Question about Bosch 3.81 cu ft WFMC530 1UC Nexxt 500 Plus Series Washer
There is a beat beat beat noise in the rinse and spin cylcle.
I just purchased Bosch Nexxt 500 Plus washer. Love it so far but am noticing a repetative sound like the wish wash of an agitator. I think it is during the rinse and spin cycles and maybe more on permanent press. Could it possibly be the pump? It is quite loud compared to the whisper quiet rest of the wash and I wonder if it is something wrong. Should I call the repair person?
    Genius:
  • 2,920 Answers
Call someone out to look at it from where you bought it or have them replace it. the noise shouldnt be there and if you just bought it you should have a warranty on it so the repair work if any should be free.
Posted on Jan 08, 2009
I have a Bosch Nexxt 500 front load washer that will not drain when it gets to the spin cycle. The drain pump is clear and free from obstructions as well as the lines are clear and manually filling up
Sounds as if the rinse hold button has been set by accident.check the switches top left.if they are correct, then next query would be logic board has a problem, sometimes fixed by hair drying the board in cases of damp lack of use washer.if machine completes most cycle then I suspect rinse hold button is on or open circuit.
May 12, 2014 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Washer will not do Final spin. the time stays on one minent for about 8 mins with no final spin
If the clothes are extracted of water it very well mean your timer needs adjusted slightly, If not, timer needs replaced. Remember, not 100% of your rinse water will be extracted so don't expect it to be hand touch dry when you remove load.But it should not be dripping wet or soaked either
Mar 08, 2010 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
My new Bosch Nexxt 500 series washer is less than 30 days old. I can turn it on any program and I can hear it initially fill with water, but it does not spin to wash or rinse. It does not have any error...
As your washer is less than 30 days old, I strongly recommend that you contact the company you purchased it from, and ask them to change it for you, under the sale of goods act, you have the right to insist upon a replacement washer.
However, before you do that, double check your handbook, and make sure it is nothing you have done wrong.
Try switching it off, and then try again to use it.
Please leave feedback.
Thankyou
Nov 13, 2009 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Bosch Nexxt 500 is on rinse cycle, won't drain the water or spin
Hi
I would check two things that might cause this problem .
1. there is small palstic capsule that comes out from the tank and has thin rubber pipe that goes to the electric tap. the purpuse of the tube is to send signale to the tap to close the water , actually the tap has a sensor that sence the change in presure when the water tank is filled . check this capsule and make sure that its clean.
2.looks like the cycle of washing hasn't started or started but hasn't pass the stage of heating the water . that means there is some problem with the heater that lies in the buttom of the tank . make sure all wires attached properly .
try run whashing program of cold water .
consider replacing the heater .
hope it helps
goodluck
May 25, 2009 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Bosch front loading washer nexxt 500 won't pump out water on the spin cycle
could be drain hose is not high enough. I had the same problem and when I raised the hose it worked fine.
Dec 04, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
My bosch nexxt 500 series washer won't spin
possibly the motor brushes.
take back panel off. disconnect motor. remove bolts holding motor in and take out motor. check condition of brushes
Oct 18, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Squealing noise
possible causes are:
bra wire stuck in tub and rubs against the drum and squeals when on spin.
lip seal at front of bearings squealing - this is a difficult repair
Sep 02, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Acoustic signal
select a cycle. hold down two option buttonsat same time until you hear ashort signal this disable it. (bleach& rinse pluse) to activate do same
Jul 21, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Bosch 3.81 cu ft WFMC530 1UC Nexxt 500 Plus Series Washer Logo
158 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
