Question about Everex StepNote NC1500 Notebook
Didn't work says it don't recognize it
  • Curtis Tuendemann May 11, 2010
    As I am constantly answering other peoples questions could you retype your error and update under it instead of clearing the page?
    I will assist you until we solve this issue if you do so ;)
    Regards,
    Blazamane
You know the "Add/Remove Programs"
You have removed you sound card driver, so you have to download it in the computer manufacturer.
Best regards,InJ3CtOr.
Aug 09, 2011 | Acer Aspire One AOD150-1920 Netbook
Tip
How to fix ?USB device not recognized? error in windows
Are you getting a “USB device not recognized” error whenever you plug in a USB mouse, keyboard, or other USB device? I love USB and have 5 ports on my computer so that I can connect my mouse, keyboard, camera, phone, and printer to it all at once!
However, last weekend, my computer stopped recognizing my USB devices! The strange thing about it was that the USB ports were not bad because all of my devices were still getting power to them. I could still charge my cell phone without a problem!
So I started with the normal fixing methods, including uninstalling the drivers for my devices and reinstalling them. That didn’t work! Next I tried System Restore thinking that maybe I had installed something and it caused a conflict with the USB system drivers. That didn’t work!
I read online that in order to fix this problem I should go to Device Manager and uninstall all of the devices under USB Controllers. Restarted the computer, reinstalled the USB drivers, but the problem STILL did not go away!
You may also see in Device Manager that the device shows up as an “Unknown Device”. 42b721d.png
So how did I finally fix the problem? Well, apparently it’s a super simple solution! No need to edit the registry, uninstall drivers, or anything of that sort.
Simply UNPLUG YOUR COMPUTER FROM THE POWER SUPPLY. Yes that’s it! Note that this does not mean just turning off your computer because modern computers don’t really turn off when you press the power button as the motherboard still gets power.
First to explain, the motherboard is where all of hardware of the computer is connected to, including the USB ports. Sometimes the motherboard needs to be “rebooted” also because something can go wrong, i.e. all your USB ports suddenly stop working. The small microprocessor on the motherboard will reload the drivers and your USB ports should be back to recognizing all devices!
So first turn off your computer using Shut Down or pressing the power button and then UNPLUG it from the wall outlet. Let it sit for about a minute and then plug it back in.
Hope this helps someone fix that pesky “USB device not recognized” Windows error!
on Jul 08, 2010 | Computers & Internet
Where can I download a driver for HITACHI CP X 260 for mac?
i didn't know mac needed drivers for projectors.... windows just connects right away
I thought mac did the same thing
I didn't find drivers for any Hitachi projectors
you might wanna get the conversion thingy for the mac input tho, if you don't already have it
and if you do you might wanna get another one, cuz some don't work correctly which might be the case
Aug 08, 2011 | Hitachi CP-X260 LCD Projector
We have 2 WASP WWS500 wireless freedom scanners that we have been working great with desktop computers (we don't use a pairing pass code). We have just bought two tablet's (HP Touchpad) and would...
Go to your blue tooth settings and delete it. After you delete it click on add blue tooth device. There is when it will ask you the 3 option's. The bottom Option is the one you want. (DON"T NEED A CODE OR DIDN"T COME WITH A CODE)
Jul 16, 2011 | Wasp WWS800 Handheld
I recently installed CAT6 cable to run between my computer and main stereo. The run is 50' so I also purchased a USB extender. My issue is that once I hook the network up to my computer, it can no...
Yes- don't use USB as an extender- Network spec for Cat 6 without a repeater ranges from about 165 feet to 75... You should be able to run the cable straight through.
Jun 15, 2011 | IOGear USB Booster Cable G2LUB16 USB...
I bought an EZ DUB DVD CD REWRITABLE MODEL SHW-160P6SU but it didn't come with any software. So I am looking fort he drivers that make it work.
Hi vickiejanas
You don't need specific drivers to have your device running , it' s plug and play and should be recognized by Windows .
For burning or copying sofware , any one will do , you don't absolutly need EZ DUB .
Best regards ,
fanaudi .
May 13, 2011 | Computers & Internet
My Sansa Media Converter won`t download videos or photos into my Sansa Fuze 4GB.First when I installed the Sansa Media Converter it wouldn`t recognize my Sansa Fuze.After a lot of research on the Internet...
Google a program called
Video Download Studio
then you can use it FREE download video or audio form YouTube, google, metacafe, redtube, dailymotion etc. attention: download function is no need to register
you can also use it to convert video to audio, video to video, audio to audio.
use it convert video to mp3 mp4 for your iPod
tutorial;
http://www.downloadvideos-convert.com/how-to-use
Jun 16, 2010 | SanDisk Sansa e260 MP3 Player
W705 mobile phone fault
just try to update it's service by downloading a new software version i guess.. maybe i could help..
May 26, 2009 | Sony Ericsson Walkman W705 Cell Phone
Would a SCSI disk and a IDE disk work together?
This solution works on WIN98 and I don?t see a reason why it wont work on you If there is something that you were missing you might want to check with anther expert. This solution is a little complex so I hope ill be able to explain it well enough: 1. Make a boot disk so u can format and install windows. 2. Define the new HD as MASTER and hook it up to "primary IDE" 3. Disconnect the SCSI and pull the board out. 4. Reset the comp from the boot disk u made (HD is connected) 5. Get in "bios settings" and make sure that the new HD is defined as "primary drive" In the 1st IDE 6. Now, perform a FDisk on the new HD, define partitions, do a reset and format the HD Install the operating system you wish to have, make sure it works well. 7. install the SCSI board and its HD make anther reset. 8. now the comp is supposed to make boot and recognize the SCSI, it is possible that you will need to define your system configurations but for that, regretfully, I cannot guide you Although this is not necessarily have to happen. Good luck
Feb 23, 2006 | Cybertron Intel Pentium 4 2.66GHz Serial...
SCSI and IDE HDs, can they work together?
This next solution is viable in win 98, and I don?t see any reason why it shouldn?t work for you too. If you know of anything I?m missing you should consult someone else. The solution is slightly complex, so I hope I can explain it properly: 1. Create a startup disk so you can format and install windows. 2. Set the new HD as master and connect it to Primary IDE. 3. Disconnect the SCSI and remove it. 4. Restart the computer with the disk you created (with the new HD connected). 5. Go to the Bios settings in order to make sure that the computer does recognize the new HD as the primary drive in the first IDE. 6. Now, FDisk the new HD, set the partitions, restart and format it. Install the OS and make sure it is working properly. 7. Insert the SCSI and restart again. 8. At this stage the computer would reboot into the IDE and see the SCSI/ You may have to change something in the OS settings for that, but I don?t know where. Good luck.
Feb 22, 2006 | Adaptec SCSI 29160 POWERDOMAIN MAC KIT...
Everex StepNote NC1500 Notebook Logo
Top Everex Computers & Internet Experts
Jerry Umali
k24674
Are you an Everex Computer and Internet Expert? Answer questions, earn points and help others
