Fan operates on x3 but no picture
I have a infocus x3 that when i power on does the normal whine and hum but then shuts off and comes back on and does this for a minute or two while blinking a green light. then red light blinks. now i probably haven't taken care of the bulb that well is it blown only had 700 hours on it. it also had a thin line running across the top of the screen for several weeks before it went down.
  • 22 Answers
Very likely your bulb. Could also be your ballast.
Posted on Jan 09, 2009
Total shutdown after after a few minutes
This is a power supply failure.
infocus.dex.com
5E.13440.003 PCBA, POWER BD$78.90
Oct 31, 2013 | InFocus IN102 DLP Projector
Annoying hum on the projector
are you sure its not the fan?
I supose its good to clean the fan and the inside ones a year.
dust gets in there.
The fan could be failing.
il get back to you about the humm
Mar 27, 2008 | InFocus ScreenPlay 4805 Multimedia...
Infocus IN10 projector, when I turn it on the light blinks green for a while (with no picture) and then it shuts off and blinks red (more than 5 blinks)
if Lamp or projector shuts off after running a short period of time, This is usually a thermal issue caused by excessively
high internal temperature. The high temperature
could cause a component on the controller ECA or
the power supply to fail when it gets hot.
First you need to check the fan operation, Are 3 fans, two for lamp and one for the color wheel. Check the elevation foot, if something is broke maybe something stop the fan.
Remove the lamp module.
Examine the fan assembly through the recess in the bottom case. Plug the projector in and turn it
on. Both fans in the fan assembly should start up and run for 5 - 10 seconds, then shut down
(because there is no lamp installed). This is time enough to make sure the fans work properly.
Make the same for the color wheel fan, you need to remove the top case.
Oct 15, 2013 | InFocus Work Big IN10 DLP Projector
InFocus ScreenPlay 4805 no projection. Unit powers on and green light blinks, but no light and no fan, eventually red light blinks continuously about 2 seconds between blinks. When the green light is...
the high-pitched sound is the colorwheel trying to spin up to speed. that may need to be replaced. check the inside of the lamp for bulges, black spots, fogging or flaking. if it has any of those, replace the lamp. you can get parts from an infocus service center or send it to them for repair. either way, try www.avsolutionsny.com they're really good. if you want to replace it yourself, there is a detailed step-by-step on my "tips" area. it's the same as the infocus x1, x2, x3 and sp4805. click on my picture and scroll down to tips. good luck!
Feb 01, 2010 | InFocus ScreenPlay 4805 Multimedia...
My infocus PL70+ powers up but there's no picture. after I plug in, the amber light come on so I hit the power button, green LED light flashes, fan kicks in, green LED remains steady after flashing for a...
if you hear chirping or a loud buzzing, you have a bad colorwheel. the lamp won't turn on if the colorwheel doesn't spin as fast as it needs to. if you don't hear anything like that, you need a new power supply. the lamp striking takes a lot of power, and if the power supply can't handle it, it shuts off. you can get the part from an infocus service center and replace it yourself, or send it to them for repair. either way, try av solutions in ny. they're really good. www.avsolutionsny.com
Jan 12, 2010 | InFocus LP70+ Multimedia Projector
I left my infocus x3 on ovrnight wnet down this morning it was shut down when i start it up fans and everything work normal but the bulb doesn't on and it is a fairly new bulb it have had the x3 for about...
it's not recomended to run constant for a day or longer. it may have overheated the lamp. especially if you've never cleaned it out before. take canned air and blow out any dust. but first remove the lamp and see if there is dust blocking the side vent. if there is a lot, the lamp overheated and prematurely blew.
Oct 30, 2009 | InFocus X1 Multimedia Projector
Humming noise from NCR RealPOS 70
In a word...yes. Except that you said it is coming from the "screen"? Did you mean the screen on the power supply? If so then yes...probably the fan.
Mar 17, 2009 | Computers & Internet
My bulb went out on my infocus sp-4805. I bought a new bulb, and replaced it, and it worked...for five minutes. the picture went out, and it was overheated. I took some parts off, and sprayed can air in...
The fan is probably on it's way out and cannot produce enough air flow to cool the lamp. Replace the fan with the same ratings as the original and it should work fine. The only other thing would be a problem with the power supply not supplying enough power to the fan, but, a bad fan is more likely.
Feb 24, 2009 | InFocus ScreenPlay 4805 Multimedia...
Infocus projector power supply dead
the caps dry out. look for bulging caps. you won't find a schematic for the ps boards. infocus had someone else make them. the problem seems more like a overheating issue. as for the other one with the "just the fans", check the colorwheel.
Oct 03, 2008 | InFocus POWER SUPPLY CORD Multimedia...
Infocus x1 projector
Indeed, the problem you describe is the Color Wheel. Very common issue in the X1,2 projectors. Unfortunately the only fix is to replace this wheel. The cost of the part generally runs around $175 but the labor to replace is about the same. You will need to find an authorized service center where you live or send it to a repair facility. Parts for any of the InFocus units are generally not available to the public, alas the Service Centers. Maybe for the same cost you could look at a new projector, like I did.
Jan 18, 2008 | InFocus X1A DLP Slide Projector
531 people viewed this question
k24674
jasbo
jasbo
