Question about Saeco Vienna Espresso Machine
Need to send in for repair...multiple things wrong. any suggestio
Leaking water from underneath unit, only brews half a cup the majority of the time...despite being set correctly, Light for the buttons for steam and brewing go off and unit has to be reatrted in order to work.
    Problem Solver:
  • 8 Answers
Sorry for the delay in response but I just read your complaint. I had similar water leakage issues and mistakenly replaced a bunch of stuff without stopping the leaks, until I discovered the real problem; the O ring seal that the water reservoir sits in located under the reservoir where it mates with the machine. Easy to replace and cheap. No leakage problems since I both replaced the O ring and started the routine of not taking off the water reservoir to fill it, but leaving it in place and filling it from a bottle. That technique does not any wear at all on the seal ring and so it won't leak in the future.
The item is called a "Saeco-water inlet valve gasket" , has a part number of NM05.006 and costs $7.50. I purchased it from Services Unlimited located at 650 N. Cannon Ave. WH-305, Lansdale PA 19446; phone 215-361-7000 Fax 215-361-7434, e mail granita@rcn.com but you can find it at any authorized dealer, I am sure. I ordered two and with shipping the cost came to $21.50.
You can request a fax with a parts diagram and listing, which I found most helpful in diagnosing issues and see where stuff goes..
A second cause of water leakage is the drain set back in the machine that is behind the brew group which gets clogged on rare occasion. Remove the brew group and take a paper clip and insert it in the drain and make sure it drains freely into the drain pan.
A third cause is that you are not cleaning the removable grinding surface in the brew group. If it gets clogged, the hot water cannot pass through it and it just kinda squirts all over inside the machine, and you get weak coffee since most of the water is not being brewed.
Hope this helps you..
George W Conrad
Posted on May 04, 2009
    Genius:
  • 1,199 Answers
This sounds like you have a leak or a hose disconnected(water under unit! half a cup of coffee!) this is also the cause for it turning itself off (its shorting out from the leak) Return for repair!!
This unit is defective!!
PLEASE rate my response to your question
Thank
You!
Posted on Jan 08, 2009
It leaks water under the right side of the brew basket.
Leaks water when brewing ground coffee with a My K-Cup ...
https://www.ifixit.com/.../Leaks+water+when+brewing+ground+cof...
iFixitWhen I use the My K-Cup filter to add my own ground coffee and brew it, after it ... the machine starts leaking water at the same time, so typically the mug beneath the ... in the lid that has the needle opening in it (half sphere perforated basket below it). ... thewater could simply flow over the coffee, and go right down the sides.
Stop Leaks - www.My-Cap.com © 2015
www.my-cap.com/stop-leaks.html
Jan 01, 2016 | Coffee Makers & Espresso Machines
Cuisinart DGB coffeemaker
Does the water leak out before or after the brew? Can you leave water in it without starting a brew cycle, or does that leak as well?
Jul 21, 2008 | Coffee Makers & Espresso Machines
My Cuisinart Grind and Brew has begun leaking water underneath the unit as it is brewing.
I also have the same problem with water leaking out of the bottom.There is a defective hose underneat the burner plate (dry rotted)Mine is manufactured in 05.We contaced Cuisenart to make them aware of the problem and they told us nothing they could do it was out of warranty.After talking to 3 of there costumer service reps.my husband decided to take it apart and found the shredded hose leaking water on the electrical wires.That is why we contacted the CEO of the company and The Consumer product safety commision..They are handeling this issue.You can contact them also .
Mar 07, 2010 | Cuisinart Grind and Brew 10 Cup Coffee...
Brewed coffee leaking into spill tray underneath
HI
You have a stripped thumb screw. It needs to be replaced. It holds the filter screen in.
Dec 06, 2009 | Saeco Magic Comfort Plus Espresso Machine
Leaking Noritz water heater.... I have a Noritz N-069m water heater. When i purchased the unit 3 years ago, i was told that if i installed a water softner unit it would void the warranty. A year and a half...
Check your water pressure and the diagnostic codes on the controller to see if there is computer failure or another problem with the unit. send me an e mail i might be able to help im a nortiz certified service tech scott@bridgeplumbing.net
Jul 27, 2009 | Noritz 6.9 Gallon Residential Direct Vent...
Leaking a half cup of water from the bottom while brewing
Call bunn for replacement gasket free of charge per recall.
Jul 13, 2009 | Bunn 10 Cup Home Coffee Brewer
Water is leaking underneath my Solis Master 5000
The only thing that comes to mind is the drain behind the brew unit under the white plastic valve.
Jul 09, 2009 | Coffee Makers & Espresso Machines
Leaking cuisinart grind and brew
Our Cuisinart grind and brew was leaving a puddle under it after making a pot of coffee. I called Cuisinart this week and it turns out the handle of the carafe has to be lined up in the middle of the opening for the carafe. It will be under the word Cuisinart, in the middle.
We have now made several pots with NO residual puddle of water or coffee. It also seems to be making the pots quicker.
Before trying this I had run 2 pots of water with 1/2 cup white vinegar in it also. But it still puddled until we lined up the carafe as noted above.
Nov 30, 2007 | Cuisinart Coffeemakers
Saeco Vienna Espresso Machine Logo
522 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
