Question about Whirlpool Kitchen Ranges
Whirlppol gas range not lighting.
Whirlpool gas range model #SF395PEP not lighting. The oven selector and temperature control are both turned on. The burners and broiler operate. The electric ignitor element for the oven does glow and I can smell gas but the oven burner does not light.
4 Suggested Answers
  • 1314 Answers
SOURCE: Magic chef oven
change the bottom ignighter just because it glowes doesn't mean its getting hot enough to open the safety valve you should see two screws at the bottom of the floor of the oven cavity after removing the racks remove those and remove the floor then you will see a deflector shield remove that to get access to the ignighter take out the two screws and install the new ignightor and reassemble
Posted on Jan 21, 2008
localwonder
  • 6784 Answers
SOURCE: oven quit working
Hi. this is common in many old gas range ovens. There is a set of coils that are attached to the gas valve assembly. These coils , when activated and operational, open and close the main and secondary valves in this unit. They are controlled by the main ERC(clock/oven control board). I recommend checking these coils and there respective wiring harnesses. if the clips and wires are worn and corroded, simply replace the entire wire harness.
Now, if the wiring harness and wires that are connected to the coils look good and there are no signs of corrosion on the wires and connector clips, this will confirm that the coils have failed and you will need to replace them.
You can also preform an additional test with a multimeter. simply connect your multimeter or voltage meter to both terminal posts located on the coils. once your meter is connected, start the oven cycle. you should register some sort of current during this test at this time. if the current is sufficient and the coils do not initiated the valve action, this will confirm coil failure. if the meter dosen't register a current during oven operation, this will confirm ERC(control) failure. you will have to replace the Oven control board in this case.
The Most common issue in this situation will most defiantly be the coil assembly and not the control.
Please rate and god bless:)
Posted on Apr 21, 2009
heatman101
  • 43501 Answers
SOURCE: I have a kenmore range the oven burner does not
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
sgf
Posted on Sep 30, 2010
Onece the range selector is turned on the light comes on but soon goes out, if you move the selector a little the light comes back on, this stove was made around 1952. Thank You, Dave
Are you talking about the oven temperature control? When turned on to the selected temperature the oven indicator will light and the element will work. When the oven reaches the desired temperature the power will shut off to the element and the indicator light will go out. When the oven cools slightly the indicator light and the element will again turn on. When it does turn off and you turn the knob slightly to increase the temperature the indicator light and element will come on again as you are asking it to heat to a higher temperature. This is normal oven operation.
Mar 10, 2011 | Kitchen Ranges
Whirlpool gas range error code f2
Hi sauerteig_j,
Whirlpool F2 error code indicates that oven temperature is too high. And to fix this problem:
1. Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
2. For SELF CLEAN models: check door lock operation.
3. Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
Remember: Oven control (ERC) measures resistance of sensor circuit, not actual oven temperature.
For replacement part you may contact Sears at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central. Just have your model # ready when you call.
Hope this helps.
Thank you for using FixYa.
Feb 08, 2011 | Whirlpool GS475LEKS Gas Kitchen Range
Whirlpool oven f2 error code. I turn the oven on and after the initial 10 minute warm-up i get an F2 error code and the oven beeps non-stop. I have already replaced the oven temp sensor. Could it be the...
F2
Oven temperature is too high 1. Look for welded relay contacts on bake or broil relays. If this
2. For SELF CLEAN
temperature
Dec 16, 2010 | Whirlpool GS475LEKS Gas Kitchen Range
Whirlppol Accubake Super capacity 465 model SF368LEPQ takes forever to bake thinkgs like brownies. They end up hard outside/soft inside. Sometimes it shuts off mid cooking cycle.
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Jul 15, 2010 | Whirlpool SF368LEP Gas Kitchen Range
Oven wont come on
Cleaned the oven yesterday with self clean and the next day while cooking on the top it just stopped working
Dec 24, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
I have a whirlpool gas oven model # SF395LEEBO
Oven temperature sensor opened Replace oven temperature sensor
Jan 11, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Oven control, possibly thermostat or oven selector switch
my dacor ER36G oven will not ignite. The top range works perfectly. When I turn on the oven, I don't even hear the gas or the ignition sequence as I used to. The heat preset light just blinks and the oven will not engage. I have reset the circuit breakers just in case, but nothing works.
Dec 07, 2008 | Whirlpool Kitchen Ranges
Whirlpool Gas Range E2 F3
I HAVE A WHIRLPOOL GAS RANGE MODEL NUMBER SF379LEMS.OVEN WILL LIGHT UP BUT AFTER TEN MINUTES IT WILL KICK OFF ANF ON ON ,THEN AFTER AWHILE I WILL JUST SHUT OFF.ANY SUGGSTIONS. ADAM
Nov 23, 2008 | Whirlpool GS470LEM Gas Kitchen Range
How to fix fault code E0-F2 on whirlpool gold gas oven?
The E0-F2 could mean one of the following:
1. Shorted keypad - Replace Electronic Range Control/Clock (ERC)/ Keypad
2. Oven temperature is too high - Check or repair the following:
  • Test operation of door lock on self-clean models
  • Test relay contact operation
  • High resistance in oven temperature sensor
Hope that helps!
Nov 07, 2008 | Whirlpool Kitchen Ranges
Kitchen Ranges Logo
187 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
