Question about Samsung YP-U3 MP3 Player
When i put the usb in the computer it doesnt connect
It says connecting but then after a while it says "disconnected and than it says charging
it wont let me sync songs n it doesnt even connect to my somputer....
  • 2 more comments
  • chechuz Jan 11, 2009
    i have the same probzz
  • Anonymous Jan 12, 2009
    it doesn't connect when pulg in usb.
  • Anonymous Feb 27, 2009
    wen
  • Anonymous Feb 28, 2009
    Have a new computer and want to down load songs to my mp3 player.
    when i plug in the mp3 player it says its connecting then disconnects then charges.
I would suggest that first you make sure that your computer is updated with Service Pack 2 or 3, DirectX9 or higher, and Windows Media Player 10 or higher. To do this, I went to Start -- Control Panel -- Windows Update. Then downloaded and installed all updates as required.
Secondly, I downloaded the codec for the portable device. To do this I pluged the MP3 Player into the USB port (still not recognised), went to Start -- Control Panel -- Printers and Other Hardware -- Add Hardware and this prompted the Hardware wizard. Clicked "Next" and selected YP-U3 from the list. Then selected "Install Automatically" and Voila! The codec was downloaded and the portable was recognised.
Posted on Jan 12, 2009
My sony nwz-s638f is not charging if i put it in the plug how can i make it work?
Please make sure that the Computer is recognizing the Walkman when connected to the USB port.
Make sure that you're using the supplied USB cable for connecting to the Computer.
If you use the portable player for the first time, if you have not used it for a long time, or the battery is depleted, it may take up to 5 minutes for it to be recognized or start charging. On models with a display, the display will remain blank. If it the portable player is not recognized or does not begin to charge after waiting 5 minutes, reset the player by pressing the reset button.
Disconnect the USB cable from the portable player and then reconnect.
Check the connection status again.
Disconnect the USB cable from the computer and then reconnect.
Check for available space on the player using Windows Media Player or My Computer.
Restart the computer.
Check that the USB cable is firmly connected to both the computer and the player.
If the player is connected to a USB hub, disconnect it and connect it directly to the computer with a dedicated USB cable.
If the player is still not recognized by the computer, disconnect all devices connected to the computer with a USB connection and restart the computer.
After the computer restarts, connect only the Walkman player and test the connection again.
If the player is still not charged by the computer, try a different USB port.
Thanks for using FixYa.
May 05, 2011 | Sony NWZS638F Digital Media Player
My camera needs to be charged and i have lost the battery charger. so i put my camera on the usb cord and into the computer and tried to turn it on but it wont work.
You don't say what model camera it is, so I am going to have to do some guessing. If your battery charger normally charges the battery in the camera, then it probably will charge when connected to the computer by the USB lead. However, some cameras require the battery to be taken out and charged in an external charger. If that is the case with yours, then it probably won't charge by connecting to the computer.
It is normal for a camera connected to a computer via the USB lead to go into a kind of passive mode, just acting as an external disk drive so that files can be transferred, so not being able to turn the camera on while it is so connected might be normal. However, if you mean that you left it connected for awhile to charge up, but it wouldn't turn on after you disconnected it, then it is obvious that it cannot be charged up that way.
Oct 20, 2010 | Sanyo Cameras
Cliq wont charge
Replace the data cord and try to connect it will work
Dec 05, 2017 | Motorola Mobility CLIQ Cell Phone
Cannot charge
SONY NWZ-E436F DIGITAL media player | PROBLEM : my battery was low So i tried charging it by connecting the usb to my computer...it charges for 3-4 seconds till the time it shows do not disconnect the moment it shows connecting it shows the battery sign full.... i tried it again and now it has hung and i try to put it on it just shows every moment has its music...and the battery is still low i believe it doesnt go further
Jun 25, 2009 | Sony Audio Players & Recorders
My mp3 doesnt connect into my usb it just disconnects and starts to charge can you help me
I assume from your description that either you are running a version of Windows older than XP/2000 or you need a special driver. Here is a link for the driver(s) you will need. Just enter your model number and select your version of Windows. Download and run the file and you should be up and running shortly.
May 30, 2009 | Samsung YP-U3 MP3 Player
My ipod shuffle wont play music
It won't play music while connected to computer, that's for sure. It only plays when it's disconnected from the wall charger and computer.
The songs could be in the wrong format
AAC is iTunes native format
Mp3 generally works
WMA is iffy - only unprotected (non-DRM) files will work
Streaming songs won't work
-Tha Mp3 Doctor
Aug 29, 2008 | Apple iPod shuffle Second Gen. Silver (1...
File transfer to computer sony ericsson w580I
update ur phone tru the SE website, then reload the software on ur comp..try connecting with the usb, follow wizard, and once u r connected, while disconnecting eject properly as the manual tells u to..All the best
Happy to help
Have a nice day!
tc
Jun 03, 2008 | Sony Ericsson Walkman W810i Cellular Phone
Samsung YP-U3 MP3 Player Logo
128 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
