Question about Dynamic Arrow Fastener Co. T50PBN Staple & Gun With Expando Attachment
How do you load brads into the Arrow t50pbn staple gun?
I have an Arrow T50PBN staple gun with no instructions. I need to know how to load the brads into the gun.
  • Anonymous Mar 15, 2014
    brads jamed in gun
Yes, the gun comes with no instructions. Strange but thanks, there is Internet. DO NOT PUSH THE TRIGGER during any time of this process. BE SAFE and use your common sense. If you don't know what you are doing, stop right now and see help from someone who knows more.
1. Turn the gun upside down so the bottom of the gun is upwards. let's suppose the end through which the stapes come out are on the left side and a little spring push tab is on the right side when the gun is in this position.
2. Push the spring tab in and you will see a little catch disengage from a notch (the notch is located just above this push tab).
3. While keeping the tab pushed in, pull the tab up until the catch that disengaged from the notch (see step, above) comes clear of the notched area of the gun.
4. The spring loaded bar / arm will pop /slide out now.
5. Load the staples into the staples housing / channel (make sure the open end of the staples is upwards (remember, the gun is upside down and the bottom of the gun is facing up)).
6. Slide the spring arm back in. Push it in a bit and let the catch in the push tab pop back into the notch.
Posted on Aug 19, 2011
  • Kathy Homme Mar 31, 2014
    That works for the staples but not the brads.
My Arrow T50 seems to be jammed how can I fix
Posted on Apr 13, 2009
  • 195 Answers
Look at rear handle and push in tab then pull out load brads. Please Rate Thanks
Posted on Mar 23, 2009
I have an Arrow JT-21M staple gun. How do I open it to add more staples?
there is no loading trya that pops out. the pusher arm is removable. when that is taken out you slid in the staples and replace the pusher with the locking tooth facing up.
http://www0.epinions.com/prices/Arrow_Fastener_PK21_Parts_Kit_for_JT21M_And_JT21CM_Staple_Gun_Tackers
Sep 03, 2010 | Dynamic Arrow Fastener Co. T50PBN Staple &...
Where can i buy batteries and a charger for my dynamic d90
Jegs11 Keynexions on eBay UK has mains-adaptors and car power-leads for The Dynamik D90S (gas-powered nail-gun); EU 2-pin, US/CA 2-pin, AU/NZ 2-pin, UK/IE 3-pin, as well as the universal car cable. They do NOT stock the actual charger-base though...:
http://stores.ebay.co.uk/Jegs11-Keynexions/_i.html?_nkw=d90s&submit=Search&_sid=58583447
Aug 21, 2010 | Dynamic Arrow Fastener Co. T50PBN Staple &...
Instruction book for Arrow ETF50P staple gun . lost the instructions and can't figure out how to insert the staples in the gun
Look at the rear of the stapler. Push in then down on the stapler tensioner to release it from the rear of the gun. Slide the tensioner out. Next slide the new staples over the rail and into the gun with points down. Slide the spring tensioner back in and connect it to the stapler by maneuvering its clip down and then up.
Apr 19, 2010 | Arrow No.ETF50PBN Extra Heavy Duty...
How do I load staples? I can not find my manual!
On the back bottom of the stapler there is a rod you need to lift up and then pull out on it should come out
Nov 15, 2009 | Arrow No.ETF50PBN Extra Heavy Duty...
The door at the back of the staple gun won't close
You may have too many staples loaded in the magazine.
Jun 05, 2009 | Arrow No.ETF50PBN Extra Heavy Duty...
T50 stapler gun it worked for about 15 applications then just stopped, it's not jammed, it has staples loaded properly & firing off staples repeatedly doesn't work nothing comes out??? Why would it just...
It sounds like a manufactor defect in wire harness or premature silinoid burn out,
or you simply need to make sure you plug into and outlet that works. Could be cheap but not worth repair,return as defect if possiable and buy new one before.
Please rate. Thanks jj505
Mar 27, 2009 | Dynamic Arrow Fastener Co. T50PBN Staple &...
How do I load the brads into my Arrow T50PBN staple gun? Do not have a manual or paperwork.
Remove tail end bt pushing in,up,and pull out spring loader. Load up to 50 staple only!!
If loader will not go back in you have to may staples so remove some.
Jan 08, 2009 | Dynamic Arrow Fastener Co. T50PBN Staple &...
Inserting brads into my Stanley TR250 Staple Gun
I bought one of these guns today and I had the same problem and it took me about 2 hours to figure it out as the instructions were very poor. Here how to load the brad nails:-
(a) Pull the slider bar all the way out
(b) Place the brad nail stick on the left side, IN FRONT OF the slider, NOT in the narrow gap in front of the two arrows where it says "LOAD BRADS"
(c) The nail heads should be facing the handle of the gun
(d) Close the slider and lock it
(e) Try it out. I tried nailing hardboard onto chipboard. The lever at low power only put the nail in about 30%. On Hi power it went in about 80%.
Good Luck
Peter
Jan 07, 2009 | Stanley TR250 H Heavy Duty Heavy Duty...
How to insert fasteners
Already posted in response to a similair question, however repeated here to close off open query!
Good Luck
Peter
How do I load nails in Stanley powershot staple/brad nails
you can try and go to Stanleytools.com and get to their knowledge base of FAQ or they have a direct way to contact the company for the information you need. I was on their site and have seen better to help the end user.
Dec 22, 2008 | Stanley Tools Staple/Brad Nail Gun
Dynamic Arrow Fastener Co. T50PBN Staple & Gun With Expando Attachment Logo
2,978 people viewed this question
Top Dynamic Tools & Hardware - Others Experts
John Trevino
J.D. Browning
J.D. Browning
Are you a Dynamic Tool and Hardware - Other Expert? Answer questions, earn points and help others
