. For some
if it sends ok, then it has probably been switched to "manual receive" form "automatic mode"
Apr 21, 2009 | Office Equipment & Supplies
How to receive faxes automatically
First this is a good machine, I use the same one and have my fax setup for the same thing. If you have a (TAD) Telephone Answering Device first you have to set up your phone to pick up before the fax, do this by setting the phone to pick up on three rings and the fax to pick up on four. Go to Menu/Fax/Setup Receive/Ring Delay. While there make sure Easy Receive is on. The machine itself will distinguish between regular calls and facsimiles and will display this info at the time of the call on its LCD screen, make sure you are using the line connection and not the phone connection. Hope this helped.
Jul 01, 2008 | Brother MultiFunction Center MFC-440CN...
I can send a fax ok but cannot receive one Can you help?
You should verify two things:
  1. Is the phone line from the wall plugged into the correct jack on the fax machine. It should be in the one marked as "Line" or "L", NOT the one with the picture of a telephone or the letters"ext".
  2. Is the machine set to automatically receive faxes. These have different modes of reception. "Manual" receive is when the fax will not answer the incoming call unless you tell it to. This is for users who have an answering machine or phone hooked to the same line as their fax. "Auto" receive is when the fax answers the incoming call automatically after a certain number of rings.
If you only have the fax on this line, your fax should be set to auto receive. If you need instruction on how to set that feature, please let me know what the model number is and I'd be happy to provide that info.
If neither of these seem to be your problem, trying testing the phone line with a regular phone to insure there are no line issues.
Hope this helps!
May 21, 2008 | Brother Office Equipment & Supplies
Receiving a fax when using the phone
you can not use the phone simultaneously while sending or receiving a fax. You do not need a separate line. especially if you do not do a lot of faxing. You just can not do both at the same time. You can set your machine to automatically receive faxes when you are not present. The machine will detect the sending tones of the senders fax and automatically receive your fax. You may want to order a users manual from brother to help you set up your fax for your specific needs. Their number is 1-800-284-4357. Another option is you can order the distinctive ring option from your phone company. This will allow you to give out a seperate phone number for your fax while only having one line. The machine can be programed to distinguish the distinctive ring and automatically pick up with out you wondering if it is a fax or phone call. But again you can not talk and fax at the same time. Good luck and let me know if I can be of further help! John
Sep 07, 2007 | Brother FAX-1960C
HP OfficeJet 6110 All-In-One InkJet Printer Logo
Ben Johnson
