Question about Olympus Camedia C-725 Digital Camera
LCD upside down and backwards
LCD on camera is displaying the picture upside down and backwards. Pictures can be fixed in Photoshop but reading the menu is really difficult. Snyone had this happen before?
  • 883 Answers
Look for a small pinhole somewhere on the camera body. then insert a pin to reset the camera. if no pinhole, remove batteries for a long time (about 24 hours) then try again.
Posted on May 31, 2007
How to fix upside down camera
When Taking Pictures With The Camera On My Phone They Are Upside Down, How Do I Fix This?
When taking pictures with the camera on your phone, there is an option to rotate the camera's vantage point. Pressing the up/down buttons on the side of the phone (Some phones differ but in most cases this would be the Up and Down Volume buttons) it will rotate the camera. If your pictures are coming out upside down, press the volume button to reverse the direction and try again.
keep the iPhone "right-side up" when snapping photos or recording videos--meaning with the volume buttons pointed down. Why does my iPhone take upside down photos CNET
http://phonephotographyschool.com/iphone-photos-upside-down
Apr 15, 2015 | Computers & Internet
Display is upside down
hi,
it sounds like the tinny switch that detects the rotation of the LCD is blocked on the 180 degrees mode. it can be fixed but you need to disassemble the cam ! or may be try a little shock near the hinge... sometimes machines need a little kick !
Apr 04, 2014 | Sony Video Cameras
My Nikon Coolpix s203 is having a monitor problem. While it still takes picture and uploads fine, the image in the screen is upside down, and remains upside down even if camera is held that way. In...
Okay, what your going to need to do here, D not shoot the tech is bring this to a camera shop.
The issue is with the video output to the lcd display not the display itself. Nikon is aware of this happening due to extended use of the display but they will not fix it because it would be out of warrenty.
Your looking at $45 in parts alone labor I would set at $15-25 per hour. So if this camera cost $100 bucks then you would look at alternitives of course.
Please do not shoot the tech, We are not charging you here we are lookingfor you execlent feedback and ratings in exchange for the advice. Thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jun 16, 2010 | Nikon Coolpix S210 Digital Camera
LCD PICTURE UPSIDE DOWN
This is a feature not a bug...The LCD is designed to flip the picture when you rotate the screen. This is so that you can see what you filming or be in the picture and see yourself filmed. I can't remember if it flips automatically or not. But, I would first try inverting and reverting the LCD screen to see if you can get it to detect orientation, then check and see if there is a setting to manually set the orientation of the LCD instead under the menu options.
May 05, 2010 | Sharp Viewcam VL-Z3U Mini DV Digital...
No lcd display and no pictures
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jun 27, 2009 | Canon PowerShot G5 Digital Camera
Inverted image
no solution I know and I have the same problem!!! Did you find a solution yet???
Mar 04, 2009 | Konica Minolta DiMAGE E50 Digital Camera
Want to print pictures from camera card.
I received my Brother printer today (11/5). I also go mine mainly for the scanner because my Visioneer 9320 doesn't have any drivers for VISTA, and Visioneer isn't making any updates.
My camra uses a SD card. This is how I got mine to print pictures.
I place my SD card into the printer
I then press the PHOTO CAPTURE button The display on the printer reads CONNECTING TO PC
Then the display reads PRESS (up arrow or down arrow) & OK
When you press the up or down arrow, the display will read PRINT IMAGES or PRINT INDEX
I selected PRINT INDEX and then you have to press the OK BUTTON
The printer display then will ask 6 images per line or 5 images per line.
You pick what you want then you hit the OK button.
Don't forget to put the photo paper in the tray, upside down.
Hopes this helps
Nov 03, 2008 | Brother Multi-Function Center MFC-240C...
Picture is upside down and backwards
I have the same problem. How and where does this come from? My camera was sitting in the dock when I noticed the problem!!
Nov 26, 2007 | Kodak EasyShare C315 Digital Camera
Camera keeps shutting off
Have you fully charged the new batteries
Nov 03, 2007 | Fuji FinePix A345 Digital Camera
My Screen is upside down and the words are backwards
The first thing I would do is a reset. Read your manual about this process, which often requires pressing two buttons at the same time or take your batteries out, wait a minute and put them back. See if resetting helps. Not being familiar with your camera, speciffically, Ithis sounds like the firmware in the camera is reading the info back to you backwards when it processes the image (from memory) for you to view. That means it is the firmware in the camera that is defective and sometimes you can update or reinstall that. I would check the manufacturer's site for updates or recalls and if it is under warranty, send it back to be fixed.
Jan 28, 2007 | Fuji FinePix A120 Digital Camera
Olympus Camedia C-725 Digital Camera Logo
179 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
