Question about Intel DG31PR Motherboard
DG31PR Won't Boot
Equipment is as follows:
MB: Intel DG31PR brand new
CPU: Intel E2200 2.2GHz brand new
RAM: Two Adata 512MB PC800 DDR2 DIMMS
PSU: Antec BP500U 500 watt
HDD: Sata 500GB not sure of the brand
Video: NVIDA GeForce 7300GT
Problem:
My computer died and wouldn't boot. I replaced the PSU but had same problem. I replaced the MB, CPU, and CPU fan but still get same problem. When I switch the computer on the 5v SB_PWR (standby power) LED comes on, but nothing else. I can see one of my fans twitch but that's it. Nothing else happens. I have tested both the old and new power supplies and both work. I have tested the case switch and it is working properly. I'm assuming it is the MB but what are the odds of the old one being going bad and the new one DOA? Also, if the MB was bad would that standby power LED light up? Thanks for the help?
  • Doctor PC
    Doctor PC Dec 21, 2011
    A new CPU or the old one? This sound that is the probm.
  • 416 Answers
You ight have a BAD CPU, try checking it out on another pc or friends pc.
Posted on Jan 08, 2009
How to install 4 gig ram on EMachine 3611
You cannot. See table below.
eMachines W3611 RAM Specifications
Standard Memory 512 MB (removable) Maximum Memory 2.0 GB Memory Expansion 2 sockets Memory Comments PC2-4200 DDR2 SDRAM DIMMs. Supports Dual Channel DDR2. CPU Type 3.0GHz Intel Pentium 4 631 Model Comments 800MHz FSB, Intel 945G Chipset
Jun 09, 2014 | Computers & Internet
Whenever i start my system, it is taking much time to start, mine is windows xp2 o.s. and D945GCL drivers. pls solve the problem
Hi, you can download drivers from here:
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%c2%ae+945+Express+Chipset+Family+Boards&ProductProduct=Intel%c2%ae+Desktop+Board+D945GCL
My guess is that you have to add more memory to your system
look for this type of ram:
  • 1.8 V (only) DDR2 RAM DIMMs with gold-plated contacts
  • Unbuffered, single-sided or double-sided DIMMs with the following restriction: Double-sided DIMMs with x16 organization are not supported.
  • 4 GB maximum total system memory
  • Minimum total system memory: 128 MB
  • Non-ECC DIMMs
  • Serial Presence Detect
  • DDR2 667, DDR2 533 or DDR2 400 MHz RAM DIMMs
Hope this will help you to tune up your system.
Aug 21, 2011 | Intel D945GCL Motherboard
I have intel(R)pentium(R)4cpu 3.00GHz(2cpu) & intelD945GCR motherboard & 512mb DDR2 ram this is my pc , this will be work slow for me how will reduce this problum i think do some cheanges in...
You can install a total of 2Gb or 4Gb RAM on this motherboard.
The specifications for the RAM are as follows -
Memory
• Two 240-pin DDR2 SDRAM Dual Inline Memory Module (DIMM) sockets
• Support for DDR2 533 or DDR2 400 MHz DIMMs
• Support for up to 4 GB of system memory
May 13, 2011 | Intel D945GCCR Motherboard
Will my motherboard(D945GCNL) support 4 GB RAM?
No. The maximum that your motherboard will support is 2 GBs of RAM. 1 GB on each slot. Refer to this link: http://www.crucial.com/store/listparts.aspx?model=D945GCNL
Apr 11, 2011 | Intel D945GCNL Motherboard
Known good processor listed on HCL Known good memory listed on HCL Powers on No video
3.80 GHz800 MHz 2 MB pentiam 4
3.60 GHz 800 MHz 2x2 MB for D processer
RAM
1.8 V (only) DDR2 SDRAM DIMMs with gold-plated contacts
8 GB maximum total system memory using DDR2 667 or DDR2 533 DIMMs
4 GB maximum total system memory using DDR2 800 DIMMs
Minimum total system memory: 512 MB
Non-ECC DIMMs
DDR2 800, DDR2 667, or DDR2 533 MHz SDRAM DIMMs
Or follow the link
http://www.intel.com/support/motherboards/desktop/dg965ot/sb/CS-026605.htm
Hope this helps.
Shibuda,
If you are helped you can rate on the 4 thumbs and leave a short comment,because,
this is the free side and I can get the chance, to help people like you .
Jan 18, 2011 | Intel DG965OT Motherboard
Hi I have intel motherboard D945GCNL with Dynet 1 GB ram installed. I boght a new Dynet 1gb ram and installed it. After that, my cpu began beeping.So I removed the ram and interchanged the rams.It doesn't...
Your RAM needs to be:
  • DDR2 667, DDR2 533 or DDR2 400 MHz SDRAM DIMMs
  • Non-ECC DIMMs
  • 2 GB maximum total system memory
  • Unbuffered, single-sided or double-sided DIMMs with the following restriction: double-sided DIMMs with x16 organization are not supported
  • Make sure the New RAM is not bad.
    Ensure that the new RAM is the same type as your old one (DDR2 XXX)
    Install the old one back and make sure that your PC works.
    If it does, Take the Old RAM out and install the New RAM in the same slot as the old one.
    If the PC does not work with the new one, It is more than likely a bad stick of RAM
    Hope this helps
    Dec 20, 2010 | Intel D945GCNL Motherboard
    I want to upgrade my system ram size to 2gb...my system memory configuration as follows mother board: intel102ggc2 system bus speed :800mhz processor (p4):3.0ghz ram slots available:2 and presently i'm...
    The below is the contents of Intel published for your board
    Intel Desktop Board D102GGC2 Technical Product Specification
    System Memory The board has two 240-pin DIMM sockets and supports the following memory features: • 1.8 V (only) DDR2 SDRAM DIMMs with gold-plated contacts • Unbuffered, single-sided or double-sided DIMMs with the following restriction: Double-sided DIMMS with x16 organization are not supported. • 2 GB maximum total system memory. • Minimum total system memory: 128 MB • Non-ECC DIMMs • Serial Presence Detect • DDR2 533 or DDR2 400 MHz SDRAM DIMM
    hope it helps, if so rate the solution
    Nov 16, 2010 | Intel D102GGC2 Motherboard
    Will Intel D102 Series Motherboard support Transcend 1 GB DDR2 667 Mhz RAM. Please confirm
    According to Intel, this board will support a maximum of 2 x 1GB PC2-4200 533MHz Memory Modules, so your PC2-5300 667MHz Ram may not work.
    Intel® Desktop Board D102GGC2 - System Memory Features:
    Non-ECC DIMMs
    DDR2 533 or DDR2 400 SDRAM DIMMs
    Jan 12, 2010 | Intel D102GGC2 Motherboard
    Max RAM for Intel 102 GGC motherboard
    Thanks to Intel website The board has two 240-pin DIMM sockets and supports the following memory features: * 1.8 V (only) DDR2 SDRAM DIMMs with gold-plated contacts * Unbuffered, single-sided or double-sided DIMMs with the following restriction: Double-sided DIMMs with x16 organization are not supported. * 2 GB maximum total system memory * Minimum total system memory: 128 MB * Non-ECC DIMMs * Serial Presence Detect * DDR2 533 or DDR2 400 SDRAM DIMMs Note To be fully compliant with all applicable DDR SDRAM memory specifications, the board should be populated with DIMMs that support the Serial Presence Detect (SPD) data structure. This allows the BIOS to read the SPD data and program the chipset to accurately configure memory settings for optimum performance. If non-SPD memory is installed, the BIOS will attempt to correctly configure the memory settings, but performance and reliability may be impacted or the DIMMs may not function under the determined frequency.
    Jun 16, 2009 | Intel D845EPI (INTELKD845EPILPAK10)...
    Intel DG31PR Motherboard Logo
    320 people viewed this question
    Top Intel Computers & Internet Experts
    Tony
    David
    David
    Computer Links
    Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
