Question about GE 24 in. GSD4020Z Built-in Dishwasher
Sears Kenmore dishwasher drains and then fills back up.
The dishwasher drains completely, but then after a while water beguns to seep back in. By a few hours there is 3 inches of water in the bottom.
  • Cam Jan 02, 2009
    I have the same problem with a 1997 KitchenAid dishwasher. It runs great otherwise.
  • 883 Answers
You have a nearly-clogged u-tube near the connection to your house drain piping. clear the clog out.
Posted on May 31, 2007
For 6 mos. now, my dishwasher has begun to leave this white filmy, cloudy residue on all my dishes. It has ruined calaphon utensils and glasses I have had for 14 years. The detergent has always been the...
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound. If it seems as a low water pressure then check the fill valve.
Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Hope this helps......
Daniel
Feb 02, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
Kenmore 17379 dishes are not clean after running a cycle
Hi
Jan 31, 2011 | Kenmore 24 in. 17372 / 17374 / 17379...
Kenmore Quietguard 2 dishwasher not filling.
There is a solenoid that keeps the water in the washer. It is either faulty or there is something preventing it from closing completely. If there is no power applied to the washer, does it then hold water?
Apr 28, 2010 | Kenmore 24 in. 17002 Built-in Dishwasher
Dishwasher does not fill
Double check that your water supply line is not kinked.
This sounds like a bad fill valve. If you have hard water and most everyone does after a few years the valve will quit working properly and will fail in one of 2 ways a slow or no fill or it will not shut off completely.
I hope this helps if I can help with anything else please let me know.
Apr 15, 2010 | Kenmore 24 in. 16003 Built-in Dishwasher
I have a Kenmore Elite dishwasher (2004) and recently it has been leaking internally at a very slow pace. When not in use it will slowly fill until the floor of the unit is filled and then leak onto the...
The water is admitted into the dishwasher through a little magnetically controlled valve underneath your dishwasher. This valve opens and shuts electrically. There is a little plunger in it that is pushed shut by a spring when no power is applied to the magnetic coil. Dirt can get underneath the plunger and allow water to seep through the valve. That is what is happening in your case. This soleniod vavle will need to be replaced.
This tip is about that valve and will help you to idenify it, find a replacement and install a new one. The problem is different, but the reverse is happening for you.
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
Heatman101
Feb 17, 2010 | Kenmore Dishwashers
Dishwasher fills up with dirty water after completing cycle.
does the drain line connect to the disposal?if so and dirty water is inside dishwasher the line must be looped under the sink so nothing can run back into the dishwasher,tie the drain line up higher than the disposal or higher than the point where it connects to the drain pipe so nothing can drain back into the washer.are you sure the water is draining out of the machine?fill it up and hit cancel drain and listen to see if you hear it draining in the sink,if the line isn't looped you could have a block in the drain line or in the pump
Feb 03, 2010 | Kenmore Dishwashers
Water keeps coming back into dishwasher after cycle is done
sounds like maybe one of your check valve is not working right.
Jun 03, 2009 | Dishwashers
Water in the dishwasher after the the cycle is complete
Two things to consider....clean water or dirty water?
Clean water usually indicates the fill valve is not shutting off all the way and the fill valve is "weeping" water in all the time = new fill valve time!!
Dirty water usually is not a dishwasher problem but more of a plumbing issue. Often the sink drain that carries the sinks water outside is not fast enough and some of this sink water is backing up into the drain hose and filling up the dishwasher through the drain hose. The drain from the sink to outside needs attention as this type of a problem indicates a slow house drain for that sink.
The dishwasher drain line should be clamped to the top underneath part of the counter before entering the sink drain plumbing, this may help the water from coming back inside the dishwasher.
Nov 19, 2008 | Whirlpool 24 in. GU1200XT Built-in...
Water seeping in dishwasher
If your dishwasher leaks, check these:Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
1. Lower rack
2. Spray arm
3. Spray arm support
4. Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
thanks for using FixYa
Jul 29, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Sears Kenmore Automatic Dishwasher: Models No. 14041 /14045 /14045... Problem:
Many dishwasher have their drainlines tied into under sink disposers. If a person caps the sink drain while dishwasher is running, it can back the water back to the washer keeping dishes dirty and backing up water
Jul 05, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
GE 24 in. GSD4020Z Built-in Dishwasher Logo
429 people viewed this question
Top GE Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Steve Allison
Steve Allison
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
