Question about Jabra BT250 Consumer Headset
Jabra VBT2050 Bluetooth won't pair with LG Voyager
I followed the directions to the "T" and I still can't get my LG Voyager to "discover" my Jabra 2050. I am sooo frustrated! Can anyone help?
  • Anonymous Jan 10, 2009
    I am having the same problem with the Centro and an LG Rumor
  • dana lollar Mar 09, 2009
    had the same issue...but i never got any notification that something was wrong or needed to be repaired...holding the volume up and down and call answers buttons all at the same time works!! Wait til the light is on constantly...and then follow the bluetooth menu on ur phone. Awesome fix!
Something similar happened to mine. It worked for 2 months, and my phone received a message from jabra to reset pass key. It did not accept, and it stopped working with my phone. I tried everything. I was told to hold the power down for 10 seconds to place in pairing mode, that did not work. This did. Hold the volume up down and the answer button down at the same time for 7 seconds. You have to make sure they are all down or it will not work. You will see that the light will stay lit continuously. This means it is in pairing mode. Then place the bluetooth on your phone on. Tap find device at the top. It will then locate the jabra. Follow any other prompts. If it asks for a passkey, or code, 0000 will suffice. Hope this helps. I looked for almost an hour and a half for the answer.
Posted on Jan 31, 2009
If you have the voyager in black it is listed as not being compatable on the website check the compatability on the site select the bluetooth then above it says check the capatability
Posted on Jan 26, 2009
How pair bluetooth Jabra vbt2050 with a blackberry storm 2
In order to pair a BlackBerry device with a Bluetooth device, the Bluetooth device must be in pairing mode. Most Bluetooth devices are not set to pairing mode by default. Therefore, refer to your Bluetooth device manual for instructions on how to set the device to pairing mode.
Mar 04, 2010 | RIM BlackBerry Storm2 9550 Smartphone
Can't get new Jabra BT8040 to connect to LG Env3
I have the env Touch and the Jabra Halo. Initially, I had a problem pairing the two, then I realized that I was not following the directions properly. The manual shows two sections for pairing ("first time pairing" and "later pairing"). I was following the instructions for the former when I should have been following the latter. I also failed to notice that the BT indicator was flashing blue and not solid blue, as it needs to be, for pairing mode. So, if you haven't already done so, follow the instructions for "later pairing" here. Make sure that you see the SOLID blue light on the BT indicator on the headset when you try to pair.
Jul 17, 2009 | LG enV VX9900 Cellular Phone
Pairing Problem - BluetoohJabra VBT2050 & LG Shine CU720
I have a Jabra VBT 2050 bluetooth headset. As per the product user manual(page 8) this device is compatible with any bluetooth mobile phones with bluetooth version 1.1 or higher.
My LG Shine CU720 mobile phone is not able to detect the VBT 2050 device. I checked the specification of mobile phone & its bluetooth 1.2. I am able to pair the VBT 2050 with other bluetooth mobile devices.
Could you help me resolve my problem. Appreciate quick help
Apr 01, 2009 | LG Shine 720 Cellular Phone
PIN on my cellphone doesnt show after seeing Jabra 2050
FIX YA IS NOT PAYING US THE MONEY WE EARNED (MOST OF US)! AND A SUIT IS BEING FILED WITH THE DISTRICT ATTORNEYS OFFICE! I SUGGEST YOU GO TO ANOTHER SITE TO GET YOUR ANSWERS!
Feb 15, 2009 | Jabra T-Mobile Wing / Dash / SDA /...
I cant pair motorola H350 to Voyager
Can you pair the voyager with anything?
Are you putting the bluetooth headset into pair mode correctly?
Feb 06, 2009 | LG VOYAGER VX10000 Cellular Phone
Jabra VBT2050
The above solution only lacks one small item. Part of the pairing procedure is to hold the on/off button for the recommended 5 seconds to power up, but the light will NOT become constant until you hold both the power button AND the round center button on together until the light remains constant. Then you can pair the two devices.
Jan 27, 2009 | Jabra BT250 Consumer Headset
Jabra VBT2050 headset won't pair with blackjack II
ARE U FOLLOWING THE CORRECT PAIRING PROCEDURE
pls follow this
ok here u go first turn on the bluetooth func in ur mobile, now while ur bluetooth headset is off press the power centre big button for like 10 sec until the blue light stays on continously not blinking position ok then search for bluetooth devices in the phone bluetooth config ur headset will come up like JABRA VBT2050 select it then it will ask u for pairing code input 0000 and press ok ur device is now connected u will see the blue light which was continous b4 now blinking it means ur haedset is connected , u have to complete this process in almost 1 min bcoz there is a timeout for this process , now try any call u will hear it in ur headset
pls rate me fixya for this if it helped
Jan 13, 2009 | Motorola Mobility H350 Wireless Headset
Setting up Jabra VBT2050 Bluetooth
I took my husband's suggestion and used 0000 and it worked. My husband claims it is the factory default for all bluetooth headsets. Try it and let us know if it works.
Dec 26, 2008 | Jabra BT350 Bluetooth Headset Headset
Jabra vbt2050 won't connect
Jabra VBT2050 - You have to hold the round button in until the light stays lit (about 20 seconds) this will put it in discoverable mode, the pin is 0000, I have AT@T service and it works just fine. Hope this helps out!
Dec 21, 2008 | Radio Communications
Cannot pair LG Voyager cell with Jabra BT150
do you have the bluetooth in discovery mode first before trying to pair?
Nov 30, 2008 | LG VOYAGER VX10000 Cellular Phone
Jabra BT250 Consumer Headset Logo
2,221 people viewed this question
Top Jabra Radio Communications Experts
TO Lady
Greg Cann
Greg Cann
Michael Vincent Cruz
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
