Question about Whirlpool GEW9250 Electric Dryer
The dryer works but does not heat
Whirpool Duet dryer turns on but does not heat so it does not dry clothe. need to find service man asap. Located in Coral Gables, FL 33134
  • vin1976 Jan 08, 2009
    Hitachi DE 555 Electric Dryer, tuns but emits no heat.
  • vin1976 May 11, 2010
    Just as I suspected, but where do I get a replacement heating element, Any ideas?
    Novelist:
  • 101 Answers
Before you buy an expensive heating element change out the thermal fuse. It's only about 15 dollars for a fuse as opposed to around 100 dollars for a heating element. Both can be purchased at a appliance repair shop. The thermal fuse is usually located near the heating element housing and has two wires coming off of it. Make sure you unplug the dryer first though. If the thermal fuse if dead then your heating element will only heat for about a second or two at a time. The way to check this is to open up the dryer so you can see the heating element. While it's running watch it and it the heating element comes on and then turns off then the thermal fuse is bad. If it doesn't come on at all then the heating element is bad. Wait a good 5 minutes though before determining if the heating element isn't coming on. Sometimes it takes a bit before it engages. I hope this helps you and if you have any more questions feel free to ask me. Good luck.
Posted on Jan 22, 2009
    Genius:
  • 2,920 Answers
It will either be the heating element or the limit switches that are preventing you from getting heat
Posted on Jan 08, 2009
My duet whirpool electric dryer keeps stoping before my clothes are dry
Make sure you are not using a timed drying setting. Use one of the pre programmed functions on the dial. These settings are meant to use a sensor and stop when the clothes are dry. If the problem continues on one of these settings, there is likely a problem with the sensor or your heating element
Sep 15, 2014 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
My whirlpool duet dryer works but it appears that the air is not evacuating from the baril. The heat and humidity built up and the clothes don't dry. Do I need to replace the fan and if so, how
YOU NEED TO CLEAN THE VENT ON YOUR HOUSE IF THE BLOWER WHEEL IS BAD ON THE DRYER YOU WOULD HERE THE NOISE AFTER THE DRY STOPS THE BLOWER WHEEL WILL STILL TURN AND MAKE A NOISE
Oct 29, 2012 | Whirlpool Duet Steam WFW9700V Front Load...
I have a whirpool duet dryer the clothes are not getting dried
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jun 25, 2011 | Whirlpool Dryers
My Whirpool Gold dryer is heating up to dry the clothes, but the clothes are damp /wet.
Hello
When the dryer wont heat up and dry clothes it means that the thermostat/thermal fuse is bad and needs replacement. This part is located on the blower wheel housing inside the duct, please get back to me if you have any other questions.
Kevin
Nov 20, 2010 | Dryers
My whirpool dryer (Duet) seems to always take (2) cycles to dry...After the first cycle the clothes are still very damp.
Your dryer may be pushed too far back , causing the vent hose to kink , behind the dryer . Also , check the outside vent airflow , and check the lint screen holder , for any peeled off lint , which could also be blocking the outside air flow .
Oct 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirpool dryer won't heat up
You need to replace the thermal fuse and the timer. A bad timer will over draw a thermal fuse and cause it to blow.
Please remember to unplug the dryer before servicing
Mar 28, 2009 | Whirlpool LER5636P Electric Dryer
No heat
mcwilliams if you pull the over off the front of the dryer at the bottom you can see the gas burner assy. Put the dryer on time dry and start the dryer, you should see a glow from the ignitor, then hear a click, then the heat come on. In the auto dry mode, the timer advances along with the dryness level. No heat, No timer advancing. If you don't see a glow, there should be a thermosat on the heater can, see if it is tripped. If so if it is resetable, reset then try again. You may have a bad ignitor.
Feb 03, 2008 | Estate TGDX640JQ Gas Dryer
3 1/2 year old Whirlpool Duet Dryer stopped heating up
it could be several things but the element could should be the last part i would check first if you are still using fuses change them both if that doesnt work call for service call a good service man stay away from major companies they are expensive i know i worked for most of them
Nov 22, 2007 | Whirlpool GEW9250 Electric Dryer
Whirlpool GEW9250 Electric Dryer Logo
561 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
