Question about Sharp Notevision PG-A10S Multimedia Projector
Green screen in the middle
I have a Sharp PG-A10s proyector with 65% life on the lamp I adjusted all the colors, tint, etc. and the movie showing is green and only the corners are the right color the rest remains greenish any ideas of what this could be? Thanks. Julio v Phoenix Az.
    Problem Solver:
  • 14 Answers
Check the Fly-Eye lens and the RGB panels.
Posted on Jun 04, 2007
SOURCE:
Yellow circle on sharp pg-d210u projector
1,white spots appeared on screen,means the DMD chip is broken,you need a new DMD chip.
we supply the new DMD chip,it's life is 6 years,
and the price is USD190
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Apr 04, 2014 | Sharp (BQC-XGNV2U//1) Projector Lamp for...
Hi guys! Have a Sharp PG-A10S projector problem. Projector (unfortunately) was recently dropped and power supply was affected. Had that fixed but now projection is all yellow (though it depicts the montior...
go into the menu and reset to factory default settings. if that does not help, you have a bad polerizer (light color filter) on one of the lcd panels. sharp will sell the individual parts if you want to fix it yourself. if you want them to do it, they'll replace the entire optical engine and charge you a fortune.
Sep 02, 2009 | Sharp Notevision PG-A10S Multimedia...
Cannot adjust color
Have you turned the controls from one of the presets? Presets are Vivid, Movie, etc. Most sets have to be in Custom or Customize to adjust the controls, likely on-screen with one of contrast, brightness, color, or tint selected. If those are horizontal bars then up/down selects which and right/left select decrease/increase or red/green for tint. Start with 50% if no reset (0% for R/G) or start with the non-Vivid settings. Consult AVS forums for you model to get better settings. Rules of thumb: Brightness should be as dark as possible without losing gray scale at lowest part. Contrast should not be so high that whites bloom or make it hard to see. Color should not blow out any color nor be unnatural. Tint is best judged on flesh tones. -Ken
Jul 15, 2009 | Insignia NS-L32Q-10A 32 in. HD-Ready LCD...
Color
see if there is a "default" option, if not set everything back to the middle, if the colors are still off you sure its not the convergence?
most big screens allow you to change "color temperature" it's like a default adjustment for 3 different brightness levels.... ie...COOL, WARM picture will show obvious changes in brightness
Apr 24, 2009 | Philips 50P8341 50" Rear Projection...
I inherited a Sharp XG-NV2U LCD projector. When I turn it on I get a blue screen with a blurry white square in the middle, which I assume is the menu. Have adjusted focus but doesn't change. Any...
lcd panel or palarizer is failed
Have a nice day!
Jerry
Lampdeng Limited
Mar 28, 2009 | Sharp (BQC-XGNV2U//1) Projector Lamp for...
Green color
reset all color settings from the unit's menu.
disconnect any source and turn off the unit
turn on the unit and wait for the manufacturers logo to show up (and it must be BLUE).
not blue ? reseat the lamp. replace lamp if it doesn't work.
Nov 21, 2008 | Epson Powerlight 8300NL Multimedia...
Blue colors appear greenish in middle third of screen...there is a circle of yellowish green in the center of the screen
You have a bad optical block, the block has a 2 year warrnty but you will have to pay labor to have a tech change it
Aug 08, 2008 | Sony KDF-E50A10 50 in. LCD HDTV
Projection tv has a reddish tint on the screen and appears to look hazy and flushed. Flesh tones have a red/orange hue.
first try adjusting the color-tint on the menu if this does not solves the problem you have a failing proyector and has to be replaced
Apr 03, 2008 | Televison & Video
Color Turns Green
HI PLEASE ADJUST THE SCREEN CONTROL OF UR TELEVESION SET IT IS INSIDE THE TV..IF U KNOW THE SCREEN CONTROL IN THE SET THAN MAKE IT LITTLE ANTICLOCKWISE.AND THE SET WILL BE OK..
May 13, 2007 | Sharp 27H-S60 TV
Sharp Notevision PG-A10S Multimedia Projector Logo
235 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
