Question about Joy Toshiba Satellite M105 S3021 Factory Refurbished Laptop PC - Intel Centrino Core Solo T1300 1.66GHz, (J156-4366) PC Notebook
Memory card problems
Memory card wont start when i insert it on the slot and does not read the information on it, and the light is off
Try a variety of cards to see whether it is just one faulty card, or the internal slot has a problem
Apr 06, 2014 | Janome Memory Craft 10000
Why wont my computer recognize my sandisk memory card anymore
Sometimes it happens that your slot doesn't work you can use a another option like Olympus LS-10 digital recorder as a card reader for accessing the data. Insert the SD card in your LS-10 digital recorder then connect the recorder to the computer with a USB cord then it will show you two options for the onboard storage inherent and one for the SD-Card. Select first photoshop elements to read the card and then Windows Live photo Gallery to view and copy your photos.
If the Information helped you out then please give me some ratings. Thanks
Jun 01, 2012 | Sandisk 4 GB Standard SDHC Card with Rezo...
Samsung C322 is not reading the contents of the memory card. On clicking Menu> My Files, the contents of phone memory is displayed but the contents of the memory card is not displayed. Tried...
Your phone may be not supporting memory card format... or your memory card may be password protected... connect your memory with your PC and format it other file format. how to format memory card, do the following. 1 insert your memory card in card slot of your laptop or card reader or your PC 2. open my computer 3 right click on the memory drive or icon 4 click on format 5 change your file system 6 click start.
After formating insert your card in phone hope it will work for you.
Please do inform about dis, thank you
Apr 21, 2011 | Cell Phones
How to upload photo
Transferring images from a Memory Card to a Windows Computer Follow the steps below to transfer images from a memory card to a computer running Windows. Step one: Insert the memory card Follow the steps below to insert the memory card into the HP All-in-One.
  1. Turn the memory card so that the label faces left, and the contacts are facing your HP All-in-One.
  2. Insert the memory card into the appropriate slot on the HP All-in-One.
    NOTE: Some portable USB flash drives with a read-only partition, such as U3 smart drives, might be incompatible with the front mass-storage port on your HP All-in-One. These read-only partitions are added by the drive manufacturer and may include utilities and other software. Refer to the manufacturer for additional details about your drive. When the memory card is inserted correctly, the Photo light next to the memory card slots begins to blink. The message Reading... appears on the color graphics display. The status light next to the memory card slots blinks green when the card is being accessed. If a memory card is inserted incorrectly, the status light next to the memory card slots blinks amber and the color graphics display shows an error message such as Card is in backwards or Card is not fully inserted. CAUTION: Never attempt to remove a memory card while it is being accessed. Doing so can damage files on the card. Safely remove a card only when the status light next to the slots is not blinking.
Step two: Transfer images without using the HP Photosmart software After inserting the memory card into the HP All-in-One, the memory card appears as a drive on the computer. Follow the steps below to transfer the images on the memory card to the computer.
  1. Press the Photo button to display the Photo menu.
  2. Press the down arrow button (c01133817.jpg ) to select Transfer to computer .
  3. Follow the prompts on the computer to complete the transfer of images.
    NOTE: If there are photo files on the memory card that have never been transferred before, a dialog box on the computer asks whether you want to save the photo files to the computer. Click the Transfer option and all the new photos from the memory card are saved to the computer.By default, the image files are saved in month and year folders depending on when the photos were taken. The folders are created under the C:\Documents and Settings\username\My Documents\My Pictures folder.
Dec 08, 2010 | HP Photosmart 3210 Printer
If you Nokia 5800's memory card is not working.
It simply means there is a problem or two,
1. the phone might not be reading the memory card,
2, the memory card might be faulty.
test to know if it is the phone,
  1. insert the same memory card into another phone to see if the phone will read it.
  2. insert another tested okay memory card into the phone to see if it will work.
  3. if it does not,then the fault is from the phone,
to fix this,
  1. get the appropriate screwdriver,
  2. open the phone,
  3. carefully open the memory card slot,
  4. clean it properly with naphthalene and dry it under the heat of a bulb,
  5. or you can replace the memory card slot completely,
  6. insert the memory card and turn it on to see if it will read it.
  7. before you couple it back together.
To test if it is the memory card
  1. insert the memory card into another phone to see if it will do the read it, if it does not, then the fault is from the memory card.
to fix this
all you have to do is to change the memory card.
take care
Jun 18, 2010 | Nokia 5800 XpressMusic Smartphone
My psp can't read my sony memory stickpro duo, every my psp can't read my sony memory stick pro duo, every time I insert it the light on the LAN showing it in reading process just blink and blink,...
The best way to check if the memory card has the problem or the memory slot is bad is to try a different card and see if the PSP will read it if it reads a different card so the old card is bad but if it wont read a different card the slot is bad and need some repair........
Jan 04, 2010 | Sony PlayStation Portable (PSP) Console
Printer wont read SD cards does read sony memory
If it does not seat (fit) properly, why say the printer will not read SD cards? It certainly will read SD cards that are supported. You can still upload to computer and print from there as you suggested.
Dec 27, 2009 | Canon PIXMA iP6700D InkJet Photo Printer
How to use the memory card reader
To access the memory card reader without using the software provided, follow the steps below. If no card is inserted, the green light on the card reader will be on.
Insert a memory card.
• Insert the card with the brand name label facing up.
• If there is an arrow on the card, make sure it points toward the printer.
• If needed, make sure you connect the memory card to the adapter that came with it before inserting it into
the slot.
Wait for the light located to the right of the slots on the printer to come on. The light blinks to indicate the memory
card is being read or is transmitting data.
• The printer recognizes one memory card at a time. If you insert more than one memory card, a message appears
on the display prompting you to remove all memory cards inserted.
• If a USB flash drive is inserted together with the memory card, a message appears on the display prompting you
to choose which memory device to use.
When reading of images is complete, the number of photos found appears on the display. Then you can make your selection and print. these are the types of memory card supported by you printer.
xD-Picture Card
• Secure Digital (SD)
• Secure Digital High Capacity (SDHC)
• Mini Secure Digital (with adapter)
• Micro Secure Digital (with adapter)
• MultiMedia Card (MMC)
• Reduced Size MultiMedia Card (with adapter)
• MultiMedia Card mobile (with adapter)
• Memory Stick (MS)
• Memory Stick PRO
• Memory Stick Duo (with adapter) or Memory Stick Duo PRO (with adapter)
Mar 18, 2009 | Lexmark X5495 All-in-One &USB...
I have a memory Stick PRO Duo 4GB
YEAH, YOU MAY NEED A MEMORY CARD READER to read your memory stick. because some compters have not all type of card slots. the card reader will solve your problem.
Feb 10, 2009 | Sony 4GB Memory Stick PRO Duo Memory Card
Memory card
Dear Starrr63,
I think the slot where you insert the memory card has been damaged or it doesn't make contact with memory stick. See inside slot in good light, hope you will find damage/tilted pins there.
May 25, 2008 | Sony Cyber-Shot DSC-F505V Digital Camera
Joy Toshiba Satellite M105 S3021 Factory Refurbished Laptop PC - Intel Centrino Core Solo T1300 1.66GHz, (J156-4366) PC Notebook Logo
71 people viewed this question
Top Joy Computers & Internet Experts
john h
Andrew Taylor
Andrew Taylor
Are you a Joy Computer and Internet Expert? Answer questions, earn points and help others
